Wahoo Element Bolt Questions?
Hi fellow Roadies,
I have been using the Wahoo Element Bolt for 2 years. Love it. Having a small issue that seems software related. I have performed all software updates properly. However, no matter the actual battery level it is giving me a constant "LOW BATTERY" warning. Flashing Lights etc. It still seems to read and perform accurately, but I am constantly having to DISMISS the false low battery warnings. Fairly annoying. Has anyone encountered this, and or have any suggested solutions? Thx.
Likes For blazin:
Liked 3,307 Times
are you sure the low battery isn't a sync'd accessory? Try unpairing a sensor, one at a time, to see if the alert goes away.
-YMMV
-YMMV
Likes For Troul:
[MENTION=355648]Troul[/MENTION] great advice and you were dead right. My Power meter battery was dead and my Bolt was telling me to change the battery. Super appreciate the advice.
Likes For Mattyb13:
One thing I learned about my Bolt was to follow the battery charging recommendations from
Wahoo. For years I used an extra Apple block but when the Bolt started having weird behavior I switched to the recommended charging block. Not sure but look at the Wahoo site.
I agree they should supply a charging block with it since they explicitly say to not use a standard Apple charging block and so many people have more of those to spare that they will end up using them.
Likes For waters60:
Bikes: SL8 Pro, TCR beater
Liked 601 Times
Yep! It reduces their production cost. That's why I put electrical outlets with integrated USB ports in the areas where I need them most. There are also outlet extenders that can be plugged in regular outlets!
