Opinions Wanted
Opinions Wanted
Old 01-15-22, 05:38 PM
lhill
lhill's Avatar
Bikes: ‘90ish Peugeot Triathlon and Specialized Alibi Hybrid
Quoted: 52 Post(s)
Liked 26 Times in 15 Posts
Opinions Wanted
I have been looking at ebike conversions for either my hybrid or vintage steel road bike. I would like your learned opinion on whether or not you think I could safely mount a small front hub motor on my old Peugeot or are the front forks too weak to handle the stress. Thanks!
lhill is offline
Old 01-15-22, 06:37 PM
surveyor6
surveyor6's Avatar
Bikes: 1961 Higgins Flightliner
Quoted: 68 Post(s)
Liked 101 Times in 70 Posts
I think your good ole steel peugeot fork would easily handle a 24v 250w hub motor. I would get a rear wheel for anything more powerful than that.
surveyor6 is offline
Old 01-15-22, 08:46 PM
kahn
Quoted: 383 Post(s)
Liked 690 Times in 396 Posts
You could inquire with the following shop. They converted my bike to front hub. I will add that a front hub does change the handling dynamics of the bike and made it more twitchy. They sell the kits or do the conversion.
https://www.bikeswift.com/
kahn is offline
Old 01-16-22, 08:58 AM
lhill
lhill's Avatar
Quoted: 52 Post(s)
Thank you both for your help! I will continue researching the systems and who knows….
lhill is offline
Old 01-16-22, 03:46 PM
lhill
lhill's Avatar
Quoted: 52 Post(s)
Another question, when the max speed is given for a mid-drive system, like 25kph for example, how does the system know what gear you’re in and what your actual mph is? Thanks!
lhill is offline
Old 01-16-22, 04:26 PM
kayakindude
Bikes: 1987 Cannondale SR600/BioPace, 1991 Cannondale Road Tandem,1994 Giant Iguana MB, 2009 Airnimal Chameleon, 2016 Dahon Vybe C7A
Quoted: 123 Post(s)
Liked 102 Times in 65 Posts
How much assist are you looking for? I think the motor/system can be tailored to the that answer. If it's just hill assist or extension of range without comprising the handling then 250 should do it. Also don't worry too much about the handling, whatever change it may have you will adapt to in short order. I have folders, tandems, road, and mountain...no issue switching between the styles.
kayakindude is offline
Old 01-16-22, 06:19 PM
lhill
lhill's Avatar
Quoted: 52 Post(s)
Thanks kayakindude, I was just trying to understand how a mid motor works. The motor just spins the cranks without regard to what rear cog the chain is on, correct? If the motor spins the cranks at 90 rpm with the bike in 4th gear than we’d be moving right along. But if the bike is in 8th gear at 90 rpm we’d really be flying. So, how does a Class 1 motor limit bike speed to 20 mph? How does it know?🤔
lhill is offline
Old 01-16-22, 06:25 PM
2old
Quoted: 899 Post(s)
Liked 864 Times in 653 Posts
The speed specified for a mid is that at which it stops providing assistance. You can go faster, but you're on your own.
2old is offline
Old 01-16-22, 07:22 PM
andychrist
Devil's Advocate
andychrist's Avatar
Bikes: Fuji Del Rey, Bacchetta Giro 20, RANS Stratus XP XL, RANS Stratus XP XXL, RANS Stratus LE XL
Quoted: 77 Post(s)
Liked 50 Times in 38 Posts
You program the display with your bike’s wheel size, just as you’d do with any bike computer. Hub motors have built-in speedometers but mid drives utilize a remote speed sensor.
andychrist is offline
Old 01-16-22, 09:08 PM
lhill
lhill's Avatar
Quoted: 52 Post(s)
Thanks all for your helping me understand about ebike systems!
lhill is offline
