Nutrition to keep legs from cramping
Sunshine
Quoted: 11051 Post(s)
Liked 7,599 Times
My legs have threatened to cramp during the last 3 races I have done, and it's been at mile 40 each time.
These are 55-65mi races so the last 15-25mi were ridden without me standing to climb and I end up slowly spinning up hills.
I have yet to actually cramp up, to be clear.
My calves aren't happy, but my quads are straight up angry.
I finish feeling hydrated and full so it isn't a total lack of liquids.
For today's race I had 44oz of water, 24oz of Body Armor, and 20oz of Nuun. Then had some quick food- singer waffles, larger, and larbar.
Also, I dont cramp in any other ride.
So it's back to the drawing board. Not enough electrolytes? Not enough hydration? Too fatigued since I am riding harder and farther without a stop?
Anyone had this issue and resolve it??
I'm sure ill go down a Google rabbit hole on this, but hearing views here is always helpful.
When are you consuming those substances? That matters too.... The key for me to prevent cramping during long workouts is to evenly dispurse the electrolytes throughout, consuming smaller portions many times rather than larger portions fewer times.
Likes For Dr1v3n:
Sunshine
Liked 7,599 Times
I had 24oz of water in the first 20mi, 24oz of Body Armor in the following 15mi, 20oz of Nuun in the next 10mi, then 20oz of water over the last 10mi.
I drank before riding too, obviously. Maybe more sooner?
...or I need to ride with with camelback of picklejuice.
Quoted: 34 Post(s)
Liked 17 Times
You might want to read the 5-part Science of Sport series on Muscle Cramps
Likes For dorkypants:
I had cramps a few times while riding however more of my experience is due to work. I work outdoors and my company constantly reminded all 10k of us to stay hydrated.
I always have. I then transferred 1,100 down south. In the summer I was constantly sweating. With that came cramping. I was constantly drinking water during all waking hours not just work. The cramps weren't horrible while working however 3-4 hours after work was when the bad ones came.
I tried various ratios of sports drink to water, bananas, multi vitamins. The only thing I found to work was protein shakes. Of course these have the protein but also the trace minerals. The lower end Boost brand worked okay but found out after trying various brands that cost wise Kirkland (Costco) or Premier Protien brands worked best and I didn't need to drink 2: 1 late morning and 1 mid afternoon. Muscle Milk worked real well however it's costly.
Certainly biking is different than my situation although an 8 ounce drink may be worth a try.
Quoted: 427 Post(s)
Liked 340 Times
Has pickle juice been helpful? I know many folks that consume it during a ride before cramping signs start. It is pretty effective for many folks but not all apparently. From what I have read the acetic acid is some sort of neurological trigger that can turn off the cramp signals to your muscles. I use it as well and have found it can ease cramp symptoms very quickly, often in less than 5 minutes. At our last race we run probably close to half of the folks on the longer distances had at least one shot of pickle juice at an aid station so it is a pretty popular solution.
Quoted: 1000 Post(s)
Liked 1,677 Times
Hydration
Compression Leggings
Normal Electrolytes (Orange Juice 8oz = 10 Meq)
Combination Calcium Magnesium Zinc daily supplement
Many Sugar substitutes are suspected of causing leg cramps (Aspertame)
Cramps in cold weather respond to warming
More than 2/3s of the general population responds to Quinine Sulfate even in small doses. Try Hylands Leg Cramp tablets and see if they work. Chew two to four at onset of the cramps to see if they get under control. You can do this while ridding. (If you are a cardiac patient and want to take high doses of Quinine Sulfate you need to check with your doctor first.)
Liked 1,677 Times
Also note that a majority of protein supplements contain Aspartame. There is a small percentage of people who are hypersensitive to the artificial sweetener. The side effects are mostly found in those who have migraines and intractable leg cramps. There is of course a continued debate over aspartame as it is long approved by use in the USA. But the Europeans and Australians are extra cautious in its use even though it is approved for general use.
Likes For zandoval:
Quoted: 7089 Post(s)
Liked 11,208 Times
Quoted: 101 Post(s)
Liked 41 Times
I get leg cramps with some frequency when riding hard (races mostly) in the 40+ mile range. I’ve had them running too; but only when I was doing marathons. So for me, onset seems to be only after 2-2.5 hours of intense activity…usually longer. However, I often don’t get them. A few weeks ago I did close to 80 miles on what turned out to be a fairly warm day, and somehow managed without any real cramping.
I wish I could say that I’ve solved the problem, but they still occur despite my best efforts. This year was better than recent ones, so maybe I’m learning.
Here is the extent of everything I’ve learned about cramp avoidance:
When cramps come:
In closing, hope you can find something that works for you…Cramps suck.
- Drink more than normal in the days leading up to a big ride…go easy on (or avoid) alcohol the night before.
- The biggest issue seems to be staying hydrated (including sufficient electrolytes). This is tough because it’s hard to know what your body’s needs are. I will say that I have gotten dehydrated on hot days despite drinking over 100oz of fluid in 50 miles (3-3:30 of riding)
- Before a bike race, I eat something like PB toast with banana, and try to keep 100-200 calories coming in per hour. I think I probably get close to 200 between food items and electrolyte mixes if I’m doing things right, but if I’m doing (say) less than 3 hours I can keep it closer to 100. I seem to have fewer problems with cramping when I keep up on calories.
- Occasional breaks to catch up on eating, drinking, stretching out my legs, etc. There must be some psychological benefit of the resetting of one’s gears, so to speak…on long rides/races that I’ve stopped a lot to help riders or take in scenery, I’ve always performed better.
- Probably obvious, but the easier I ride the less problem they seem to be.
When cramps come:
- Get off the bike. Massage the cramped muscles, walk out the cramp, and try to put it into easy mode for a while. While this is happening, so what you can to try to catch up on any caloric/electrolyte/hydration deficiencies. I’ll get back on the bike and ride as I feel comfortable…usually staying unclipped and walking big hills for the rest of the race
- Pickle juice is okay if available. I bought some shots of it and usually pack one on longer rides…I need to learn more about the mechanics of how it works, but I know there a few theories. I’ve had better luck with Hot Shots (single shots) and Tri-Fuel (sports drink). Both of those products work great to eliminate cramping, but are expensive and not always easy to find.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I concur. In fact, the only times I've ever cramped (usually my calves) has been on hot days -- never on cool rides, even when I've gone farther or climbed more.
My post-ride recovery drink is this stuff, from the fine folks at Martin House Brewing. After a sixer I feel like a new man!
Quoted: 2629 Post(s)
Liked 1,979 Times
My money, if I were betting, would be on the latter. No fun, unwelcome answer, since it'll take a while to get in condition to ride longer and harder, and throwing money at it won't help.
Sunshine
Liked 7,599 Times
- my miles are up this year over prior years and I havent had this sort of cramping in past races.
- the prior incident was a 100k race on the first Saturday of August and I had just ridden 640mi in July. Admittedly, those miles often times had a break halfway thru for regrouping and while they were hard ridden, they werent race effort.
I am guessing it was largely due to not enough riding with race effort leading up to the race.
Jedi Master
My legs have started to cramp up in the last couple of seasons if I ride too fast for too far. I just assumed it was part of getting old.
Likes For kingston:
Liked 1,979 Times
Yeah, that could be the issue, but I sort of wrote it off a bit due to some things-
Likes For pdlamb:
Quoted: 324 Post(s)
Liked 251 Times
I'm glad you brought this up. This has been happening to me as well and I've had more active seasons with longer rides, in hotter conditions, with more effort/less fluids and no cramping. Perhaps my fitness level is not the same, or it's that I am getting older. For a second I even wanted to blame it on Pfizer(just kidding! or am I? Yea, I am!). It's always the last 5 or so miles and at the same spot - lower quads just above the knees.
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
I was getting lots of cramping and found out I had a hyperactive para-thyroid. Had it (one of four) removed and my calcium and other balance of electrolytes significantly improved.
You can buy little 2oz packets or bottles of the stuff to easily take with you on a ride if they don't have it in bulk at aid stations on a supported ride.
Bikes: 1990 Trek 850, 2005 Cannondale R1000, 2019 Cannondale Topstone 105
Quoted: 26 Post(s)
Liked 35 Times
I come from a long line of muscle cramp sufferers. It runs in the family apparently.
Magnesium Bisglycinade supplements have made a huge difference.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2137 Post(s)
Liked 1,651 Times
Have you tried SportLegs? https://www.sportlegs.com/ They flat out work for me.
Quoted: 3057 Post(s)
Liked 1,223 Times
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
I usually mix a good quality salt with my electrolytes, or just add it to my water bottles and drink that. And it does help with muscle cramps/fatigue.
