2nd Wheelset help
2nd Wheelset help
Hey everyone, i'm kind of new to the drop bar scene. I bought a Kona Rove last year which has 650B x 47 tires and I really love commuting 10k to work on mixed terrain on this bike. On the weekends however I find myself riding with my more efficient road focused friends on some bigger rides.. 50 - 60kms. I'm considering setting up a second set of wheels for this purpose. My frame and fork would accommodate a 700 x XX wheel and think i've found a wheelset that has compatible hub widths and center locking disk brakes. I have 2 questions. 1. Do I need to use the same cassette as i have to avoid derailleur adjustments on wheel swap? 2. Am I missing anything that would make the wheelset not fit my bike? Again I have a 2021 Rove with the Steel frame 650b option. Shifters are Sora. Maybe this is the wrong approach? Maybe i should just get a good used road bike? I just really love riding my Rove and would like to just change wheels as needed. Any advice would be great.
Thanks!
Thanks!
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Just to be clear, you should use a cassette with the same number of cogs (9 speed, 10 speed, etc). And yes, it’d be simplest if you also use a cassette with the same tooth range (e.g., 11-34). That’ll probably be fine for both kinds of riding, especially if your bike has a 2x drivetrain. One would need to know your drivetrain specs to advise further.
For the brakes, the best thing would be to find a 700c wheelset that uses exactly the same hubs as your 650b wheels. Any other hubs might require minor adjustments of the brakes when you swap wheels, if the rotors don’t end up in exactly the same position on the two wheelsets. My instinct is that centerlock vs 6-bolt won’t necessarily matter for this, so if you can’t find identical hubs, it should be fine to get 6-bolt hubs on the 700c wheelset. (Indeed, that might even have advantages, because there are shims available to tweak 6-bolt rotor spacing, e.g., https://bikerumor.com/2015/11/11/jus...otor-shim-kit/)
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
I would get the same cassette. You may need to shim the disk rotors on one of your wheelsets so the calipers do not have to be adjusted every time you switch wheelsets. I have two wheelsets with different hub brands and both wheelsets line up the same for me when mounted (no shims needed).
Thanks everyone. At the risk showing you how little I actually know. How come some wheels say QR or quick release right on the ad. Does that mean they will not work with my through axles that my bike has? Are some hubs not thru axle compatible? Can anyone show me an example of the mid range gravel wheelset that could possibly work?
Thanks.
Thanks.
Originally Posted by Newbie_Canuck;[url=tel:22240618
22240618[/url]]Thanks everyone. At the risk showing you how little I actually know. How come some wheels say QR or quick release right on the ad. Does that mean they will not work with my through axles that my bike has? Are some hubs not thru axle compatible? Can anyone show me an example of the mid range gravel wheelset that could possibly work?
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
Is your Rove a 1x or 2x? If the former, one of the things you are dealing with in riding with your roadie friends is very different gearing, even if the high and low gears are the same. With a 2x, the cassette cogs will have more incremental steps. With a 1x, those steps will be farther apart. What that effectively means is that your friends are keeping their same cadence as they speed up or slow down, and it's always tempting to try and match not just speed, but cadence as well. Riding uneven surfaces like gravel, where an even pace is not such a big deal, this is not so noticeable, but it becomes evident when riding on pavement.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I have a second wheelset on my gravel bike for road riding (winter and commuting). For ease, I have the same ratio cassette. I couldn't be asked to faff around with the B-screw every time I swap the wheelset.
Quoted: 431 Post(s)
Liked 274 Times
Between my four bikes ( 3 gravel one road ) and six wheel sets I had to do very little to next to zero adjustment when all the cassettes where 11-30, 11-32, 11-34. Maybe just dumb luck between my wheels and bikes. When I swapped to a 11-40 cassette on the one gravel wheel set things changed. Had to back the b screw all the way out and make adjustments to the barrel screw. And when I put the road wheel set back on ( 11-30 cassette ) of course I had to re adjust it all again. Too big of jump 11-30 to 11-40 cassette at least for me. I liked have a dual purpose bike more than dedicated dirt bike so I replaced my 11-40 cassette back to 11-34 so my gravel bike can swap between road wheels and gravel wheels.
