Looking for lwb hardtail
Quoted: 140 Post(s)
Liked 81 Times
I’m enjoying the Rivindell Clem Smith set up with a BBSHD and now thinking about a hardtail for a mid drive.
So far 50% of the riding is hilly off road off trail and 50% dirt road and skid trails. The bike is set up for panniers and eventually a trailer.
I don’t need or want speed but better handling through really lumpy stuff. More utility/trials than bombing sport bike.
Not sure if putting a front shock on a bike not designed for it is a good idea.
I’ve been enjoying long chainstay/wb bikes ever since I got a Surly LHT ten yrs ago. The long bikes I’ve seen are full suspension but they’re obviously racing and downhill speed oriented but that may be my unfamiliarity with fs bikes.
I’m not familiar with fat bikes but the general concept rubs me the wrong way as 27.5 x 2.4 tires are already super comfy. I’m not riding in snow or sand.
Jones LWB e HD bike is under consideration but wonder if a front shock would give me the handling I seek at less cost.
Appreciate any responses.
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
I have a Jones LWB (non-electric) and it is an awesome bike, but I think in your situation I would look for a used hardtail and convert that.
Likes For skookum:
Quoted: 890 Post(s)
Liked 847 Times
Good advice above. Don't know what dimensions you want, but the seatstay on my 1985 Mt Fuji is 17". Sometime not too much later bikes started getting "shorter". Another aspect of the early MTB's was 1" threaded headsets which you may or not prefer. Also, you could locate a steel MTB and have a frame builder extend the rear (I had a dropout on a steel Mongoose break after about 20 years of hard use and had that done. The guy cut the rear ones off and replaced with adjustable - lengthwise - units).
Quoted: 890 Post(s)
Liked 847 Times
BTW, I've ridden mostly rigid for the last 40 years, but lately have discovered that front suspension has reduced shoulder pain from a couple of spills markedly.
Quoted: 12206 Post(s)
Liked 1,501 Times
One of the best bike companies you've never heard of is Gunnar. They are the 'budget' line of Waterford. I have a Gunnar Sport, and it is fantastic.
They make a variety of frames, not sure which would suit you best. But take a look at this one:
Fastlane
Fastlane
Likes For late:
Ride more, eat less
Quoted: 726 Post(s)
Liked 759 Times
Maybe something similar to this? plenty of room to add motor kit/battery.
https://bikepacking.com/bikes/xtracy...W7PGcZOyIu9dS4
Quoted: 890 Post(s)
Liked 847 Times
Or a Surly Big Dummy (might be named after some members). Xtracycle (AFAICR) started business with a kit that converted a "normal" bike into a cargo bike with an extended rear unit, but it wasn't available the last time I looked at their site.
Quoted: 140 Post(s)
Liked 81 Times
Appreciate the responses. I’ve been looking at new entry level hardtails. I’m in a rural part of Tennessee and the used market is Walmart quality for too much or decent quality used for too much money too far away. Folks seem to have a hard time parting with stuff. Had a Kona Ute which kinda soured me on long tails. Thx again.
Ride more, eat less
Quoted: 726 Post(s)
Liked 759 Times
Low budget, probably less expensive to find two used frames and combine into one LWB frame.
As pictured in my previous post, the rear is actually a 20" rear wheel.
Likely take more abuse than a 26" wheel.
Last year, I bought a cargo ebike on Alibaba:
https://www.bikeforums.net/electric-...y-e-bikes.html
I use it to transport large volume/weight of foods in Brooklyn, 100% pavement operation, but at times the pavement in Brooklyn can be as rough as some off-road trails.
The 20 x 4.00 tires were designed more for off-road operation, but certainly provide good amount of suspension for traction, I converted the front end to a different suspension fork and narrower wheel/tire for pavement riding.
The whole project was well under $1.5k, including shipping from China, which seems impossible these days with supply chain/transport situation.
I have little over 2000 miles pedaled on the bike, most of it at PAS level 2 and throttle-only to get going from stop lights.
I get about 50-60 mile per charge on single battery, with a spare battery available to extend the range.
As I wear out the rear tire, I will likely change to a more pavement oriented rear tire.
Age before beauty
I'd look for a Specialized Rockhopper hardtail. They quit making them and so there are a fair number on the market at very reasonable prices. They came with fairly good parts and are very sturdy bikes. It would make a perfect mid-drive eBike.
Quoted: 140 Post(s)
Liked 81 Times
well I went ahead and bought a new Co-op 2.2 hardtail and I don’t think I’ll motorize it. Sure the 2.8 tires and 140 mm front shocks give me the rideability I wanted for the bumpy pot holed field and descents but it’s not an easy cruising bike. It’s a responsive go fast bike and I’m not that guy anymore. Gotta say hydraulic disc brakes and the dropper seatpost are nice although the seatpost is squeaky. Maybe the Jones is it, or the Riv Gus Boots.
