Pump for traveling
Pump for traveling
I am looking for yet another pump - I don't know how many I have in the garage - but most should be in the trash. I have only been on a few small 4-5 day trips, and planning to increase those quite a bit for the next 5 years, and then hit the road on some bigger tours when I retire. Right now my main pump on the road with my LHT is an older zefal frame pump - it looks cool and works ok - I just hate not having the flexibility of a hose, and would like a guage to top off tires every morning. A dual nozzle would be preferable - but really only have presta on bike - so could get a cheaper dual pump for around home. I'm not really looking for top of the line - but would prefer to pay a little more for higher quality. Any suggestions? TIA
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Liked 91 Times
i either carry a Lezyne Micro Floor Drive or Pocket Drive depending on weight and distance. they're both over 10 years old and still work terrific
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/768x768/lezynemicro_floor_drive_6853d16e1aaf38f0839f5dede6bee0ed20babe26.jpg)
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/400x1760/lezyne_pocket_drive_a1a65b7a21eecfe31e50e5e0a2716f85fe56eeb5.jpg)
Mad bike riding scientist
Liked 4,338 Times
Topeak Morph. Road if your tires are less than 1.5” and mountain if the tires are wider than that.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 1,721 Times
Lezyne Pocket Drive or just stay with your Zefal Frame pump...
Bikes: 2013 Custom SA5w / Rohloff Tourster
Liked 342 Times
I really like my Bontrager mini floor pump. It has a clamp head and a comfy handle. I only have mid size tires.
My Axiom Enforcer HV is a really good pump too, with a screw on head. The threads wore out on my last tour, then had trouble finding one I liked. Ended up cutting the same type head off another broken pump. I spliced the hose in the middle, so a nice LONG hose now. LOL.
So I have 2 good floor pumps and 2 crappy ones that aren't floor type. They are horribly tiring and won't go much over 70 lbs.
They all need over a hundred strokes from empty, you know.
built and reasonably light. Had them for many years and use them regularly.
Likes For jvt:
Looking at both the topeak mini floor and topeak road morph- they have similar gauges - with hit and miss reviews as the gauge is not extremely accurate, and a potential point of failure. Is it worth it to get one with an in-line gauge, or just get a cheap gauge to keep keep on hand.
Generally it is hard enough to get tires to the proper pressure that I am unlikely to overinflate them without knowing it and if I underinflate them significantly it will be fairly obvious. Also I do sometimes vary the pressure a bit based on the road surfaces where I am. This is more by feel than by knowledge of what the specific pressure should be there. Ror example, I let some air out for the texas chipseal which was especially rough in parts of the state with the skinny tires I was running. I might run tires a bit harder where the surface is glassy smooth. I am likely to sometimes not use a guage when making these adjustments
All that said a separate gauge may be a good idea. It is more likely to be accurate and easy to replace if it proves not to be.
Miles to Go
Well said. I just purchased a Road Morph G, and the gauge on it won't win any awards for readability. I have yet to check its accuracy, but a ballpark figure is good enough for me too. I also have a separate, very accurate dial gauge that I had purchased to carry along on tour, but deemed it not worth bringing. It may be worth having it to check the accuracy of other pumps at home.
The flakey gauges like on my road morph G were usually close enough for me to not sweat it the majority of the time. The gauge did seem to stick on a reading at times. Most of the time I have found that with mini pumps or pretty much any pumps that I'd carry I am close enough to the maximum that I can pump with the pump that I can judge where I am when at the proper pressure. So between that judgement and the gauge I get a decent read. Worst case a quick check with my thumb says if I am in the ballpark. I can generally look at the gauge and know that it is sticking and reading low or whatever based of how the pumping and the tire feels. This might not be true except I am topping off nearly every day on tour.
Liked 1,501 Times
Several years ago I wrote up a comparison between the Lezyne and the Road Morph G. There have been a few other brands since then that also added a hose, but I think the comparison I wrote up is pretty good. Note that the software used for this forum has changed a few times since then, so the graphics got a bit disorganized.
https://www.bikeforums.net/touring/1...l#post18521373
Wow, I had not realized I wrote that over six years ago. But other than a few other competitors out there that have been added to the possible list of others to buy, my opinions are still unchanged from when i wrote it.
ADDENDUM:
I have not checked my links in the six year old post, but I am too lazy to keep updating links in old posts, so if they do not work, I am not surprised.
ADDENDUM:
Likes For Tourist in MSN:
Lezyne Micro Floor Drive with the gage works well for me. One important caution. Keep your valve cores tight and don't screw off the pump head at an angle because you can inadvertently remove the valve core and thus all your hard earned air pressure. Once you get the technique, it is straightforward.
aka Timi
I’ve carried a Topeak Road Morph with gauge on tour for many years. Works well.
I’ve got a Mini morph with gauge as it fits in my commuter bag. TBH I’d be fine carrying it on tour as well. Thanks to modern tires I hardly get flats so just the daily top up.
Liked 4,338 Times
Stuart Black
Stuart Black
Yep and pressing the tire with an educated thumb can read that close IME. At home I pump exact pressure with a compressor and a tire inflator because it is really easy to do so and why not, but on the road I don't get too picky.
Liked 2,007 Times
Biggest failure mode I've seen on the Topeaks is mounting them on the top tube, then carrying bike on bike rack. Take the pump off, put it on the trunk, put the bike on the rack, drive off... Yeah, that's the pump's fault!
![Smilie](images/smilies/smile.gif)
Last summer I had the chance to use my 20 year old Zefal HP frame pump when I stopped to help a lady with a flat tire. It had been 2 years since I used it last. Unfortunately upon the first pump the head snapped off. Replaced it with the Topeak Road Morph. Completely different pump and completely awesome pump! The best frame mounted pump I have ever used. Easily will take the pressure to 100psi and more.
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Liked 38 Times
I am a HUGE fan of having a foot peg. It makes pumping so much easier.
I want to be a fan of the Topeak Road Morph. But I've gone through several, both the small one and the higher volume one. They all rattled apart way too soon.
I now have Lezyne Micro Floor Drive, both the road version and higher volume version and find the solid.Multiple years with both and no problems. I wish the handle was as comfortable as the Topeak's handle. but I'll live.
Update - I ended up with the Lezyne HP micro floor drive with the guage, and love it. I couldn't find either the topeak or lezyne local to check out - So I just toldweeks - my kids to surprise me for my birthday. I have used it exclusively the last several weeks with no issues - even going from a flat (intentional) a couple of times. I do wish the handle was slightly bigger - but I am usually wearing gloves - so not a huge issue. I have also thought about if changing out a tube on the side of the road, you could wrap the flattened tube around the handle before pumping if it really were to become an issue.
I have it mounted to the bottle cages for errands and commuting, but will likely just throw it in a pannier wile on trips- So I can just have one consolidated tool bag/repair kit in a roll or stuff sack.
