Water purification?
Water purification?
Do experienced tourers use filtration systems when they are crossing Canada? I don’t love the iodine pills so if filtration is necessary, I’d also be curious if the gravity works systems work.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 683 Post(s)
Liked 770 Times
I carry a purification system on any tour where I'll be able to camp in the wild, and much of Canada fits that. I use AquaMira drops, a two-part chlorine dioxide system that reacts quickly and leaves no taste detectable to me, compared to treated municipal water at least.
bicycle tourist
I came down the Alaska Highway in 2016, went via Banff and crossed into the US in Montana.
On that trip, I started with a pump type water filter. It jammed up and had difficulties and I replaced it instead with a basic Sawyer water filter once I got to Banff. The Sawyer worked well from then on for the next 16 months after that it took to reach Argentina. In general I would catch water in a "dirty" bottle and/or pouch and then let it gravity feed.
In general my approach to filtering water on tours has been:
(a) if other local people drink the water, I will also unless there is an explicit warning; that also includes tap water in Canada and many other places.
(b) when I areas where I get water from streams or other natural sources, I will filter it
(c) I avoid using water treatment pills, particularly for extended periods of time
I also crossed Canada in 1997. Starting in Fairbanks, AK and ending in St John's Newfoundland. I didn't filter any water on that trip and had some limited cases on the Alaska Highway where I used purification tablets.
Likes For mev:
Quoted: 3523 Post(s)
Liked 1,500 Times
I have not crossed the continent, but I can say that I never carried a filter on a bike tour. But, I go out of my way to tour where there are campsites with showers, etc. My Iceland tour, I did not know if I might need to disinfect any water so I bought a Steripen to bring along as a just-in-case way to treat water, but never used it.
That said, I have been filtering water for years when backpacking, canoeing and kayaking. I wrote up a piece on the gravity system I assembled recently. But, you will note that one person that did not understand the importance of backflushing the filter kept blasting the filter, but he was in a small minority, several others concurred that it is a good filter. And I met a LOT of backpackers that swore by that brand of filter. That thread is at:
https://www.bikeforums.net/touring/1...-system-3.html
If you are not used to cobbling together bits and pieces that were bought at different stores into a single system, you might be better off buying a complete gravity system instead of assembling one like I did. But I read that some people that bought Sawyer brand bladders had them fail, so if you get a Sawyer gravity system, it might be a good idea to also get another brand of bladder as a backup that has compatible threads.
Likes For Tourist in MSN:
Bikes: 2014 Avanti Circa (Rd Dist), 2020 Giant Toughroad (Rd Tour), 2021 Trek Allant+ 8S (eCommute), 2021 Scott Aspect 940 (Mt HT), 2014 Santa Cruz Superlight 29er (Mt FS), 2022 Scott Spark 960 (Mt FS)
Quoted: 35 Post(s)
Liked 52 Times
My girlfriend has tramped over 1500mi with the Sawyer setup with a dirty water roll up bottle pushing filtered water into a clean roll up bottle - no problems with it at all.
The only thing she modified was setting up the system to be gravity fed, hung from a tree, then she could do something else while the water was being filtered.
Although the Sawyer should work with a number of water bottles, the Platypus bottles seemed to give her some trouble, so I'm inclined to stick with the Sawyer roll up bottle for the dirty bottle...
Never cared for chemical purification, have used filtration systems for the past 30 yrs. The great thing is, is that they keep getting smaller, lighter and better at filtering. Presently using the Sawyer
Likes For MarcusT:
Likes For Jno:
Quoted: 2333 Post(s)
Liked 2,097 Times
Likes For GhostRider62:
I have had good luck with Sawyer filters, both the Squeeze and the Mini. The dirty water bags used to get lots of complaints and required some care in squeezing. These days I don't hear many new complaints about that. Maybe the bags are better now, maybe folks learned to handle them, Maybe they just use other bags or gravity, or maybe I stopped listening. Any way, if in doubt, take some care with the squeeze bag or use something different. If going with gravity I doubt it would ever be a problem.
FWIW, I bought a one gallon Sawyer Gravity filter setup to stick in our emergency "go bag". The setup claims to weigh 8 ounces. I have not checked if the 8 ounces includes the weight of the cleaning syringe and associated coupling. The setup looks well thought out and durable.
I use one when backpacking or canoeing, but I typically don't use a filter when touring with only a few exceptions. I enjoyed having one in the heat of one trip in the Sierras mostly because it was nice to filter ice cold mountain stream water and have a near freezing drink on a 100F afternoon. The other time was when going off road touring and drinking water from lakes, streams, or other surface water.
I have had good luck with both, but yeah, probably worth a few extra ounces if depending on it for much of your water. If it will be light and or ocasional usage the Mini may still make sense for the more weight obsessed. Speed isn't such a big deal most of the time if using gravity since you can walk away from it and do something else. I am pretty obsessive about the ounces so I have opted for the mini pretty often for shorter trips or where filtering will be sporatic. I have both and choose depending on the trip.
Liked 2,097 Times
It is one oz difference between a Mini and a Squeeze. Plenty of people have had trouble with the Mini.
Also, don't let the membrane freeze, bring it into your sleeping bag.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 354 Post(s)
Liked 186 Times
I like the Grayl water filters. I've used mine for international travel as well as on two 1+ week tours on GDMBR. One of my touring partners on GDMBR had a Sawyer system and started borrowing my Grayl at water stops after seeing how easy it was to use. It also served as an extra water bottle. Most complaints seem to relate to the fact it does take some force but I don't find that to be a problem and I'm no he-man. I'm still on my first filter but now see that maybe it is due for replacement because of age. The ultra compact is on clearance at REI. I might buy another. It was recommended to me in Cambodia by an Australian who used his while trekking in Nepal.
Miles to Go
I use the Sawyer Squeeze, but one that has become the filter of choice with many backpackers is the Katadyn BeFree. If I didn't already own the Sawyer, I would get the BeFree. Lots of reviews and comparisons between the two out there.
Bikes: Custom built LHT & Troll
Quoted: 877 Post(s)
Liked 156 Times
The beFree is indeed very easy to use - screw on the Hydrapak and drink from it. Or press on the bladder to pour filtered water in your kettle. Water flow is excellent.
My experience is limited to a 3 days, 3 persons trip in the Rockies. Never had to rely on it while riding across Canada.
I carry an MSR pump and it has worked fine the few times I have used it. I have carried it a lot more than I have used it. Also used tablets which seemed to work fine, but need to be replaced every year because they seem to imbibe water from the air. Did the C&O last September and kind of got used to the iodine taste.
Quoted: 612 Post(s)
Liked 292 Times
When touring I always carry with me a few of the newer purification tablets that don't taste nearly as poor as the older iodine tabs. But in all my years touring, I've only used them one time, and that was when I was so far away from humanity and was facing the possibility of dehydration.......of course immediately thereafter and just around the bend, I come upon a gas station.....Doh!
Katadyn Befree, i think the name is. Flow-through is much faster than Sawyer. In Japan we often find pipes in the mountains/parks/shrines spewing mountain water. We assume it's drinkable but there is rarely a sign saying so. We can filter to fill a two litre bottle in less than a minute.
A good write up from some folks who did a lengthly comparison of how each will fare in real world extended usage conditions is at https://hikinghammonds.com/2019/10/0...tadyn-be-free/ They give a pretty good summary of the pluses and minuses of both. They did find some issues with slowdown after longer usage with the BeFree that most reviews don't mention. Perhaps they just had bad luck with theirs, but it seems more likely that mosts tests are not side by side comparisons with long term usage in real world conditions.
Our Katadyn BeFree: when it's been in storage for many months, we first fill it with water and hang it upside-down over night. This clears the filter and then it works just like the first day we bought it. It was the trickle of the Sawyer I saw in reviews that made us go for the BeFree and I have to say we have zero problems using the above mentioned procedure.
To be really confident about the potability of water, the recommendation is filtration and chlorine, or iodine. Or, boiling.
None of these will eliminate toxins and carcinogens. It is a wonder we're still alive.
