SRAM 12 speed chain durability
How many miles are you getting from a Sram 12 speed chain on a road bike. I already have over 8000 miles and my Park Tool CC4 still shows less than .5 wear. It seems they last a long time when you keep them clean and lubed.
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
I've noticed they last an abnormal long time as well. I had a gravel bike that was set up with force AXS in a 1X configuration. After right at 5000 miles, I decided to switch to a larger chainring. I figured the chain was smoked and I would need a longer chain anyhow, but the chain had very little wear. I didn't trust the chain wear tool, and after holding it next to a brand new chain, there was very little if any wear!
Thread Killer
Quoted: 3272 Post(s)
Liked 1,813 Times
Yeah, isn’t there something about chain stretch gauges not being suitable for SRAM 12spd because of roller size or something, and the correct way to assess being to measure?
I have no idea what I’m talking about here, so I hope I’m mot confusing things…
Quoted: 523 Post(s)
Liked 664 Times
How long is a piece of string? Chain wear results from a number of things including chain quality, maintenance, riding conditions, gear choices, and rider power output. A light spinner who stays on the big ring (and therefore bigger cogs on the cassette), never rides in the rain, doesn't live in a dusty area and does a good job with cleaning and lubing the chain will get much more miles per chain than a powerful masher who stays on the small chain ring, never maintains the chain, and rides in wet and dirty conditions. Throw out the chain tool and measure chain wear with a ruler. Accurate, consistent, easy to do and provides a relevant measure.
Shawn of the Dead
Quoted: 277 Post(s)
Liked 449 Times
Quoted: 523 Post(s)
Liked 664 Times
The force per link on the chain is the total force divided by the number of links engaged. So the force per link is a lot higher on the 12t cassette cog (e.g 34/12 gear) than on the 18t cog (e.g. 50/18 gear). Same gear ratios, but a lot more teeth engaged by the chain in the 50/18 than in the 34/12. Plus in the 34/12 you're pretty cross-chained.
Likes For KerryIrons:
AXS chain users often think that their chain has little wear after 5000 miles, then put a new chain on and get new-chain skip because they didn't change soon enough. I alternate the use of several AXS chains per bike, so I'll never get new-chain skip and use each chain longer. With 10 chains in use, it will take a long time to figure out how long they last. I alternate chains about every 600 miles.
The best way to measure true chain elongation or change in pitch is with a 12 inch or longer rule. I have a scrap piece of tape measure with a pin through the 10 inch mark. I can lay the chain out on my work bench and get an accurate full length measurement.
Some chains don't show much elongation even though they have severe roller and side wear. The roller wear can cause new-chain skip.
Quoted: 523 Post(s)
Liked 664 Times
Quoted: 6393 Post(s)
Liked 4,991 Times
Electronic shifting might have something to do with it. Especially if you use full synchro shifting or what ever SRAMS equivalent of that is.
