Difference in chains
I see some members asking about the best chain for their bikes. Is there a difference in quality, life span, materials, etc?
I imagine that most people walk into the LBS and say replace the chain. Will appreciate the info to better educate.
On Your Left
Liked 2,435 Times
First you need the correct type of chain for your drivetrain. Different sped cassettes use different chains, a 9 speed chain will nto fir a 11 speed cassette.
Then there's different levels, generally a more expensive chain will be lighter.
Then there's color, silver/black/gold and others.
Like everything else there are different quality levels of chain. It's also a good item not to skimp on - after all it is the hardest working part of your entire bike, except for the rider!
Likes For PeteHski:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Liked 3,373 Times
But obvious brand names are not always the best guide. Shimano has more name recognition, but KMC are in most cases just as good.
Also, depending on your drive train, you can run SRAM chains on Shimano drive trains and vice versa. AFAIK, this is true for both of their 10 and 11 speed lines. Not so for 12 speed, I believe.
dot dash
Bikes: Shmikes
Liked 6,173 Times
Since chains are a wear item, are easily replaced, vary widely in price, and are made from steel, which can be recycled cheaply, it is not automatically true that the “highest quality” or longest lasting alternative makes the most economic sense. Obviously everyone wants a quiet drivetrain and flawless shifting, but aside from that, I want the chain that costs me the least over time, whether I have to replace it twice or five times.
One of the most extensive chain tests was run by Wippermann. Of course, an in-house test, their chains were on top.
Now, I tested some Wippermann chains a while ago. I need to do more testing, but I started blowing out cassettes after switching to Wippermann. I need to watch that more and try to figure out what apparently happened.
KMC also has "e-bike" chains which I'm not sure made the test.
https://www.youtube.com/watch?v=RGjcD8xEu8o
https://www.youtube.com/watch?v=H4cz-JgbOP4
Method to My Madness
Liked 1,700 Times
Relative hardness? Assuming that you had used the same replacement cassettes, then it seems fairly obvious the Wipperman chains are made from harder grades of stainless steel, which make the chains last longer, but increased the wear on cassettes (and probably chain rings too). While it is not possible to isolate the wear onto the chain alone, I would prefer to replace multiple chains before I have to replace a cassette.
Liked 2,814 Times
I use KMC, SRAM and Shimano HG53 chains, all affordable, not high end. Can't say I notice any difference in performance or durability. I replace 'em about once a year, or every few thousand miles. I don't use a wear gauge or measure them precisely, but after about a year I'll remove the chain and hang it next to a next chain to eyeball the "stretch" from wear. If it's more than a smidge longer than new I'll replace it. I don't think I've ever ridden a chain so long that it caused problems with shifting, etc.
Somewhere around here I have a Dura Ace 10-speed chain, waiting for me to finish putting together a basic TT/tri-bike. We'll see whether it makes any difference.
It's tempting to replace chains more often, because nothing feels or sounds like a brand new chain. It literally feels and sounds like nothing -- silent and smooth. But, nah, too pricey. And I can't say that new chain feel consistently translates to improved performance. The few times a new chain seems to be "faster," I attribute that to enthusiasm over the new chain. IOW, placebo effect.
Advocatus Diaboli
Liked 1,613 Times
Liked 732 Times
dot dash
Bikes: Shmikes
Liked 6,173 Times
Liked 3,046 Times
In theory, higher end chains are made from harder steel. All things being equal, harder steel lasts longer. But it just might be the case that conditions vary more widely than the hardness so the length your chain lasts is luck of the draw with respect to rain and road grit. I've never seen evidence that a better chain lasts longer in real life. I use KMC chains because they're cheap and they seem to work as well as all the others.
Liked 3,307 Times
Shimano tends to ride quieter than other most common brands available at the LBS. I go for the quiet ones.
-YMMV
-YMMV
Advocatus Diaboli
Liked 1,613 Times
https://www.kmcchain.us/X11-Chains_c_60.html
Liked 3,046 Times
I currently have a KMC chain on my bike, but I keep seeing these references that KMC is cheaper. Here's their 11-speed lineup. Their bottom couple models are competitively priced, but really not much different from what eg. the 105 series chains price at. As soon as you're in the $50+ range, you can buy Record or DA chains.
Advocatus Diaboli
Liked 1,613 Times
Liked 3,046 Times
Right. Sometimes they are not less expensive. In that case, the brand is a tossup. I really don't find differences in quality, though I'll buy a name brand. These new Chinese copies with weird names do not tempt me.
Advocatus Diaboli
Liked 1,613 Times
Related to this phenomenon, is the evident increase in chain longevity as each iteration in increased gearing has occurred.
https://cyclingtips.com/2019/12/the-...ciency-tested/
