bar end shifters
Quoted: 139 Post(s)
Liked 52 Times
bar end shifters
hi guys, and ladies. quick question. do bar end shifters require a certain bar inside diameter? i'm looking at an old raleigh grandprix with bar ends, 2 x 5 speed with drop bars and want to convert this to a riser bar wald 867. will the bar ends fit in this bar. its pretty much standard as far as i can tell. if not. are there shims made to adapt to this. thanks, joe
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Quoted: 699 Post(s)
Liked 1,303 Times
IIRC Drop bars are 23.8 and and most flat bars are 22.2
Likes For Germany_chris:
Am-a-tour
Bikes: 2020 New Albion Privateer, 1983 Schwinn Super Sport, 2022 Rivendell Atlantis
Quoted: 45 Post(s)
Liked 65 Times
Bar end shifters are designed for handlebars with a diameter of 23.8mm, slightly larger than most riser/city bars (22.2mm). That said, some handlebars with a big backsweep (so that the handlebars end up parallel to the top tube or nearly so) - like mustache bars - are 23.8mm and can accept bar end shifters.
Edit - the Wald 867 will not work with bar ends.
Mother Nature's Son
Quoted: 865 Post(s)
Liked 1,462 Times
There are riser bars with the correct sizing for bar ends. One handlebar of that size I really like is the Velo-Orange Porteur bar, comes in both 22.2 and 23.8. It may not have enough rise for you as it is only 15mm. I believe the VO left bank bar comes in both sizes and it has a rise of 75mm. My issue with a lot of these types of bars are the width, too wide for me. The Porteur and the Left Bank keep the width narrower.
Likes For delbiker1:
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 162 Post(s)
Liked 135 Times
Be aware the you'll run into issues fitting upright style levers on many of these bars.
The outside diameter is irrelevant, it's the inside that matters. The tubing wall on steel handlebars is much thinner, making the ID larger. I've used bar end shifters with set of upright steel handlebars from an old Schwinn with no issues. I can't be a 100% certain that bar ends will work with the Wald bars, but I'd be very surprised if they didn't.
