Tricky brake hood
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Liked 479 Times
Tricky brake hood
i need to replace my rear brake cable and handle bar tape but trying to see how the brake handle comes off the handlebar seems to be a challenge. Looking down through the cable holder I don't see any screw behind it nor is there a screw on the reverse side. The hoods are a black rubber mold which fit over a hard black casing attached to the handlebar.
Does this look familiar to anyone and if so, where do I release it to get it off the handlebar? There was a small screw behind the lever where you can see that squarish opening but when I removed it, it just held place a small spring in place which controlled the brake lever mechanism.
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x900/brake_hoods_27bd80b13b9ca44ab3faf521fbcf357c7c37f8fd.jpg)
Ride, Wrench, Swap, Race
Liked 1,341 Times
4mm Allen key through the hole in the front of the lever.
Likes For dddd:
Liked 479 Times
wow! my old man eyes would have never found that so thank you. I will turn on some serious LED lights and look for that hole.
Used to be Conspiratemus
You don't even need to be able to see the target. You should be able to just stick the long end of the Allen wrench into the hole, blind, and it will butt right against the cap screw. Jiggle/rotate the end until you feel it drop in to engage and Bob's yer uncle.
Likes For conspiratemus1:
