Garmin HR Strap Dropouts?
Klaatu..Verata..Necktie?
Quoted: 10644 Post(s)
Liked 12,298 Times
I've been using a Garmin Edge 520, and the associated heart rate strap, for about 3 years now (I think). Recently I've seen the heart rate on the 520 drop down to 85 and just stay there for minutes at a time. It's not my actual heart - I checked. If I adjust the strap it starts working again. I replaced the battery, thinking maybe that was the problem but no, it's done it again - once on the road, and this weekend it did it while I was Zwifting. In the latter case I wasn't even using the Garmin head unit, just an ANT+ stick.
So, my questions: Has this happened to anyone else? And, Does this mean my strap is toast?
Quoted: 2644 Post(s)
Liked 1,998 Times
IME, that sort of thing happens shortly before the strap stops working entirely.
Likes For pdlamb:
Bikes: 2022 Salsa Beargrease, 2020 Seven Evergreen, 2019 Honey Allroads Ti, 2018 Seven Redsky XX, 2017 Trek Boon 7, 2014 Trek 520, 2006 Gary Fisher Montare
Quoted: 697 Post(s)
Liked 911 Times
I’ve found mine stays unrealistically low sometimes. I trim my hair around the area where the contact pads are and it resolves it. I also wet the pads prior to putting the strap on.
Liked 12,298 Times
When it's happened, the last thing I'd have needed to do was wet the pads. That's how I knew my HR wasn't really 85!
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 462 Times
Battery, straps needs a good washing or it life is about over. Not yours.
Quoted: 18883 Post(s)
Liked 10,646 Times
I had a few CooSpo HR straps from Amazon, couldn't tell the difference between them and the Garmin one except by price.
Quoted: 6370 Post(s)
Liked 4,971 Times
Are you sure your HR wasn't really 85 bpm?
I had a one time only 10 or so minutes of my HR dropping to the mid 80's when it should have been better than 130 bpm. During that time I could tell it was my heart as my vision was borderline on going blurry and I was ever so slightly feeling faint.
But I'd agree that when my Garmin soft straps are about to go, they do odd things for awhile till I get tired of messing with them and replace them. Usually last me over four years. My current is about to be six years old. It's had an odd moment or two recently.
Quoted: 842 Post(s)
Liked 1,698 Times
My Garmin HR strap/monitor would do that from day one. It finally quit completely on me after about six months of use. I bought a Wahoo HRM and strap and haven't had any issues since.
Randomhead
Liked 3,802 Times
I think my wahoo tickr is finally dead. I tried the strap off of a chinese strap and got nothing
Liked 12,298 Times
No issues on this weekend's 3 1/2 ride IRL or last night's 1 hour ride ITG(In The Garage), but I figure intermittent problems are how it starts, when the strap is going bad. OH - and not only have I changed the battery but also washed the strap between occurrences. Oh, well. Nothing lasts forever.
Quoted: 4280 Post(s)
Liked 3,006 Times
For mine, replacing the strap (not the sensor, just the strap), often did the trick.
Liked 4,971 Times
Are you looking for one and going to stick with Garmin?
Surprisingly BestBuy use to sell the Garmin straps pretty cheap. However I think my current one was the last one they sold. I haven't seen them there since.
However Bike Tires Direct seems to have almost as good a deal on them as Best Buy use to have.
Likes For Iride01:
Liked 12,298 Times
Now watch - the old one will stop misbehaving.
Liked 12,298 Times
Oh, yeah, the strap is toast. I just did the Zwift Academy Baseline Ride, and it seems highly unlikely that I can put out an average of 821w for 25 seconds and have my HR sit unchanged at 85, or for that matter 270w for 10 minutes while my HR FALLS from 140 to 120. Really buggered the long climb effort, not knowing my HR.
Likes For genejockey:
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 892 Post(s)
Liked 1,248 Times
I just switched from Wahoo Roam to Garmin 830 last Saturday.
1st Garmin ride and saw sensors dropping out.
Went to Garmin forums and it appears that the latest 830 Firmware has dropout issues.
Maybe it's across all the Edge series.
Barry
Barry
Quoted: 1287 Post(s)
Liked 1,417 Times
any resolution to this?
having the same, and gradually worsening, issues with my polar H10 strap and sensor. for a while it would get stuck reading a rhythm which is half the actual, and on today's ride dropped to zero quite a bit. although my HR is low-ish i can confirm it was not 39 while i was climbing a hill nor was it 0 for 10 minutes.
visually it looks fine, i don't see any signs of oxidation or other conductivity issues either on the plasticky (but presumably conductive!) interior surface or the button clips. i'm surprised to read these care instructions:
anyone tried conductive gel? shaving a small area of chest? tightening it? i was very hot and sweaty today, i would have thought conductivity would be high. i usually put a bit of water on it before i wear it.
- Detach the connector from the strap after every use and dry the connector with a soft towel.
- Note that you must detach both sides of the connector from the strap to keep the snaps from oxidizing and the battery from wearing out.
- Clean the connector with a mild soap and water solution when needed. Never use alcohol or any abrasive material (steel, wool or cleaning chemicals). Never put the connector in a washing machine or dryer.
LR÷P=HR
Quoted: 892 Post(s)
Liked 1,248 Times
Gel
LR÷P=HR
Quoted: 892 Post(s)
Liked 1,248 Times
No, but in the benefit column, my neighbors no longer think I rub spit on my [Censored]
Barry
Barry
