Max seatpost height
Max seatpost height
How serious do we take the max line on seatposts? It’s just a touch over the line, but the bottom of the post is right at the bottom of the seat lug cluster.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/9ab96644_f5be_4a90_9ca3_fb5c13ae03f9_77d7d4521618b8e39955c8a83b63239a502ed7e7.jpeg)
2019 Salsa Warbird
2019 Salsa Warbird
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,648 Times
The marking doesn't mean much to me. I pay more attention to how much seatpost is below the bottom of the seat lug.
señor miembro
Liked 6,648 Times
The answer might depend on how much is above the seat lug. My tallest seat post is 12cm above the lug. I'd like at least 1.5cm below the lug for that one ... maybe 2cm.
The shortest one is just 10cm above the lug. For it, I'm comfortable with its bottom at 0.5cm below the lug.
I'm only 155 lbs and ride pretty light in the saddle.
Bike Butcher of Portland
Bikes: It's complicated.
Liked 5,996 Times
Just get a longer seatpost. Giving advice to say it's ok to be above the line just doesn't seem like a responsible thing to do.
Likes For gugie:
Likes For P!N20:
Bikes: Yes
Liked 4,094 Times
I think a read somewhere that you should have a length the diameter of the seat tube below the bottom of the top tube.
My Bikes
My Bikes
Likes For Andy_K:
Liked 1,362 Times
Do ya think that when they decided to put the minimum insertion line on the seat post they said "well, it's safe to put the seat post in to here, but heck, let's put the minimum insertion line up there just to mess with them"?
Likes For davester:
Likes For P!N20:
Liked 4,071 Times
Two questions. How much is this frame worth to you and what is the seat tube wall thickness.
Basic engineering - your post is trying to rock around the top of the seat lug when you hit a bump. The very end of the seatpost is doing most of the work to hold in in place. The (simplified) load at that end is what you are doing to your seat X the distance, top of seat lug to seat top / the distance, top of seat lug to bottom of seatpost. So, if you have twice as much seatpost buried, the force the end will see will be half. Why does this matter? Because that force is directly against the seat tube wall. Too high and the tube bulges. Probably not catastrophic and if your frame is built like a tank, probably will not happen. But if this is a sweet Columbus SP (say) frame, that bulge would be a deal breaker to a potential buyer and something you see every time you look at the bike.
Honestly, yes, I guarantee you they said “Here is good enough, but let’s move it up a half cm just to be safe.” The seatpost isn’t the issue here, it’s the frame.
2019 Salsa Warbird
2019 Salsa Warbird
working on my sandal tan
Liked 2,579 Times
Seatposts and stems (and everything else on a bike) aren't omniscient -- the manufacturer had to take a reasonable stab at how much length would be enough to keep from damaging the part or most frames in use.
Those of us who like to work it out for ourselves will want the seatpost to extend completely below the junction with the top tube, and having one seatpost diameter beyond that should be plenty. Some frames have a fair amount of seat tube extension above the top tube, so IMO it's good to think about this even if you weren't trying to cut anything close!
2019 Salsa Warbird
2019 Salsa Warbird
Liked 929 Times
I like to have two inches below the top of a seatlug like yours. Ona bike with more seattube above the toptube I want two inches of seatpost below the top of the toptube.
I seen bicycles that had broken seatubes above the toptube because the seatpost was too high and acted as a big lever until t he seattube finally failed.
Cheers
Cheers
verktyg
Rule of thumb for both seatposts and stems: Minimum insertion depth 75mm to 80mm (around 3")...
You don't want to be a "hey, watch this" kinda guy do you?
verktyg
verktyg
![50+](images/smilies/old.gif)
Chas. ;-)
Chas. ;-)
Edumacator
Liked 3,374 Times
Save that post for a high collar Cannondale and watch the insertion mark disappear under the rim of the seat tube! Safe!
i have one if you need it...
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
As to the question I'm with the get-a-longer-one camp.
Not lost wanderer.
My Touch is a whole lot lower than yours. That looks like 1/2 inch or more, a touch would be 1/8 or so.
Have to agree, I thought the line was lower when looking at it in my dimly lit garage. Longer post it is.
2019 Salsa Warbird
2019 Salsa Warbird
Edumacator
Liked 3,374 Times
That seatpost needs a nice Cannondale to partner with it...
Bikes: Yes
Liked 4,094 Times
I'm not convinced the Cannondale high collar really helps much. The pivot point is still the top tube. I think the high collar just offers a false sense of security. Or takes away the manufacturers "room for error" if you prefer.
I'm picturing the forces kind of like this:
![](https://ak.picdn.net/offset/photos/592da60717fb156e48061c10/large_w/offset_572504.jpg)
And the collar above the top tube would be like having another kid on the other side of the see saw trying to hold it up from the bottom.
My Bikes
My Bikes
Likes For Andy_K:
Liked 2,257 Times
The Colnago is on the small side with keeping the components consistent, hence the Camp seat post. The saddle is a bit too short but.....I used a Brooks Pro that gives a little more leeway with the post insertion due to its higher rail to sit height. I feel I am at the absolute max with this arrangement. The line is 55mm from the end of the post.
P1030606 on Flickr
This is the shorter version of the post. I am sure the longer version is a needle in a haystack.
![](https://live.staticflickr.com/65535/50165445528_c15cc3641a_b.jpg)
