Tubes losing air tip
Quoted: 3352 Post(s)
Liked 1,056 Times
Sometimes presta tubes lose air pressure and you simply cannot find a puncture. Be aware that some presta tubes have a screw in valve like schrader tubes do. Check the stem closely, and if you find flats, simply tighten the core back down.
Likes For rydabent:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Likes For GlennR:
Quoted: 6196 Post(s)
Liked 4,810 Times
While I hear and read about presta valves with removable stems, I've never been aware of any that passed through my hands. What brands use removable stems? Is it something they use as a marketing tactic and have displayed on their box?
And why? Other than those using tubeless setups with the valve stem mounted on the rim, I'm not certain I see their reason for being. For tubeless, I can see why one might need to change a core if the sealant gums up the valve.
While I had a valve core remover for Schrader valves, the only use for it was to let air out quicker and more completely from larger tires and tubes that would take longer to empty of air to change the tire. My 25 mm tube doesn't need much time to empty.
Just curious. I'm not hating on those with removable presta cores!
On Your Left
Liked 2,433 Times
If you have deep rims then you might need a valve extender and then you move the core from the tube stem to the extender.
Likes For GlennR:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 128 Post(s)
Liked 98 Times
I have one that that came unscrewed when I unscrewed my presta to schrader adapter from the tube. Thread sealant has stopped it from coming back out. The bike shop I bought the tub from warned me it might happen. I guess his last supply of tubes had a few in that had this problem.
Quoted: 313 Post(s)
Liked 682 Times
Continental tubes also have removable valve cores. I've had one or two come loose over the years and slowly leak air. Also had one unscrew while taking off a screw-down pump head.
They're useful if you need to use a valve extender for deeper section wheels. I've got some 40mm stemmed tubes that I pop a 40mm extension on so I can use them with my 60mm deep wheels. Sure I could just buy longer stem tubes I guess....
Quoted: 2281 Post(s)
Liked 1,710 Times
I had a Presta valve core unscrew out when I tried unscrewing the cap to put air in it. That just about made me want to scrap my caps.
Quoted: 2333 Post(s)
Liked 2,097 Times
Schwalbe, Continental, Michelin, Vittoria, Silca, Challenge have removable cores. I carry a core replacement in my bag, it is rare but they go bad.
Likes For GhostRider62:
