Lightweight, strong trailer floor?
I have taken this kid's trailer (Chariot model no longer in production) apart to turn it into a cargo trailer, and possibly a micro camper too.
I sometimes haul heavy stuff (e.g. compost, small furniture) so the floor needs to be sturdy enough to withstand 50-60 kg of weight.
I am getting stuck at floor options: Marine plywood, aluminium, PEHD, Coroplast, foam tiles, linoleum?
What did you use? Or what do you recommend?
Chariot Corsaire
Chariot Corsaire
Likes For SagaInColours:
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 573 Times
I’ve had good luck with shelving:
https://www.bikeforums.net/21220581-post693.html
For high point loads, I have a sheet of 1/4” plywood that I use to distribute the weight.
Likes For flangehead:
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,246 Times
3/8 plywood on top of the frame
Fred "The Real Fred"
Likes For 10 Wheels:
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
I’d look for 1/4 HDPE it’s light strong and of course waterproof and extremely easy to work with. drill a hole and zip tie it to the frame. The other option may be aluminum which you could still cut with a circular saw but would have to do more grinding on the edges for it to be less abrasive to the zip ties. Screws will only as weight and the vibrations may work them out of the frame.
I’m thinking the plywood may hold moisture and add weight.
Likes For Bogey Speedwell:
Quoted: 87 Post(s)
Liked 132 Times
should handle anything you want to pull. Use the frame as support, so the platform is on top of the frame. Pretty confident you won’t be able to break it unless you are using it at sub zero temps. I occasionally work with it and it is stronger than 3/8 plywood and think it would be more durable than 1/2” plywood. I’ve tried to bend it with a heat gun to bend pieces to make diy cargo cages and I gave up, was able to bend it but not very well and none broke under my manipulation.
