18mph pace
18mph pace
Did a sprint triathlon in Long Beach this morning. 12.28 mile course in 40:45 = 18mph pace. My goal has been to break 20mph on a timed circuit. I was saving a little bit for the run, but not that much. If I had just gone balls out, maybe 18.5mph but I'm still a long way from 20mph sustained pace.
But that's still pretty good, right?
Likes For VegasJen:
Quoted: 314 Post(s)
Liked 683 Times
If you're happy, it's good. Did you run well of the bike?
(also depends on how lumpy the course was, the bike you were riding, sneaky drafting 😉, your cDa, etc...........)
Likes For tempocyclist:
Quoted: 2333 Post(s)
Liked 2,097 Times
Flat as a pancake with just a couple of turns? Do you use a power meter and have you optimized your aerodynamics to any degree? Do you know what power you needed to average 20 mph? 18 mph is pretty far off from 20 mph, it is probably something like the difference from 140 to 180 watts with mediocre setup and position. So, you might have needed 140 watts average to go 18 mph, for instance. With a dialed in position and kit, that 140 watts alone could get you 20 mph. Numbers are illustrative only.
Likes For GhostRider62:
As for the run, I gave it all back there. I ran right at a 10 minute/mile pace. I'm not exactly a speedy runner but in a single 5k or 10k event I'm generally around an 8:30-9 minute pace. I was just out of gas at that point. What I did really well (for me) was the swim. The swim has always been my worst event. Regardless of wave, I am usually one of the last ones out of the water. But about 9-10 months ago I started to incorporate some upper body free weights in my routine and I've been swimming at the public pool twice a week this summer. That has helped immensely. I got out of the water in the back of the pack, but I was still in the pack.
If your goal was 20 mph average, you failed. Right?
Likes For VegasJen:
Liked 2,097 Times
I'm pretty happy with it overall. This was my fifth tri and that's my fastest pace so far. Not by a lot, but still fastest. And it was mostly flat. The course was two laps that included a back-and-forth over a bridge.
My goal is to do 20mph pace at some point. So, I failed this time. As for power meters and watts and stuff, I have no idea about that stuff. I get on my bike and pedal like hell. As to the course, There were quite a few turns and I had to traverse a bridge a total of four times, so mostly flat, but not ideal.
I do what I can with my equipment. I know some people hate them but I have clamp on aero bars for my bike, not so much for the aero but to relieve arm fatigue. Still, I'm sure it's not hurting my aero either. Once I finish school, I'm going to look for a decent used tri bike. I have no idea if that would help at all but I'd really like to try one.
Likes For VegasJen:
Quoted: 6199 Post(s)
Liked 4,816 Times
Arbitrary goals are okay. But what matters is whether or not your data shows that you are improving when compared to past rides.
Or are you looking to see how you compare to any of us?
Likes For Iride01:
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
The difference between 18 & 20 can be a lot of little optimizations. High quality, low rolling resistance tires *could* be a big piece of that equation. But, I don't think your issue is as much equipment, or prevailing winds, or luck.
The tell is the 10 minute run pace. At a 10 min/mile pace, I don't feel I'm running. Only jogging, & jogging poorly at that.
Poor form is what causes injury. The human body is designed to either run or to walk. The sort of half-between, neither that is jogging is begging for aspirations of long durations, long distance with poor form resulting in poor adaption, unnecessary muscle-skeletal stress & eventually injury. Un-coached people when new to running will often trade speed & proper form for distance & time engaged. It's only natural & it is because nobody has told them better. Running takes years to develop. It's hard. Any yahoo can step out their door & jog their way to injury in the hopes of attending an event.
In my mind, this is what you have done here. You have not developed the capacity to sustain the minimum energy expenditure necessary for a 7-7:30 or better pace that would be actual running. This "overhead" in your cardiovascular fitness & mitochondrial adaption would go a long way to feeding your cycling ability.
base2
former runner
base2
former runner
Quoted: 432 Post(s)
Liked 461 Times
Really difficult to say whether 18mph is a good pace, especially in the context of a triathlon. Wind is also a factor. For example there's a short segment that I do, and I can push 16mph against a 7-10mph wind. On the return leg with tailwind I average 20mph with what feels like way less effort. I don't know if I have it in me to get to 20mph against the wind and sustain it. I've also never had 12 miles of uninterrupted flat road to try these sorts of tests.
In general though, aerodynamics make a huge difference, regardless of the rider's body type. The goal is to get to a position that reduces the frontal area as much as possible while still being able to tolerate it from a comfort perspective, and maintain strong power output to the pedals.
A dedicated tri (or TT) bike will certainly be more aero and help you ride faster but there's a trade-off in comfort. But if your TT efforts are short that may not be a problem.
Quoted: 18883 Post(s)
Liked 10,646 Times
Congratulations on utterly smashing the swim, doing great on the run, and still managing to do well on the bike!
Likes For Seattle Forrest:
base2
former runner
base2
former runner
Thanks. Aside from the run, I feel I did pretty well.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Triathlon is not cycling; you don't need should be happy (or not) on your own, not against someone else. You don't get pulled for being down a lap.
Did you make and execute a good plan? Leave it all out on the course? Learn some new things? Then you did great, not pretty good.
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
Likes For shelbyfv:
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Yep, enjoy! https://www.bikeforums.net/triathlon/
Likes For Bah Humbug:
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,932 Times
I am potato.
Liked 1,631 Times
Ya, I never had any training to run, but I did a lot of running when I was in the Marine Corps. Back then, my best time was a 6:20 mile. But that was 30 years ago too. About six months ago I ran about an 8:20/mile pace in a 5k. I'd like to be under 8 minute/mile, but I'm pretty happy with that. I've been trying to figure out why I'm so much slower now despite only being a couple pounds heavier today and what I keep coming back to is my feet. I have no spring in my feet like I did when I was young. I watch young people run now and I see how their feet land, absorb energy and then re-release it on the stride. I just don't have that in me. My feet hit like Playdough.
The fastest runners conserve energy. Arms bent, wrists about belly-button, waist level with feet traveling a scant inch or 2 off the ground.
What fundamentally changed my stride was switching to zero-drop shoes. The absence of padding in the heel drives a more forward ball of foot type stride. My plantar-fasciitis disappeared. My foot actually grew a full size, my toes spread out & I can now use them almost like fingers. But also importantly the stride became much less impactful. All the helper/stabilizer muscles & other soft tissues/ligaments began strengthen as they were incorporated into the stride.
Those kids with the spring in their step; They're doing it wrong.
Anywho, I'm now inspired to get outside to give it a give it a go. I haven't had a good run in a while now.
Cheers,
base2
Car dependency is a tax.
I used to post my nearly-weekly tris over in Addiction. Write up a nice race report and post it there!
Indeed.
What I see a lot of new runners do is high feet, high step, leaping with high arms against the chest or wildly flailing. Sort of like repeatedly re-enacting the overly animated stride the model did for the picture in the fitness advertisement.
Cheers,
base2
Cheers,
base2
I am potato.
Liked 1,631 Times
What is a "zero drop" shoe? Never heard of that before. As for the other things, I don't run for looks. But I already have big feet. I don't think I would be really happy about them growing any more. Although I definitely think I need to strengthen them. I just don't know how to go about doing that.
Nike Free are Nike's attempt. 5.0 being the most like a conventional with the most padding. The 1.0 being the most like slippers.
My wife swears by Xero. Though she still has heavy feet, she is no longer a heel striker. She wears them 12 hours a day in a production science lab.
I used to wear Vibram 5-fingers, but now wear some $45 Amazon brand...Whttn or some such. I too am on my feet for 8 hours.
They do take some time months to acclimate to when converting from super cushy conventional shoes. But it is nice to have tactile sense & feedback of the ground in every step to adjust your gait accordingly.
If nothing else, they are low stakes & comfortable to wear around the house. So you've got nothing to lose.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
The only plan I have is to finish. I want to do as well as I can, but the whole goal is to finish. My plan is pretty general. I swim with my upper body to save my legs for the ride and run. When I ride, I try to only ride at about 90% so I still have something left when I run. The only plan I can say I have for my runs is to just keep my legs moving. Regardless of how fast or slow, how steep or flat, I try to push myself to never walk. On both the ride and run, I try to pick someone out that's faster than me and keep up with them.
Also, if you have a few races, you can always push your limit and see how fast you can go before you blow up. It's probably faster than you think.
Oh and try to pass people on the run! Don't keep up. The second-to-last race I did was the 70.3 in Boulder and I was so shattered after that I couldn't think about talking without nearly throwing up. Was definitely blown up.
Zero drop shoes are often minimal, but not always - you can have a high-but-equal stack front and rear. Even Altra has different levels of cushion, though they're all zero. Most Hokas, I think, are low-drop at 4-6mm. Be careful trying though - running too hard or too much in them at first is a great way to strain your calves and Achilles.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
I typed out a few rude replies and cancelled each time. Sorry about him; just ignore him. Easier said than done I know, but really. Come on over to Addiction if you want to chat tri - I used to be a hardcore tri freak and there are one or two others who dabble in it over there. It can be a bit rough around the edges but nothing like that.
That's a good start. You can fold in nutrition and hydration (though I've done sprints with neither... not recommended though). You can also go above 90% for a sprint, if we're talking FTP. Test in the pool to see how much you gain with kicking in the swim vs not - a light kick might speed you up more than it costs you.
Is Addiction another section? I'll look around.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Not sure what you mean with stack and drop. My kick is absolutely worthless. One reason why I don't do it. But it's probably more form than anything. I do work on hydration and carb loading the week before. The first Olympic I did, I really didn't plan it well and I was wiped out, barely crossed the line before time cut off. I was literally the last person to finish before the race timed out. Last Olympic I did I carb loaded the week before and I did much, much better.
https://www.bikeforums.net/road-cycl...-2022-3-a.html
Quoted: 3241 Post(s)
Liked 2,512 Times
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
