Flatbar trimming
Bikes: 1994 Raleigh MT200,,2022 Marin Four Corners ,1994 Cannondale T700,2019 Trek Domane SL7
Quoted: 35 Post(s)
Liked 289 Times
Flatbar trimming
Any downside to shortening an aluminum bar with a hacksaw?I’ve got a short wingspan and the 640mm is just too wide.
Quoted: 458 Post(s)
Liked 490 Times
As long as you keep it straight it'll be fine. I use a pipe cutter. As always, measure twice, cut once.
Likes For tFUnK:
Guest
Quoted: 1346 Post(s)
Liked 3,271 Times
No issues, but unless you have a guide for the saw it‘s hard to cut it straight. I use a rotary pipe cutter.
And you might be surprised at how easy it is to take off too much. Start with a smaller reduction than you think you need.
Quoted: 35 Post(s)
Liked 289 Times
Excellent tip about the pipecutter. I even have one,thanks guys.
Really Old Senior Member
Make sure you move the brake shift levers to the new position before marking/cutting. You don't want to find out you cut a bit too much.
You'll need a file or emery cloth to remove the burr. My tubing cutter leaves a knife sharp one. Not large, but VERY sharp.
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
/ yea \
Loosely mount grip, levers & bar end before you cut. Be sure it all mounts just outside the bend radius.
Likes For epnnf:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
640 is too wide? These days those are handcuff handlebars.
Likes For cxwrench:
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,311 Times
No matter whether yo use a hacksaw or pipe cutter, use a reamer or deburring tool on the cuts. I usually prefer the reamer. It’s faster than using a file.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1872 Post(s)
Liked 1,747 Times
Quoted: 35 Post(s)
Liked 289 Times
It’s the Windsor Tourist I bought for mostly pavement fitness riding and some bikepacking with gravel.I’m a short old guy(5’4)and they use the same bar length for all their bike sizes plus I mistakenly bought a size larger than I should have. I took 1” off each end giving me 23”(585mm).
Guest
Liked 3,271 Times
“I cut my handlebar three times and it’s still too short!”
Likes For Rolla:
