Best Clamping Location on Repair Stand
senior member
First choice was the top tube but the bike turned in the jaws and the rear brake cable got pinched - I'm now thinking seat post or tube - wondering what others do and whether you wrap the tube or post with a material that resists twisting - hanging it by the seat nose isn't an option .
Always seat post. Decent bikes have very thin walls in the center of the tubes. You can
Likes For cpach:
Quoted: 4895 Post(s)
Liked 4,066 Times
You don't say what your bike or bikes are. The steel bikes of long ago were save to clamp on all of the main tubes. Quick destruction for many current light bikes. Many of the new seatposts have the same issue. What many mechanics do is have a second seatpost with a strong tube and simple swap seatposts for the stand.
Likes For 79pmooney:
Method to My Madness
Quoted: 2081 Post(s)
Liked 1,568 Times
Always clamp the seat post, never clamp the frame. This rule applies even if both the frame and the seat post are carbon fiber. Seat posts are designed to be clamped by a clamp on or within the seat tube. Yes, I understand that a work stand clamps a higher section of the seat post, which may have thinner walls and/or a non-circular cross-section to allow flex, but that is still safer than clamping the frame. No, the seat post is not indestructible, but at least it is (generally) much less expensive to replace than the frame. Use only the necessary clamping force; do not overtighten the clamp. If planning to apply great torque, best do as 79pmooney described above.
Likes For SoSmellyAir:
senior member
PRS-4W-2 Deluxe Wall Mount Repair Stand | Park Tool
Quoted: 3662 Post(s)
Liked 3,098 Times
Concur with seatpost. Also--use a shop rag in the jaws for added protection.
Likes For smd4:
Quoted: 604 Post(s)
Liked 1,064 Times
All my bikes are steel so usually the top tube, and a shop rag, on my old Blackburn stand, never had an issue. Newer Aluminum or Carbon frame seat post.
Tim
Tim
Quoted: 4280 Post(s)
Liked 3,007 Times
If you're afraid of damaging your seatpost for whatever reason, get yourself one of these:
Likes For himespau:
Liked 3,098 Times
Quoted: 604 Post(s)
Liked 1,064 Times
I didn’t know that even existed, Thanks!
Tim
Tim
Liked 3,007 Times
I think those are no longer made, but I found one on eBay for like $20 and they make a different version that does a similar job, but doesn't push the bike outward when it clamps.
Liked 3,007 Times
Sorry, when I said push the frame outward, I meant that the ISC-1 that I have, because of the U-shape design of the tool, has the clamping surface a few inches over from the frame which pushes the entire frame outward from the clamp. It also allows you to have the frame a bit higher relative the clamp.
Quoted: 2406 Post(s)
Liked 2,997 Times
not made any more by Park any one have other brands.... of course one can just get a seat post to use
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Liked 3,098 Times
Likes For RGMN:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I have the same race stand as the above to posts. Its the best, nothing you can't do with that stand front or rear end work. I have both types but don't use the traditional style very often.
Heck i use it mostly for work on my hunting bow more than my bikes.
Quoted: 243 Post(s)
Liked 234 Times
Likes For RGMN:
rebmeM roineS
Quoted: 654 Post(s)
Liked 348 Times
A bit of a challenge for my $99 Venzo VPT with our tandem but the 2" Reynolds cromo main tube is pretty robust.
Liked 3,098 Times
I'd personally prefer not have to remove a wheel to get it to work. If I had my druthers (actually, the money, or lack thereof, is the issue), I'd get a Park professional stand with the sheet steel base. That thing was a marvel of engineering.
Likes For smd4:
Quoted: 1956 Post(s)
Liked 2,201 Times
The best location is probably the seatpost, and for any higher torque maintenance, probably a must.
But for me, I weigh the integrated seatpost clamp vs. the separate seatpost clamp and the type of work I’m doing.
I use a Feedback Sports work stand, but that’s probably academic, except for linkage type work stand clamps.
If I’m doing light adjustments or lubing, I’ll very lightly clamp the top tube rather than loosen and tighten an integrated clamp, especially one that is threaded aluminum, every time I’m dinking around on one of my bikes.
John
John
Liked 1,568 Times
But would this damage a carbon fiber seat tube? That would be worse than damaging a seat post. And even if not, what is the advantage over using an alloy seat post? Either way one would have to remove the actual seat post. Or is a non-round seat post the only reason to use this?
Quoted: 243 Post(s)
Liked 234 Times
Liked 2,997 Times
I don't think I would want to try this or similar with carbon seat tube. especially non round ones.
the guy I would go to for stuff that i don't have tools for like bb facing, put a bunch of padding on top the top jaw and would hang bikes by the seat. I am to clumsy to do that, and certainly not with other peoples bikes
