Larger cassette for a Trek 1800C
Yes, I still have my original. But now that I'm getting older I can't run with the 12-25T cassette like I used to and I want to add a larger one. The crankset is a triple Ultegra 52-42-30 and the RD is an Ultegra GS 6500/6510 GS Long Cage. I want to add a 34T cassette and believe a Deore CS-M770-9 (five hanger) will work with the Ultegra derailleur. My question of course is, will it work? I know a 27T/28T would and I think a 32T will too, but doing the research online is akin to neuroscience! Now I do have a Deore 9-speed RD-M592-SGS that maybe I could swap out for the Ultegra if I had to and run the M770 that way. Does anyone out there have a similar re-build experience? And no, I do not have the money for a Cannondale CAADX!
Any rational, constructive and measured comments are welcome...and thanks for taking the time.
Quoted: 1956 Post(s)
Liked 2,200 Times
I wouldn’t run your 6501GS with that setup. I’ve pushed max cog 2 for road RD and 4 for mtb RD, if the stock hanger is generous enough.
The other issue is capacity. Ideally you want a 45t capacity. 11-34 = 23 and 52-30 = 22 for a 45t capacity. I’ve pushed it some, but the 6501 GS has a capacity of 37 and 8t is a bit much.
Your 592 would work. I’m more partial to an older 9 speed XT as I think you get a bit better shifting. But finding one usually means eBay and being very careful to find a really good one.
John
John
Freewheel Medic
Quoted: 1470 Post(s)
Liked 2,239 Times
Justin, welcome to C&V. Believe it or not, 9 speed is not quite vintage, yet, but we are a friendly bunch, and we'd never make some snarky comment like, "Why don't you just mount the latest DuraAce Di group?"
In fact, most of us ride a wide range of different bikes so you did come to a place that is helpful. I'm running a Deore RD (don't remember which model but I believe it was for a 9 speed cassette) on an 8 speed HG/UG hybrid cassette and my largest sprocket is 34T with no issues. I am using friction bar-end shifters and not index ones.
Don't forget you will need a longer chain, so purchase a new one at the same time. The chain will need to be shortened to the correct length, which can be critical when riding a wide range cassette with a triple crankset. If you don't have a chain breaker tool, buy one as well. A SRAM or KMC 9 speed chain with the quick link would be my choice.
Let us know how you progress. Again, welcome to our friendly little spot on the internet.
Bob
Bob
Thanks for your response, I really appreciate it!
For Pastor Bob:
My 1800C was built in 2004 and Trek considers it "vintage". I felt this would be the place to start. I'm not sure how the forum feels about double-posts, so here I am.
Yes I bought a longer chain and a new cable set too. I even have a new FD (Sora) if I need it. Now I need a mechanic to try and make it work. I want to get the cassette right or try to find out if I can even do it and that's why I posted here. I'm glad to hear your setup works, good for you.
Liked 2,200 Times
Your shifters will work with any 9 speed Shimano road or mountain rear derailleur.
There “might” be a very slight tweak to the low limit setting on the front derailleur. Probably be fine, but it all depends on the inner cage shape and where the chain is positioned on the 34t.
If you eventually look for an older mtb rear derailleur, you’ll want an SGS long cage.
John
John
[color=#222222]Your shifters will work with any 9 speed Shimano road or mountain rear derailleur. There “might” be a very slight tweak to the low limit setting on the front derailleur. Probably be fine, but it all depends on the inner cage shape and where the chain is positioned on the 34t. If you eventually look for an older mtb rear derailleur, you’ll want an SGS long cage.]
Thank you for all your help, it is much appreciated! I feel confident now my setup with the new cog and derailleur will work.
I agree the Deore is the better way to go, to much for the Ultegra.
I dont think you will ever hear anyone in Classic-Vintage group ever tell you to just go buy a CAADX.. lol
