brake blocks
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveler, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course, yet another 70-something Raleigh Record
Quoted: 50 Post(s)
Liked 18 Times
brake blocks
I'm working on a kid's bike that has painted rims and sidepull brakes. The sides of the rim aren't parallel, but taper in, so that the brake blocks have to be beveled to meet up to the rim. Does anybody sell these beveled brake blocks, or do I just need to get some regular square ones and file a bevel on them?
Quoted: 4239 Post(s)
Liked 3,976 Times
Only a couple of years ago some LBS suppliers did offer angled face brake pads, I just searched both QBP and JBI's sites for such pads and I no longer see them listed.
I suggest getting the thickest pad you can find and grinding down their faces to the angle you need. Filing would take longer but is also OK. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
USAF Veteran
Having the same issue with an old 3 speed. Tapered rims with "square" brake shoes. Only the top edge makes contact. None of my LBSs carry them. They suggest the same thing. Don't think it's a big deal. I'll use my belt sander to get the angle. This particular bike won't be ridden very much so it's not that critical.
Quoted: 50 Post(s)
Liked 18 Times
Thanks for the responses. I'll probably use a belt sander, too, but I might ought to get some extra ones, in case I screw them up.
Quoted: 432 Post(s)
Liked 732 Times
If the brake doesn't already have a concave surface so you could use a convex washer, you could try using a combo of 1 convex and 1 concave washer to allow an angle.
Bike Brake Pad Adjusting Washers - 2 Pairs - 2 each Convex and Concave Washers 600192975386 | eBay
Likes For freeranger:
I have used a grinder to get the angle to match the rime on a non adjustable shoe. Its quick and easy. Rubber can clog up a sanding belt, but if you have a disk/belt sander you can place the shoe on the table and do a better match.
Likes For speedy25:
working on my sandal tan
Quoted: 3874 Post(s)
Liked 2,576 Times
If you sand the brake pads to shape, it wouldn't hurt to finish with a file so that you don't leave any grit from the sanding paper embedded in the pads.
-Ken
Likes For KenCarlson:
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
Hey if any of you need angle cut brake pads, the bike shop I work at carries them. We are a small non-profit community shop, no web store or anything. But, if you need PM me and I will send some to you, just cover postage and shipping.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
