Sign of too little food on the ride?
Yesterday, I rode for 3 hrs which I haven't done for one whole year. Most of my rides have been 30 to 45 minutes and lately, I've been doing 1 hr rides in the weekends only with very short indoor training sessions during the weekdays (under 15 minutes).
I was perfectly fine for the first 2 hours of the ride that included 1000 ft of steep climbs 15 to 20% grade and maintaining 20 mph on the flats on a heavy commuter bike. No soreness in the first 2 hours and still feel 100%
However, in the 2 hr mark, I've exhausted my drink bottle that contained diluted milk chocolate with a pinch of salt. From that point, my strength rapidly deteriorated and started feeling sore in my legs. I started having nausea too. The last one hour of the ride is mostly flats, maintaining 20 mph until I no longer could.
I felt weak and dizzy the rest of the day after I got home but today, the day after, I feel 100% fresh again and resumed indoor training. No soreness anywhere like I never did the 3 hr ride.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4435 Post(s)
Liked 3,064 Times
undertrained for that ride, probably. Nutrition effect likely parenthetical.
Quoted: 6353 Post(s)
Liked 4,956 Times
As long as I'm in the shape to ride a particular distance or even just attempt it, then carbohydrates are all I need for the entire time I am riding. And I'm happy putting all of them in my bottles. Usually consuming 150 - 200 Calories per hour is what I plan on for me. I don't see any advantage to protein while riding other than it can smooth out some of the tastes. And maybe helps with how it feels in your stomach. Fats I wouldn't add at all.
So I'm a little skeptical of milk while riding. I'd worry about stomach upset. Though I use to be skeptical of milk as an after ride recovery drink. Though I've found that milk seems to be a good recovery drink when additional carbs are added too it. Like chocolate syrup! Though mostly I'm using soy milk for the protein boost in my post ride recovery drink.
Last week I did my birthday ride and took 4 hours 15 minutes pretty much non-stop except for crossings and a water stop. Except for the carbs I put in my bottle I only ate one high carb power bar that had a little bit of protein in it.
So I too will agree that if you had issues then you just probably pushed too hard too soon.
I felt famished in the last hour of the ride after my bottle ran out. Any chance bringing one more bottle would help?
Liked 4,956 Times
I go through 25 fluid ounces of drink every 50 minutes. So I normally have two bottles on my bike and that gets me a tad over 30 miles. I personally won't ride 20 minutes without water. In the summer heat here one can die without staying properly hydrated. And getting dehydrated can cause you to mistake thirst and hunger as well as a lot of other things.
For rides longer than 30 miles, if I can fill my bottles somewhere with water, I take dry mix to put in them. When I can't do that, I've stuffed a bottle in my jersey pocket or velcro'd it to the underside of my top tube and even taped one to the underside of my downtube a time or two. Put that bottle in a plastic bag. It'll get all sorts of road filth flung onto it from the front tire.
So I have carried four 25 fl oz bottles on rides and could do 5 or 6 bottles if willing to deal with them in my jersey pockets. Those get switched out as soon as I empty the first bottle as the weight is annoying in a back jersey pocket.
So if you run out of drink while riding distances, you need to stop and call for your SAG person.
Likes For Iride01:
Quoted: 2333 Post(s)
Liked 2,097 Times
Depending on temperatures, one bottle is likely not enough. I did two hours today in 48F with one bottle and did not even finish it. On a hot day, I might need a bottle an hour. It would not hurt to bring a second bottle. Normally, I do not eat on a 3 hour ride but it sounds like your relative lack of training base would suggest bringing an emergency supply of food along and nibbling a bit as you go. It might not take much supplementary carbs.
Likes For GhostRider62:
Liked 3,064 Times
Likes For MinnMan:
I soaked my gloves, shirt and hair in water before heading out. It kept me cool for the first 30 minutes.
Liked 3,064 Times
Ah, you didn't make clear how hot it was in the Kingdom of Qwaa this time of year.
At those temperatures, a 3 hour ride requires a great deal of hydration. One bottle for a 3 hour ride was not nearly enough. But the issue would be fluids and maybe electrolytes, not food or nutrition.
From then on I avoided riding between 8am and 4pm and no longer had any issues with the ride until I did this 3 hour ride from 4pm to 7pm.
I might do it again, not this weekend but when I get free time. I'll bring a pannier so I can have 3 bottles of drink.
Liked 2,097 Times
It takes a couple of weeks for me to adjust to very hot temperatures.
I find wearing white sun sleeves and keeping them wet helps a lot in 100+ temps.....just another idea.
Quoted: 5234 Post(s)
Liked 3,609 Times
3 hrs no water or food? I would not do that
Likes For rumrunn6:
I estimate bringing three bottles in my next attempt at the same route. 2 bottles for drink with carbs+electrolytes and one bottle of pure water to keep my jacket wet. Or perhaps four bottles just to be on the safe side. Three for drink and and electrolytes and one for keeping things wet.
Likes For qwaalodge:
I thought just 1 bottle of drink with carbs and electrolytes would be enough in >90F riding temps for three hours
Is losing power quite suddenly is expected for insufficient "fuel"? My legs just suddenly went from being ok to quite sore in just just a matter of minutes past the 2 hr mark and after I depleted my bottle and it happened while I was cruising the flats. I started having a headache too.
just another gosling
Quoted: 3919 Post(s)
Liked 1,982 Times
It's all of the above: dehydrated (why you had pain and nausea), out of gas (why you felt weak), and undertrained (why you suffered more than you should have). Training doesn't solve problems of dehydration and lack of fuel, but it does enable you to do a better job of suffering through them. As others have commented, 1 bottle/hour, carb-rich, say 150-250 calories depending on how hard one is capable of riding. The better shape you're in and thus the harder you can ride continuously for 3-4 hours, the more carbs and hydration you actually need. In top shape on long mountain rides, I've had problems of lack of water and fuel. I still finished, but I wasn't shall I say, comfortable.
You should be able to complete one ride in relative comfort which is as long as the sum of your weekly hours in each of the two weeks preceding the long ride. Having problems with doing that is not usually a training problem, though it could be a pacing problem. Use that for a guide in the future.
The secret to getting in better shape is simply more total weekly hours. Six is pretty easy to get for most folks, ten is enough that you can do any ride, anywhere, any time. That would be 500 hours a year, or about 7500 miles. I've found 5000 miles/year, or about 400 hours counting gym time to be enough to do almost anything. Keep track. I ride year 'round, though more hours in summer of course. Year 'round is critical IME. Trainers and rollers work fine. Count those hours too. In fact, I think trainer and roller hours are equal to about 1-1/3 outdoor hours - no coasting, stop signs or traffic lights. The time at stop signs and lights don't count of course, but they do rest your legs. That said, I don't use a multiplier. Hours are hours.
Results matter
Results matter
don't try this at home.
Quoted: 989 Post(s)
Liked 535 Times
90F, 3 hour ride with hills?
I'd finish 3 24 ounce water bottles, one with a diluted sport mix to start the ride. So that's a water stop part way through the ride. Also a Coke at the stop is good, I like that.
400 calories in energy bars, at least. And I like having an extra one "just in case"
And a cooler with iced cold water waiting at the end of the ride!
Likes For rm -rf:
As I get stronger, I increase power output but NOT the duration. Have difficulty finding more free time for training so I would simply increase power output in the time given. If situation gets better, I'll do my best to reach 10 hrs /week.
I did finish the ride, got home but with nausea and nausea being the most bothersome feeling. I would have been OKAY with the sore legs but the nausea wrecked my spirit because I know it's about to get worse and got a throbbing headache the rest of the evening. Totally fine the next day. Legs fresh again. Only the butt is a little sore and my left wrist. I have fairly recent accident-related injury on my left wrist so the soreness is probably expected. But no leg nor hand numbness during the 3 hour ride.
Re: Pacing. I may have pushed hard in the first hour there was a strong headwind so I went about chasing slow cars to draft 10 ft behind. Longer duration of z4 effort to catch up to and get in the draft zone. 2nd hour was mostly steep hills which actually felt easier than dealing with headwinds on the flats.
I'm also thinking of avoiding milk in my drinks for now. I've had upset stomach by the time I got home. Would be the first I had problems with milk. Milk never gave me issues before when consumed during rides.
Bad idea to pour cold water on my shirt though?
Liked 1,982 Times
I do between 3.5 to 4.5 hours of training per week. 3.5 hrs in indoor trainer. Each day is 15 minutes zone1 spinning 120 to 140 rpm and another 15 minutes in zone4 low cadence (cumulative, not continuous duration). Excluding stretching for several minutes.
IMO minimum effective trainer time is 45'. Most indoor days, maintain a moderate pace, just below VT1: https://www.acefitness.org/fitness-c...2-and-vo2-max/
OK to warm up to that pace over a few minutes. Save the Z4 for the weekend. Once a week, do the fast pedal, steady 120 rpm for as long as you can, up to 40'.
Or instead, do one-legged pedaling drills, indoors only. I prop the lazy foot in the frame triangle https://www.bikeforums.net/training-...l#post21373253
The harder one rides, the more choosy one becomes about what one puts in one's belly, and when, and how often
Results matter
Results matter
Likes For Carbonfiberboy:
Increase training time by about 10% per week. You body needs time to adapt. For headwinds, treat them as long pass climbs. Gear down, maintain normal cadence and a maintainable pace. Ignore speed completely. Try to get more aero. Go hard on the hills.
Strawberry jam have always worked for me. The rest of the day, I keep a low calorie diet to keep my weight ~130 lbs and BMI of 20.
Klaatu..Verata..Necktie?
Quoted: 10634 Post(s)
Liked 12,266 Times
That's something I do on hot days, although generally it's just whatever temp of water I've got. I squeeze the bottle down my back, and also into one of the vents on the top of my helmet.
Likes For genejockey:
Quoted: 229 Post(s)
Liked 327 Times
And, yes, losing power suddenly is very expected. Could be you bonked from low carbohydrate stores.
Likes For guachi:
One bottle would not be nearly enough for me. I can ride three hours on my trainer inside at 75 and only drink one bottle. But outside, 90, and sunny would easily be three.
Might be prudent to attach a thermometer at the top tube to see how hot the temperature really is? I suppose 95F would be no-go. Although I could ride 100F but that would be mostly light pedaling and would probably avoid routes with long steep climbs. Probably pointless unless it's only 1 hr recovery ride.
Liked 1,982 Times
Thanks. I suspect out in the road, the temperature could even be higher than the weather report because the road tends to absorb and radiate the heat.
Google heat shock proteins (HSPs).
Results matter
Results matter
Liked 2,097 Times
Training in the heat makes a huge difference. I purposely go out for day rides in the hottest part of the day. That practice also helps one when it's not hot. I've done long pass climbs in 105°. Takes a lot of water. I use HR to watch for dehydration. This is only safe if you know where your water sources are. I've gone through 70 oz. of water in 20 miles, maybe half of that climbing, though I was probably a little dehydrated when I started that leg. I've ridden on asphalt so hot that my tires left dents in the road. That sucked.
I don't have the study at hand but I had read that training in hotter conditions also raised plasma volume and therefore stroke volume.
It was brutally hot on TABR in the West. When I got back home on the East coast, I would shiver riding in 75-80F temps. Crazy how the body works. I probably might have been skinny, too. But as usual, I agree......heat acclimation can be trained although the combination of Malaysian sun, high temperatures, and brutal humidity might be too much.....dunno
