Installing other chainring brands on Sram Omnium chainset
Quoted: 28 Post(s)
I recently built my first track bike with a used SRAM Omnium crankset, but just realized that it doesn't play well with other brands of chainrings.
Are there any simple solutions for installing other brands of chainring on this crankset?
Get some different bolts? Use spacers?
2k miles from the midwest
Quoted: 525 Post(s)
Liked 932 Times
First I've heard of that problem. Any 144bcd chainring should fit and if it doesn't, it will after 3 minutes with a file.
I swapped an Omnom ring with an Andel. I used the Omnom chainring bolts with no issue. Try using the Omnom bolts and throw in a spacer if need be.
Quoted: 28 Post(s)
Wabi used to sell rings individually on their website. Don't know if they still are with the inventory shortages. I have my perfect gear ratio with my current 46t setup so I won't be upgrading to the Pro any time soon. Though they do sound nice.
Quoted: 2432 Post(s)
Liked 641 Times
They just came out with the Pro crankset, I may have bought the first one and they don't sell rings for it. I think they were talking about maybe looking into getting them.
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
What type of chainring are you using? I've put an aarn and a blackspire on my omnium cranks using the factory chainring bolt with zero issue. Sounds like the ring you are using is thinner.
When i put an aarn on my rotor crankset I needed longer bolts since the rotor bolts were too short.
