Cut in sidewall tire repair
I ordered online a pair of Pasela 27 x 1 1/4 tires about a month ago. Tires looked fine upon delivery. I mounted them on rims and pumped the tires up. I was working my way around one if the tires getting it seated when I saw a cut in the sidewall.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_20220403_083221793_287b99d340cdae57019621913c94e22b72be29ad.jpg)
Its about a 1/2" cut. Called and emailed the well known seller and they refuse to do anything. I even said I'd forget about replacement and buy more tires if they would pay for the shipping. They werent interested.
So whats a way to fix the tire. Duct tape? Canvas boot? Super glue? Gorilla glue and fibertape? Any ideas appreciated.
curmudgineer
Bikes: 2 many 2 fit here
Liked 112 Times
I learned from experience not to consider the Pasela by any means a rugged tire. I certainly don't commute with them, and limit their usage in my fleet to pleasure bikes with 27" rims.
I wouldn't get so attached to one with a split sidewall, to try to repair it. In the bin with it.
Likes For old's'cool:
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Liked 419 Times
I agree in the bin. It's one of the last things you want failing. Even if it's safe it's just not pleasant having that worry in the back of your mind.
That being said you can cut a piece of sidewall off another tire and glue it on the inside, with a largish margin around the cut. Don't use superglue, its too brittle.
Likes For Soody:
Phyllo-buster
Liked 2,069 Times
Likes For clubman:
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Liked 199 Times
just my $0.0125... i've patched an ugly cut into a sidewall using flexible glue and two layers of the satin-like lining material (the kind you'd find lining a sportcoat etc.), pressed in place overnight. it's been holding up fine for over a year now. I would have done this with tyvek had i any handy at the time - suspect that would handle higher pressures than the ~65 psi the suit lining is dealing with.
Likes For niliraga:
The tire with broken cords is now trash. If you try to patch the inside. patch the outside, too. Symmetry is a good thing for repairs like that.
The tire with delaminated and cracked rubber but intact unbroken cords could be saved. Cover the cords with liquid latex to protect them from the elements and smog so they don't embrittle and break.
Likes For Bad Lag:
seńor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,650 Times
I’ve used liqui-sole or Shoe Goo to glue patches of either nylon cloth or non-woven to fix sidewall cuts. They’ve lasted for the remaining natural life of the tire so far. I make sure to soak the patches through to create a kind of laminate.
Likes For dabac:
Regarding how rugged Paselas are, I don't think it matters in this case. Seems big chainring hasn't ridden the tire in question. It looks to me like it might have been damaged in shipment from distributor to retailer by someone misusing a box cutter. Too bad the seller won't replace it.
If it was for a bike of mine I'd use it. Boot it with a chunk of Tyvek and some barge cement. If I was going to move the bike on, then I'd toss it.
I've had plenty of Paselas and Col de la Vie tires from Panaracer. They are sturdy. I've run Col de la Vie tires on my Schwinn Speedster since converting it to 650A. The bike lives in my garage and goes from sub-zero winters to 100°F summers. I've ridden them until their sidewall casings began to break down, which takes a while. I've even stretched their life a bit more with liquid latex when I didn't have a replacement ready to install. Yes, I can be a CSOB...
Happy With My Bikes
Liked 2,360 Times
It looks to me like a defect in the sidewall. I would try to get a refund or replacement from the seller.
FWIW, I love my Paselas
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Liked 364 Times
Since the seller won’t play nice I’d say contact Panaracer directly and see if they’d replace it. That’s either an egregious manufacturing defect, or somewhere along the way that sidewall was nicked with a box cutter.
Likes For Rooney:
Mother Nature's Son
Liked 1,465 Times
To me it looks cut, then spread a bit when inflated. I would not ride it, just mark it up as a loss. I have used shoe goop for a lot of things, and that is what I would do If I was going to try to repair it. From the picture, the sidewall looks too compromised for me.
working on my sandal tan
Liked 2,579 Times
As much as I enjoy squeezing life out of questionable tires, I don't think this one should be ridden, except perhaps on a trainer. That's a pretty significant cut across the "grain" of the tire casing.
I think a certain amount of Buddhist non-attachment is necessary when riding Panaracers or any other high-performance tires with thin, fragile sidewalls. You have to accept that their life will generally be shorter, and sometimes over in an instant when they get an injury like this. And that's after paying a lot more for the privilege in some cases!
![Wink](images/smilies/wink.gif)
Likes For ThermionicScott:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Liked 459 Times
In the short term I would use one of the repair methods mentioned and keep an eye on it when riding. Then I'd order a new one. I wouldn't use this one on the front btw.
Why wouldn't the retailer allow a return?
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Liked 3,106 Times
It's quite obviously not a manufacturer's defect.
I've used shoe goo to glue in a thin leather boot to repair a cut almost that big in the tread & casing of an almost new Pasela when I ran over a car key and it somehow went straight though the tire. I clamped it with a deep socket on the inside to help maintain the shape of the tire, wrapping it with an old latex tube for clamping pressure. Also used shoe goo to fill the cut on the outside. It's holding up good. I don't think I'd use it on the front, though.
Likes For alcjphil:
Finally the seller responded. Wants the tire returned, they pay shipping, and they will refund money for tire. And now they say they have no more stock of this tire which I think is bunk. They also mentioned, as if they are doing me a huge favor, returns are to be made 24 hrs upon receiving tire or part. Any item mounted or installed is not returnable. Screw them. (Carson City Bikes).
I'm going to go for a try at repairing. I think I'll boot it with fabric and shoo-goo or other flexible glue. I made a sidewall repair on a sew-uo years ago and it held.
Likes For big chainring:
