Rear derailleur indexing is perfect, then gears start to skip
I cannot figure this one out. I must be missing something, so hopefully some forum members can point me in the right direction.
I have an 24-speed Specialized Rock Hopper from around 2006. It was skipping between the the smallest and second smallest rear gears regardless of cable adjustment. The gears were very worn, so I switched out the rear cassette and the chain. Initially it seemed this fixed the problem, but after a few rides the problem has returned in a new form.
Now, I can get the shifting perfect on the repair stand by adjusting the barrel adjuster, test ride the bike and it seems fine, but as soon as I ride more than a mile or so it will either start to skip from the smallest to second smallest gears, or vice versa. What could be causing this?
Quoted: 6330 Post(s)
Liked 4,922 Times
Smallest gears being the smallest physical size or the lowest ratio gears?
Quoted: 4232 Post(s)
Liked 3,940 Times
The first thing I think of is that the replacement cassette probably fits on the hub slightly further out from the spokes. So that the high gear limit screw is no longer set correctly. I suspect that screw is not letting the chain run onto the small cog as smoothly and as centered as it should. With soft pedaling the "trying to sort of shift but not quite" limit screw setting generally won't be an issue. But add pedal pressure and this slight misalignment can be the cause of the chain trying to shift but not making it.
While the industry does try to make every cassettes of the same cog count fit on the freehub body exactly the same, this just isn't the real life case. So with a different cassette (and/or wheel) one should double check the der adjustments and make (minor usually) corrections as needed. Bicycle gear systems are not a plug and play system. Close but not exactly. It's up to the person doing the work to confirm and correct as needed. Andy
AndrewRStewart
AndrewRStewart
If I were you, I'd replace the chainrings as well. I posit that will resolve your issue.
