Hirame Pump Head
senior member
Hirame Pump Head
Just watched a brief video demonstrating this pump head - my takeaway was nearly no air loss at the point of disengagement with the valve but also there's minimal push down when attaching and then using the red nut and quick release type lever - is that enough justification to entice you to cut the head off an otherwise good pump and replace it with Hirame ?
What say you all ??
What say you all ??
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 4209 Post(s)
Liked 3,875 Times
I'm all for having a head you enjoy, working with that is. Andy (who likes the Topeak replacement head options)
AndrewRStewart
AndrewRStewart
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I use pneumatic couplers and swap the heads faster than I can type this.
You should just get it if you want it, but Id argue 99% of the perceived air loss when disengaging a normal pump head is from the hose, not the valve, - unless of course its a particularly inept design.
Likes For Racing Dan:
senior member
Quoted: 840 Post(s)
Liked 336 Times
Well, you look at the availability of suitable parts no matter what their original purpose was. Another place where you could source pneumatic couplers for tube sizes of interest were dental instrument suppliers .
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
Silca also makes a very similar lever action chuck which is excellent and similar priced.
HIRO Side-Lever Locking Presta Chuck- Carbon Steel – SILCA
senior member
Liked 1,096 Times
senior member
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
It's not exactly the same mechanism. The silca is similar to the Hirame - I have both on different pumps.
they both work about the same, which is really positive engagement and disconnect.
yes, the Silca does thread onto to a hose barb, where the hirame goes directly into the hose and secures with a clamp.
However - the replaceable rubber collar for the Hirame is real hard to get, and that is a wear part. I got 3 when I was last in Japan and they wear at the rate of 1 every couple years.
the Silca collar is readily available from Silca.
I'd say it a tossup, I'd give a slight preference to the Silca.
/markp
/markp
senior member
AFAIK, it's exactly the same mechanism as the Hirame head with Silca's name. The only difference I can see is the Silca attaches to a Schrader tire chuck while the Hirame attaches directly to the pump hose via a hose barb. Unless you are switching between Schrader and Presta valves routinely, the Hirame has a better connection.
Liked 1,096 Times
https://www.tracksupermarket.com/sta...s-3x-pack.html
Quoted: 840 Post(s)
Liked 336 Times
So here is the Hirame head/Zefal Christmas tree. I kept the Schrader Zefal head too as it was reasonable. Happy Season's Greetings!
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
what's hooked up to what there ? I see hoses, pump ends etc. Wait, I get it, that's a setup for pumping up both tires at the same time
very clever !
/markp
very clever !
/markp
Likes For mpetry912:
senior member
The Zefal frame pump was common years ago , probably Silca as well - looks like Silca has a strong web sales presence today but not so much with Zefal .
Quoted: 840 Post(s)
Liked 336 Times
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
Both are great, I prefer the Hirame, but only by a fraction. I bought three rubber washers when I got the Hirame, I expect them to outlast the user. As I said in the other recent thread, I wish I'd bought one twenty years ago.
Further, to me, the chuck is what makes the pump. A great chuck will make any pump a pleasure to use, but a chuck that is a chore to use will make any pump seem mediocre.
Good luck.
Quoted: 569 Post(s)
Liked 584 Times
I have found an infrequent tiny application of o-ring lube has made my Hirame gasket everlasting.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
Thanks again HillRider , sounds like you have a good pump with formerly a crummy head - my situation is different , it's a strain to achieve 100psi so rather than rebuild the pump I'm thinking of getting a new one - Topeak has a good selection but the Silca pumps look great and probably come with a good head since they also carry the Hiro as an option - my valves will always be Presta .
Quoted: 257 Post(s)
Liked 252 Times
2. it is relatively low volume so takes a good number of strokes,
3. the gauge is hard to read because it is small, low, and the black on red for psi doesn't do it for me. That said, no regrets.
Clank!
Excuse me, my Silca is calling...
