Cable stops clicking when turning
Hey guys - setting up a new bike and am getting this clicking because cable stops jumping out of their slot when doing a 90 deg turn. This is the rear brake cable with cable full outers all the way to the back.
See video below here - imgur.com/a/tVOr3fW
Any tips on fixing this?
Can't see the video but it sounds as if the housing is too short. FWIW, you won't intentionally be turning the bar/wheel 90 degrees.
Likes For shelbyfv:
I haven't cut housing yet and have tried giving more slack at front but doesn't help. This is compressionless jagwire so doesn't bend easily. Yep understand on non-90 deg turns - thought someone had found some little fix I don't know about.
Likes For veqra21:
Droid on a mission
Liked 317 Times
^^^^^ What he said
Constant tinkerer
I'd recommend regular brake housing instead of the stiff compressionless stuff, but that might make the rear brake too spongy, because, you know, full-length housing... Maybe you know this and that's why you're using it.
Unfortunately there's not a good solution here. Just do your best and make sure the housing is in a good position when the bars are straight. On some of these frames you can't turn the handlebars 90 degrees without kinking something.
