SRAM Force eTap AXS FD chain drop
Quoted: 4560 Post(s)
Liked 5,083 Times
Sooo.... I'm wondering when I can expect this to start happening on my new bike? Everything I've read on the internet strongly suggests that SRAM eTap AXS front mechs are garbage, guaranteed to drop the chain on every ride. Now it's very early days for me, but it's not happening yet. Front shifting is actually very smooth both up and down. Not even the slightest hint of throwing the chain off in either direction. Am I being lulled into a false sense of security or is it just the usual internet amplification of problems? Or have SRAM sorted out previous issues through hardware or firmware tweaks? So far I'm impressed with it. It's not even noisy like they are supposed to be!
Quoted: 2333 Post(s)
Liked 2,097 Times
I have never dropped a chain with SRAM AXS FD using 53-39 crank. Very rarely dropped with 11 Speed eTap but I was also shifting 56 down to a 39 with a very old crank. The 10 year old mechanical 11 speed SRAM FD was less good for sure.
My AXS upright bike is currently 1 X with 48T and no problems.
Quoted: 4008 Post(s)
Liked 7,505 Times
Liked 5,083 Times
Likes For PeteHski:
Liked 5,083 Times
Liked 2,097 Times
That should be less a challenge. I noted my chainrings to show even using non-recommended rings, the AXS and eTap handled it.
I still have the old mechanical 11 speed on two bikes, the FD is just ok. The newer ones are better. I was using barcon to shift a Shimano ultegra in place of the old SRAM FD at one point but eventually just lived with just fair front FD shifting, the newer stuff is def much better. Is it as good as Shimano? I do not know
Liked 5,083 Times
Thread Killer
Quoted: 3214 Post(s)
Liked 1,752 Times
I’m running 48/35 SRAM under the Force AXS Wide FD on my rig and have never had chain drop. I guess with the proliferation of 1x, I should add that I actually use the thing, too. I can clean a lot of my local terrain with the 10-33 cassette x 48t, but there are definitely some climbs that go by better in the 35t, so yeah, I shift gears.
Likes For chaadster:
The most common problem is improper FD setup. It's easy to set the alignment marks parallel to the big ring, then fail to notice that the FD rotated a bit when the clamp bolt was fully tightened. Sram shifting ramps may not be the best either. I check the space between the FD cage and crankarm accurately, before and after tightening the clamp bolt.
Quoted: 7088 Post(s)
Liked 11,207 Times
Quoted: 1139 Post(s)
Liked 1,238 Times
Between my wife's bike and mine, we've ridden probably 2,000 miles and no problems. So my guess is that OP will experience the issue exactly on...never.
That AXS FD is easier to set up than most: the marks on the FD cage greatly assist in alignment IMHO. I tried the plastic installation jig, but found it was easier to do it the old way of setting the alignment (with the marks) and the clearance with some sort of feeler, or even eyeball.
I do like the Force Etap AXS Wide HRD group. It was a splurge for this Senior Citizen thinking "if not now, when?" and it's fun. Comfortable hoods, easy installation, lots of lever adjustment available. Not enough to swap over my other bikes because they're perfect too.
Likes For Camilo:
Thread Killer
Liked 1,752 Times
I have the same setup as well as two bikes with mechanical 10 speed - one Red, one Force. I must have deficient sensors, but all of my Sram FD's have always shifted perfectly. My Shimano mechanical FDs have always done the same too. Shift the button or lever, and before you can say "uh" it shifts and doesn't drop.
The interesting thing about my Wide FD setup is that I’m not using the Wide crankset, but it still works fine. I think maybe it’s not as fast as it would be in a properly matched system, probably because of the longer derailleur throw, but it”s one touch effortless, so it’s nice.
Liked 5,083 Times
So it looks like I don't need to worry too much then. After reading a few SRAM AXS horror stories (especially Force) I honestly thought it was going to be a pain to set up and that chain drop was almost inevitable, lol. I now get the impression issues are blown out of proportion and then fuelled by Shimano diehards. Can't say I"ve had any issues with either brand over the years. My other road bike has 105 R7000 and that works flawlessly too. My last 2 mtbs had mechanical SRAM X01, which has been great too. I have to say my first impression of electronic shifting is excellent. Even better than I expected.
Now I just need to get past Thursday pm....
Liked 5,083 Times
Yes I thought so too. Mine was factory built by Canyon and alignment was spot on when I checked. Only fine adjustment I made was to close down the chain gaps on both sides of the front cage to the 0.5 mm limit as recommended by SRAM. Shifting was perfect in the stand and on my first 25 km road test. Didn't need to trim the rear mech either. So far so good.
Liked 5,083 Times
Likes For PeteHski:
Liked 1,238 Times
Yea, same here. The limits are set like any other FD, so I just can't see there's anything special about avoiding chain drop. That said, I do have a chain catcher on my carbon fiber frame - but it came integral to the FD. I have no shame using a chain catcher on a CF frame even though I fancy myself an excellent FD adjuster. I don't do it on a metal frame though.
Liked 5,083 Times
Quoted: 8 Post(s)
I’ve had trouble
I’ve had significant trouble with sram force axs chain drop. It happens randomly. I have had it set up by three different mechanics. We have shorted the chain, set the limits very tight and I have a chain catcher. The only solution seems to be to upgrade the force front chain ring to a red front chain ring ( interestingly the new sram force front chain ring is one piece of metal just like the red front chain ring) seems like there is too much flex in the original force chainring and it sometimes throws the chain off
Quoted: 8 Post(s)
I’ve had trouble
Liked 1,238 Times
Quoted: 8 Post(s)
i don’t think it’s inability to adjust the FD. Three different mechanics have done mine from different shops. Two other guys I ride with that have sram force axs and use different mechanics to mine also have chain drop issues. If it’s that hard for bike shops to set up then it’s a bad product. I think it’s the chain ring as sram just brought out the next generation of force and it no longer has a two piece front chain ring. It now has a one piece front chain ring just like the red front chain ring. It has been a maddening problem for me for two years.
Liked 5,083 Times
ignominious poltroon
Quoted: 2280 Post(s)
Liked 3,503 Times
This is why SRAM vigorously advocates for 1X drivetrains.
Thankfully, they don't take a similar approach with their brakes.
