Will more reach on a gravel bike make for better descending?
Quoted: 60 Post(s)
Liked 33 Times
First off....I'm sorry the text is huge I don't know what happened.
I’m 6’5" and my gravel bike is a Lynskey GR300 XL with 400mm of reach and a 120mm stem. I found this put me very far forward on steep descents and it’s frankly terrifying at my skill level. As a function of my height too, I feel “on top” of the bike rather than “in it” if that makes sense. It’s fine on the road but gravel has me worried. It has Di2 so I’m not sure what to do about a dropper which I think I need on my next bike.
Given the crazy bike market now, I put it up for sale just to test the waters and I can sell it without losing much. I’m thinking that a different bike with more reach and a dropper might make it a better descender. Mountain bikes have been getting longer…would this translate to gravel bikes?
The new Checkpoint in 61cm has reach of 417 mm (+17mm) and the Canyon Grizl XXL has a reach of 436 mm (+36mm). I’d get a shorter stem to compensate. Both would allow internal droppers which is a must.
Would pushing out the reach and potentially the wheel base help me from feeling too far forward? I’m thinking that and a dropper could be the solution.
Any tips are appreciated!
In defense of the Lynskey, it’s an absolutely beautiful bike and I would wholeheartedly recommend it to someone if they like the geo.
Quoted: 7087 Post(s)
Liked 11,203 Times
I'm not really understanding your question: you state that you feel "very far forward on steep descents," but you're wondering if MORE reach will make you feel safer on descents?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I'd play around with stem length and seat height on your current bike just to test the theory before committing to selling and buying.
Likes For Rolla:
Likes For tyrion:
Quoted: 60 Post(s)
Liked 33 Times
What is the suggested stem length for those frames? Running a dramatically shorter one might introduce other handling characteristics that you may not like.
I've tried different stems on my Lynskey and anything shorter makes me feel to upright and actually causes more hand discomfort.
Guest
Liked 3,270 Times
I wasn't suggesting it as a permanent fix, but just as a means to confirm whether a less forward position makes you feel less sketchy on descents.
Likes For Rolla:
Sunshine
Quoted: 11048 Post(s)
Liked 7,596 Times
I am 6'5 and have a gravel frame with 405mm of reach plus a 100mm stem.
The front center measurement is 635mm.
It'd be nice if Trek or Canypn listed the front center geometry of their bikes. That is the measurement you are asking about.
I dont feel too far over or in front of my bike when descending.
maybe see if you can get the front center measurements for your Lynsky and the bikes you are considering. A longer front center will help push the front wheel out further for sure.
Likes For mstateglfr:
Quoted: 60 Post(s)
Liked 33 Times
Grizl XXL: 662 mm
Lynskey GR300 XL: 650 mm
Checkpoint 61cm: 646 mm
The Grizl also has the longest wheelbase (+11 mm over the Lynskey) Do you think the longer front center and wheel base would make it a better descender? Not sure if these amounts are meaniful in practice. Thanks!!!
Quoted: 427 Post(s)
Liked 340 Times
If you are newer to gravel, before you buy or sell anything have you had a chance to go over riding technique with an experienced rider? Many of us slide our butt back on the seat or even behind the seat on a steep descent to get more weight on the rear wheel for better traction back there and to let the front wheel track better in loose stuff.
I'd also have your fitter double check your seat position to see if you can set it back further.
With your height you may be able to significantly benefit from using a dropper while descending to lower your center if gravity.
Are you on the drops or hoods on these sketchy downhills? I know it goes against what you feel is right in the world but ride in the drops.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Have you considered using bars with a flared drop? Lots of opinions exist on just how much flare is the right amount, but general consensus is that flared bars provide better control.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Yeah, it helps a bit. My bike has a long top tube and a crazy short stem. Humorously, my old school MTB has a 120mm stem, and my gravel bike has a 70mm stem.
With gravel. you can go wide. Easily 2cm wider, but there are some bikes that go crazy wide on bars. Could be the next new fad in gravel.
Likes For chas58:
Quoted: 60 Post(s)
Liked 33 Times
Thanks all for the help. There was a shop relatively near me that had a Cutthroat....I figured it take it for a spin just for hahas. Well, that was a mistake and I bought it. With a longer front center, wide flared drops, slightly more upright position, and a short stem....I think this along with practice will get me where I need to be.
Likes For FrankTuna:
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
+1 for a check on your technique, should be descending in the drops, off the seat, with your weight as far back as you can get it (which is def where a dropper post can help). Some people like wider bars, I run 42cm road bars on my gravel bike, but that's just me. Also, keep a loose grip on the bars, have to let the bike float and guide it more than steer it. Brake with the rear to keep the front from sliding/washing out, a rear slide is much easier to control and recover from. And like anything else, practice, practice, practice. There's a pretty rough descent where I used to live, steep, big rocks and ruts, I was pretty sure I was going to die the first few times I went down it. Then after riding gravel for about a year, I did that descent in a race, and didn't even notice it. Just takes time.
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,540 Times
I don't get too concerned about having a long front-center distance on my gravel bike. Main reason it is a benefit on MTBs is that it prevents going over the bars. I am seldom riding in situations steep and rough enough for that to be an issue on my gravel bike. I guess if you are riding MTB trails on your gravel bike, that might be different, and I guess then I'd want more of a drop bar MTB which is going to have a longer front-center (longer top tube and slacker head angle). Yeah, I know the line between gravel bike and drop-bar mtb is a wide blurry one.
I think getting low is more important than getting back, and I am more likely to start running a dropper than lengthening my front end on my gravel bike.
Likes For Kapusta:
Liked 415 Times
Likes For chas58:
Quoted: 532 Post(s)
Liked 621 Times
Thanks all for the help. There was a shop relatively near me that had a Cutthroat....I figured it take it for a spin just for hahas. Well, that was a mistake the best choice I made all week and I bought it. With a longer front center, wide flared drops, slightly more upright position, and a short stem....I think this along with practice will get me where I need to be.
Likes For Badger6:
On extremely steep descents I like to keep my hands in the drops and lower my ass behind the saddle so that my crotch is pretty close to the rear tire. The upper part of my body is sort of vertical but I'm extending my shoulders forward, my knees extremely bent and I'm basically squatting over the pedals.. This is surprisingly easy to do unless your setup has excessive reach. I run Thunder Burt micro knobbies and they very rarely lose traction in this scenario, but if they did I would simply step off the rear of the bike and grab the seatpost while transitioning to a squatting-sitting position on the ground. Obviously platform pedals make all this possible. I don't like clip-in pedals now.
On descending switchbacks it's also important to keep your center of gravity as low as possible, but you also have to have adequate weight on the front tire. A high handlebar setup won't work. You need substantial bar drop and your hands have to be in the drops. In this scenario I'm typically standing on the pedals with my lower stomach over the saddle, and my ass is hanging way out over the rear wheel. The upper part of my body is flat and parallel to the trail surface at saddle level.
So in my opinion your overall reach should allow you to get behind and lower than the saddle while keeping your hands in the drops. If you can master that squatting behind the saddle maneuver it'll allow you to go down insanely steep trails with a feeling of complete safety and control at very low speed.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 276 Post(s)
Liked 246 Times
When going down on rough, his weight is towards the front rather than well behind the gravity center. As mentioned before, flared drop will help with stability as they offer grater leverage. If you look at gravel flared dropped bar, they tend to ordered more leverage but also less reach to give a more upright position.
Also a quick free mod would be to set the stem in +6deg rather than -6deg, it will give a more upright position for free.
