Caught in strong rain, 30 minutes should I re-lube?
Old 04-02-22, 04:10 AM
couldwheels
Liked 18 Times in 17 Posts
I waited for chain to dry. After it's fully dried, I rubbed my fingers and flexed the links, rolled the rollers with my fingers and the chain certainly feels like it still has oil in it. I even ran my fingers on the tap water and the ones I touched chain is hydrophobic so there's definitely a bit of oil remaining.
Not only there's litttle bit of oil remaining, The chain is still very clean, no dark residues, no dirt, no rust, just shiny silver.
Does this mean I can pass on the re-lube, wait another few months or wait to get caught in another rain before I consider re-lubing?
couldwheels is offline
Old 04-02-22, 04:39 AM
dabac
Liked 295 Times in 222 Posts
Pour some lube on a cloth. Give chain a wipe with said cloth. Dispose of cloth in a responsible manner. Done.
dabac is offline
Likes For dabac:
Old 04-02-22, 04:40 AM
couldwheels
Thanks. Sounds very easy to do but would the oil get inside the rollers that way?
Old 04-02-22, 06:02 AM
andrewclaus
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Liked 826 Times in 464 Posts
Chain cleaning is almost a religion to some, completely ignored by others. Some of us commute and tour in rainy climates and don't worry every time the chain gets wet. Besides water, dirt and chemical contaminants from the road are constantly assaulting the chain, as are minute metal particles from the chain itself wearing out. The chain is a consumable. Oil it when it makes noise, check it for wear regularly, replace when needed.
andrewclaus is offline
Old 04-02-22, 06:31 AM
freeranger
freeranger's Avatar
Liked 768 Times in 471 Posts
It can't hurt, and it will provide peace of mind. Re-lube.
freeranger is offline
Likes For freeranger:
Old 04-02-22, 07:02 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Liked 890 Times in 533 Posts
Yes, relubing would never be a bad thing, but to answer your original question: It depends on what lube you are using. Some lubes don't tolerate rainy rides very well, while some are very good. I can usually tell by sound when my chain needs lube. Any hint of noise above the normal smooth hum does it.
Moe Zhoost is offline
Likes For Moe Zhoost:
Old 04-02-22, 07:04 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
No, I wouldn't think that would be effective.
Old 04-02-22, 08:17 AM
Crankycrank
Liked 1,215 Times in 838 Posts
If shiny includes your rollers too, that's a sure sign it needs more lube.
Crankycrank is offline
Old 04-02-22, 08:41 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Liked 4,537 Times in 2,522 Posts
Nope. Oil rubbed on from outside just stays outside and does nothing other than be cosmetic. No matter what the lubricant, reapplication after rain is necessary.
Stuart Black
cyccommute is offline
Old 04-02-22, 09:11 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Liked 2,935 Times in 1,490 Posts
You're kidding, right? You should be lubing your chain once every week or so whether or not it gets wet.
cxwrench is offline
Likes For cxwrench:
Old 04-02-22, 11:47 AM
Iride01
Iride01's Avatar
Liked 5,404 Times in 3,729 Posts
Depending on what your lube is, I too would think you should be lubing your chain more often than every few months. A lot of the lubes now that stay cleaner on your chain will need application every 100 miles and half that for use when in wet conditions. Assuming you wish to stay in what the mfr says gives the ideal benefit for their lube to your chain.
You won't hurt your chain by lubing it too often. Just wipe off the excess on the outside afterwards.
Iride01 is offline
Old 04-02-22, 11:57 AM
zandoval
zandoval's Avatar
Liked 1,844 Times in 1,182 Posts
What the Hey!!! Just lube it Dude. It's gonna be OK...
zandoval is online now
Likes For zandoval:
Old 04-02-22, 07:13 PM
KerryIrons
Liked 709 Times in 402 Posts
Wouldn't that depend on how many miles per week you ride?
KerryIrons is offline
Old 04-03-22, 10:27 AM
couldwheels
A few months ago I was doing around 60 miles per week. For two months I did not re-lube the chain because I did not get caught in any rain. The first month, I was wiping the chain down with rag after every ride. Then I stopped wiping down the chain because the chain never gets dirty anymore. I suppose most of the oil have finally run out.
Then after the 2nd month, I removed the chain and removed a chain link for inspection. I found the pins and rollers still have thin film of oil inside that has turned dark gray but still liquid otherwise. Other than the that, the insides look pretty clean. No sandy particulates whatsoever.
I also measured the chain stretch new (before and after) in those few months. So far, so good, no stretch at all after approximately, 500 miles.
I haven't re-lubed yet since the rain. I definitely would if I only have a bit more free time. Just tired all the time from work and other day to day problems!
Old 04-04-22, 07:36 AM
pdlamb
Liked 2,159 Times in 1,328 Posts
I'd start by wiping the chain off; I always collect a lot of road grime on my chain (and frame, and wheels) when I ride in the rain. Or while the roads are still wet.
Unless I'm feeling particularly lazy, I'll re-lube after a heavy rain. If I am lazy, I'll listen for a squeaky chain. Of course, that depends on how heavy is a heavy rain? My heavy rain is at least half an inch of rain in an hour.
pdlamb is offline
Old 04-04-22, 01:30 PM
Camilo
Liked 1,400 Times in 898 Posts
The correct answer follows
If the thought crosses your mind that the chain might need lubrication, why wouldn't you just do it?
Camilo is offline
Old 04-04-22, 02:48 PM
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Liked 437 Times in 258 Posts
Wipe it as dry as you can with a rag.
Place a drop of lube on each link and after a few minutes, wipe it all off again.
Should take less time than writing and reading all the replies.
bblair is offline
Likes For bblair:
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
