Derailleur Wobble/Chain Ring and Cassette Wear
Bikes: 2023 S-Works Tarmac SL7 Dura-Ace Di2, 2022 Cervelo Caledonia-5 SRAM Rival etap AXS, 2019 Specialized Sirrus Elite Alloy, 1977 Schwinn Super LeTour 12.2, 85 Bianchi Limited Shimano New 600EX
Quoted: 25 Post(s)
Liked 50 Times
I'm working on a restoration of an '85 Bianchi Limited with Shimano New 600EX components. It's been in storage 30 years or so.
The RD cage is wobbly which causes the pulleys to be misaligned with the cogs. Is this type of wear repairable? I haven't disassembled the component yet.
I've also attached pics of the chain ring and cassette. Can anyone comment on the condition?
Took the bike out for the first ride after reassembly. Under heavy load, there is some chain slip. I'm not sure if this is related to wear on the cogs or the RD alignment.
I installed a new chain, and I believe I have the chain length correct.
Thank you.
Thank you.
Constant tinkerer
Freewheel/cassette wear is difficult to evaluate, but a new chain will "skip" across worn teeth.
Your rear derailer pulleys are quite misaligned with the cassette. The hanger and/or derailer itself is bent. Start by straightening the hanger.
Likes For FastJake:
Quoted: 25 Post(s)
Liked 50 Times
I think the misalignment is caused by the play in the connection between the cage and body. Here's a photo of me manually holding the cage in alignment.
SE Wis
Quoted: 2754 Post(s)
Liked 3,421 Times
Likes For dedhed:
Quoted: 25 Post(s)
Liked 50 Times
Likes For phughes:
SE Wis
Liked 3,421 Times
Another method to align without a hanger alignment tool.
Likes For dedhed:
Quoted: 25 Post(s)
Liked 50 Times
Thanks to you that helped out. As a newbie to bike mechanics, it's nice to have a place to run to when help is needed.
I ended up rebuilding the derailleur and while I was at it, I figured I'd give it a little polish. It's now missing the branding, but looks a bit better.
I did my best to get the hanger straight. Having already cleaned up the threads with a tap and die, I didn't want to risk further unreversible damage.
Before Pic:
Before Pic:
Likes For Bici Veloce:
Expired Member
Quoted: 3780 Post(s)
Liked 5,752 Times
That ferrule is wrong.
Quoted: 25 Post(s)
Liked 50 Times
Expired Member
Liked 5,752 Times
I think that cable stop is designed for pre-index shifting, the housing just fits directly into the stop w/o a ferrule. If you are using indexed shifting, I think you can get "step down" ferrules. Larger at the housing end, smaller at the other end to fit inside the cable stop..
Likes For shelbyfv:
Quoted: 25 Post(s)
Liked 50 Times
I looked at some photos prior to disassembly and I see that I installed the cable housing backwards. I also found the original ferrule that attached to the frame side in my parts bin. I'll work on it after a test ride.
Quoted: 25 Post(s)
Liked 50 Times
Expired Member
Liked 5,752 Times
Looks right! That derailleur turned out well, big improvement.
Quoted: 25 Post(s)
Liked 50 Times
