Hello from central Pennsylvania
Hi! I am new here and I am waiting until I get 10 responses so I can post pictures of my bike. I know it's a Benotto but it has been repainted. It has been my goal all along to share it with you and get your opinions and possible worth.
But...my question today is how to clean my hubs before I repack them. There is brown hardened oil, from sitting for 40 years!!
Thanks
Thanks
Likes For Ruby56:
Liked 2,262 Times
[MENTION=545268]Ruby56[/MENTION] - Welcome! You can post pic in your gallery found in your profile. You need to post 10x not get 10x responses! Just blather on and you will get there in time.
Use low odor mineral spirits to clean. Remove most of the gunk first then use it.
Likes For SJX426:
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Liked 103 Times
You can go to the Introduction forum and introduce yourself and welcome a few people and you will have your 10 posts in no time.
Yeah, getting some solvent of your choice in those hub races and letting it soften up the hardened grease is a good way to go. Then, you can scrape what’s left with a small screwdriver and finish off with some bronze wool.
Likes For nlerner:
Likes For prooney343:
I would shy away from a screwdriver or even bronze wool on any aluminum
Likes For repechage:
Likes For nlerner:
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,654 Times
I use a tiny screwdriver on nasty looking steel hub races. And lots of wd-40. On the outside of the hub, it's more wd-40 and paper towels ... and/or 600-1000 grit paper under a dripping faucet.
verktyg
USAZorro
Lancaster Co. was further east...
When I was young in the 1950's we frequently visited with family friends in Centre County, PA - Rebersburg, Belle Fonte, Centre Hall. My mother's family's name was Reber. Beautiful little towns, great farms in a spectacular area. Great trout fishing too...
I always wondered what it would be like to ride those narrow 2 lane country roads with the roller coaster hills that ran up and down the valleys between the mountains.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Liked 97 Times
Cycling in Eastern and Central PA requires climbing ability. Even in the valleys, one needs to be able to climb.
One of my routes takes me from Fleetwood to Oley, across the Reading Prong - so I need to climb the Prong twice. It's about 600-800 vertical feet, depending on the route.
Another route takes me through the center of East Penn valley. You'd think it would be flat, but it isn't, due to the stream beds that cut across. The hills don't rise as much, but there are more of them.
Inside the races I'll use degreaser, toothpicks and sometimes if it is really bad some steel wool. Be sure to get every bit of it out.
On the shell I'll use degreaser and I find polish on a rag can cut through the brown stuff.
Good luck on the cleanup, [MENTION=545268]Ruby56[/MENTION].
Cycling in PA can be lots of fun and quite beautiful, but yes, bring your climbing legs. I live in the northeast, in the Wyoming Valley.
remove the tires.
outside effort, suitable protection
Cotton rags, a nylon bristle wood brush and lacquer thinner.
one could start more modestly, but one and done.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Liked 217 Times
USAZorro
verktyg
verktyg
Google Maps
Liked 103 Times
We moved to Berks County in 86 from Wisconsin which required me learning how to climb hills. Funny story, we moved here in January and late spring I'm on a spirited club ride where I sat on the front pulling the group through the valley. As we turned to climb out of the valley my lack of climbing skills came to play as I rocked back and forth on the mile long climb. Everyone rode away from me, several minutes one of the fellows came back down the hill thinking I must have flatted! :-)
We now live it the Lancaster County which may have some of the best riding in the country. Tons of little farm-to-market roads to be ridden and a population use to people riding bicycles as it is a standard mode of transportation with the plain Mennonite community.
Likes For Paul J:
Thanks
Thanks
I like old plastic gift cards, popsicle sticks and cheap plastic paint scrapers to remove old gunk.
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
These are a few of my favorite things
I love to use those exact items that you use to remove gunk. Except, I use them to clean bird feeders! Seriously, what do you use to wipe off what's left. Someone suggested mineral spirits.
"paint" thinner was once ok, now not really useful for even cleaning a chain.
There is acetone (and it might be cut with water too)
Lacquer thinner. (in quarts only now)
Denatured alcohol is off the shelves.
I understand, but there are few choices.
way back there was Chevron 325 solvent. obtainable from the Chevron service station, 5 gallon containers.
A useful alternative to solvents is an orange oil type cleaner. Blackjack Tar and Asphalt remover works pretty well, and it is safe to get on hands and such. Once the grease and grime is removed, you can simply wash off the residual oil from the cleaner with regular soap and water. My main tools are plain old rags and q-tips. An old worn out hacksaw blade can be made into a very handy scraper for hardened surfaces like bearing races. Simply grind it to the desired shape.
In California "mineral spirits" is now emasculated. So is paint brush cleaner.
señor miembro
Liked 6,654 Times
Have you tried lemon juice? Mix an ounce of lemon juice with with a dash of chili powder, pinch of gun powder and a quick splash of oven cleaner. Do a shot of tequila and suck a whipped cream canister while that fully immersifies. Brush on the contaminated hub race and smell for effectiveness. Scrub with the rubber from an old shoe. Wipe clean with white cotton briefs and do another shot.
señor miembro
Liked 6,654 Times
