Nashbar Nekkid VS Wabi Classic Which One for Someone New
Nashbar Nekkid VS Wabi Classic Which One For Someone New to SS
The Wabi Classic is $275 the Nashbar Nekkid is $125. They both should fit. I'm using it for around town but would like to try it on slower 11-14 mph group rides of 20-30 miles. Is the Wabi Really going to be that much better?
The Wabi in question...
https://chattanooga.craigslist.org/bik/d/chattanooga-wabi-classic-single-speed/7394066665.html
Don't really like the bullhorn bars.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times
That Wabi only has a front brake. If you are going to ride it with a singlespeed freewheel, you will need to add a rear brake. Also, Wabis are sized center to center, so a 55cm will be equivalent to a 58cm sized center to top. Make sure you stand over the bike before buying.
The Wabi frameset and wheelset are much better quality and lighter than the Nashbar. If you are climbing hills, it is worth the extra cost.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
On the other hand. I want to buy drops. That plus a rear brake means the Wabi is going to cost over $400 all in
Veteran Racer
Liked 766 Times
As to the cost issue, you will need to buy a pair of cone wrenches to adjust the wheel bearings on the Nashbar. Either that, or pay a bike shop to do it. Sometimes, the bearings are too tight from the factory, causing unnecessary drag and wear. Also, the Wabi wheels will be true, but the Nashbar wheels might not be. Do you know how to true your wheels ? If not, more expense at the bike shop.
No, mainly the weight difference.
I think the Wabi would be easier in a resale scenario so I would lean more towards it.
$275 is a great price for it. Wish it were closer to me
Likes For tangent70:
Jedi Master
Looks like the price on the wabi went up to $400. They look like quite different bikes to me. Certainly very different price-points. The Nashbar is probably good enough for how you say you plan to use it.
I'm starting to understand why so many folks on here own so many bikes!
Jedi Master
The Wabi is a better bike. If you're looking for a bike for hills and group rides, a bike with gears will be better than either one.
^that guy^
A Wabi Classic for $275?!? You'd be a fool not to go that route
noticed you said you'd buy the cheaper first then the Wabi if u don't like it... But why? Just buy the better bike at an amazing price.
Well Mama didn't raise no fools! Im really enjoying the cheaper bike so maybe I'll go ahead and buy the Wabi. Worst case scenario is I guess I can sell it for at least what I paid. Although I really don't live the bullhorns, after riding up and down some hills in Chattanooga I can see why they might be helpful.
Steel is Real
Bikes: Wabi Lightning, Wabi Special, Wabi Thunder, Merckx Extra Corsa, Colnago Tecnos, Colnago Super, Cinelli Supercorsa, De Rosa Professional, De Rosa Replica 73, Serotta Colorado iii, Koga Miyata Full Pro, Panasonic RT-3500, Lynskey R320, Time VXRS
Quoted: 22 Post(s)
Liked 21 Times
55cm Classic might be too large for you - especially standover. I'd measure you actual inseam and check how it clears the 32.5" standover.
Yeah I looked up sizing on the website. Good deal or not I think I'm just going to stick with this. I just busted my ass test-riding an old Bianchi ten-speed so I'm done with bike looking. Think I'll just concentrate on bike riding.
Likes For RoadWearier:
Guest
Quoted: 1346 Post(s)
Liked 3,271 Times
With all those spacers under the Wabi’s stem, you can probably lose the Viagra stem angle and still find a comfortable handlebar height. That said, the rear tire clearance at the seat tube looks pretty tight — keep that wheel true and round!
Quoted: 586 Post(s)
Liked 612 Times
Good idea. And maybe after some riding you'll have a better idea of what you ultimately want. A lot of money and time can be wasted looking for something when you really aren't sure what you're supposed to be looking for in the first place.
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone, 2023 Surly Disk Trucker
Quoted: 708 Post(s)
Liked 415 Times
Buy the Wabi. Better quality bike and worth putting more money into over the years. Make sure it fits you, and +1 for adding a rear brake. You won't have buyer's remorse with the Wabi, the Nashbar you probably will.
