Eroica California 2023 - Sept. 17, 2023 in Cambria, CA
#126
Quoted: 415 Post(s)
Liked 696 Times
Yes, it's COLD! The roads were still wet (in the shady areas) from the rain a couple days ago. Today's goal is to ride out past the lighthouse to where the elephant seals hang out. BTW, Madeline's in Cambria is a great place for a nice dinner...
#127
Quoted: 879 Post(s)
Liked 2,300 Times
I will keep that in mind , we usually opt for Linn's.The Elephant Seal rookery is actually just before Piedras Blancas Lighthouse(heading north). Leave early and catch the tailwind back!!
#129
Straps & Climbing
Yesterday I did my first serious l'Eroica training climb with toe clips and straps, Big Rock, paved 10% to 13%. I kept the straps loose fearing crashing if unable to unclip, this resulted in unclipping three times having and having to do a quick loop downhill to clip in again. I'm using Look slotted clip adaptors, 41 -28, 6 speed.
What do l'Eroica riders do on steep climbs?
Likes For santambrogio:
#130
Bikes: 57 ExpressWerke, 58 CinelliB, 62 CinelliB Altenberger, 70 Cinelli SC, 76 Masi, 77 Colin Laing, 78 Ritchey, 80 Jack Taylor, 82 Appel, 82 Davidson, 85 Ironman, 92? Andy Gilmour, 04 Peter Johnson, 91 Ed Litton, 11 Bianchi
Quoted: 99 Post(s)
Liked 458 Times
Better gearing? There are some seriously steep sections, pulling out one's shoe is almost unavoidable.
Guy
Guy
Likes For cinelliguy:
#131
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Quoted: 62 Post(s)
Liked 220 Times
Likes For fvernon:
#132
aka: Dr. Cannondale
Quoted: 2156 Post(s)
Liked 3,417 Times
Flat touring pedals. And more agressive gearing, like 28/34 low.
Likes For rccardr:
#133
I've committed (bought) a used set of Campy pedals and toe clips, shoes are laced Lake. The current Look slotted adaptors are plastic, I've got a set of aluminum adaptors to try, they might better engage with the pedals.
The 6 speed freewheel has been changed from a 13 - 26 to a 14 - 28, currently experimenting with chain length and RD position in the dropouts. Small - big 41 - 28 works, Big - big 52 - 28 looks too tight. The drivetrain is '80's SR, I've learned here that it can go up to a 28 cog.
The posts in BF are great.
#134
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4685 Post(s)
Liked 5,823 Times
We walk
edited: I found a better pic!
Likes For gugie:
#135
Quoted: 62 Post(s)
Liked 220 Times
Edit--I clearly wasn't thinking too clearly when I mentioned the SR crankset change--my mind immediately when to the Japanese brand, not the more obvious conclusion that you're running Campy SR.
Likes For fvernon:
Likes For Reynolds 531:
#137
Quoted: 1954 Post(s)
Liked 2,018 Times
Dig your enthusiasm santambrogio. With 9 months of training ahead of you, 41-28 is plenty low. Super Record with a 28? Maybe. If this is your first time, go stock OE. This will be my 5th one and my plan will be the same one I always use: get strong enough to ride the whole course with a 52/42-13/24. I’d hold off on using cleats on unfamiliar training courses. When you can do the dirt and climbs with clips and straps then try the cleats.
edit: my plan hasn't worked yet but I always have a blast.
Likes For Classtime:
#138
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,482 Times
Gearing to match your fitness level, and pull the straps nice and tight on the climbs. (Easy for me to say. I had several decades to learn how to reach down quickly and loosen the straps when needed.) Clips with cleats take practice.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Likes For obrentharris:
#139
Quoted: 4520 Post(s)
Liked 6,406 Times
Likes For merziac:
#140
Liked 5,823 Times
Likes For gugie:
#141
Liked 6,406 Times
#142
Liked 5,823 Times
I believe Wes had disengaged with Eroica California organizational duties since 2018. I was under the impression he later moved to Japan to care for an elderly relative. I don't know if he still lives in Paso Robles/Atascadero area or retains his farm and horses. I do hope he's at the 2023 event, he's a good guy.
Bart
Bart
It would be great to see him again.
Likes For gugie:
#143
I did get 31 and 29 cogs and now see that they will not work with the SR derailleur.
I'm looking for easy gravel routes around here.
#144
Liked 6,406 Times
The ride up Big Rock was done with a Regina CX 14 -28, it took moving the wheel in the dropouts. The top pulley is close to the 28 cog, with the wheel close to back of the dropout there is no noise or movement at the cage.
Here's a great recent thread.
https://www.bikeforums.net/classic-v...l#post22793437
Likes For merziac:
#145
Quoted: 3814 Post(s)
Liked 6,728 Times
I’d have to check, but I think my low gearing for last year’s CA Eroica was 30t large cog rear and 28t small front. Yeah, real low and glad I had it. Didn’t need to walk up any hills! Plus I was running flat pedals with no clips or straps.
Likes For nlerner:
#146
Liked 2,018 Times
You can go up Topanga to Dirt Mulholland and from the Nike Tower come back down Mandeville Fire Road.
#147
Quoted: 99 Post(s)
Liked 458 Times
#148
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,104 Times
santambrogio This is me in a 42-28 on Kiler in 2018. Probably the only 5 seconds I wasn't out of the saddle. In the couple of times since that year, I've "cheated" and used a compact crank but I hope to do it again one day on standard gearing. The bike I rode that year, a Tommasini, has some kind of magic and climbs better than any other bike I own. But barring a magic bike and especially since it sounds like your unclipping issue was more technical rather than physical, just keep training on the hard stuff. I would suggest losing the cleats for now and just go flat shoe with clips and straps. Also practice track standing (staying in one place with both feet in the pedals) as good ability with this increases confidence in staying in the clips for an extra second or two and reduces the likelihood of falling over. I learned this many years ago from a Ned Overend book on mtb skills.
Cosplay faux pas, jersey matches color but not brand of bicycle
Likes For Spaghetti Legs:
#149
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 268 Post(s)
Liked 326 Times
If I were still in my 20's and riding up Mount Baldy in a 39x25, I might well be tempted to take on Eroica with "heroic" gearing.
I am not, and I am not tempted. Each of the four times I've ridden it, I had low gears in almost a 1-to-1 ratio. Kiler and Cypress are both steep in sections (Kiler has steeper sections) and the gravel/dirt surface is such that you often can't stand up for more power. If you have the option to go for lower gearing and are considering it, I recommend it. It's still a challenging ride and a beautiful day out on the bike.
Likes For mhespenheide:
#150
Liked 5,823 Times
Gotcha beat, 24t front, 32 rear. Last year, for the first time ever I was able to climb Cypress without walking. I did, however did an involuntary dismount near the top. The last half mile or so I was not much over stall speed, 4 curves from the top my front wheel slid out on a rack and some sand, and I was suddenly looking up at the sky. Getting back up and running with toe clips and straps took 5 or 6 tries.
Likes For gugie:
