Continental Grand Prix 4000 Sll tire question.
There is 2 of these 700X28 for sale locally private owner new in box for $70 .. These seem to be discontinued but would they be
too old to buy and is that a decent price?
If stored properly, that’s a reasonable price.
I’d pay that.
Have been running these on my Cannondale ST for quite some time and they are great tires.
I’d pay that.
Likes For rccardr:
Crawlin' up, flyin' down
Liked 2,659 Times
I agree with Doc. They are good tires.
Likes For bikingshearer:
Bikes: Yes
Liked 4,112 Times
These are the tires I'm using on most of my bikes. I think it's only been a few years since they were discontinued. I would probably trust them.
On the other hand you can find the newer Grand Prix 5000 online for around $40 each, so I'd try to get the seller to lower the price a bit.
My Bikes
My Bikes
Likes For Andy_K:
Sunshine
Liked 7,743 Times
It's been over 4 years since the 4k was replaced by the 5k.
But yeah if they are in good condition and not cracked, that isn't a bad deal. It's hardly a screaming deal for 4 year old 4k tires, but jot a bad deal either.
Ride, Wrench, Swap, Race
Liked 1,339 Times
The 4000 tires are definitely a bit wider than newer 5000 tires, mainly to compensate for today's much wider rims.
The 28mm 4000's are quite plump.
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,654 Times
Liked 5,413 Times
Yep, I'm running a few set of the new 5000s tires now and they are all running undersize for me.
Steel is real...and comfy.
That's a smoking deal. Let me know if you pass, I'll take them.
The 4000s are 1) wider than the 5000s and 2) considerably beefier in terms of amount of rubber and sidewall material. I have found the 5000s very flat prone, the 4000s...not nearly so. The 28mm size for the 4000s is fairly rare too.
2019 Salsa Warbird
2019 Salsa Warbird
Might want to put eyes on the tires and check the date code on them.
https://www.continental-tires.com/bi...e-construction
If they're more than 6 or 7 years old, you might want to consider passing. Unless stored in an inert atmosphere or sealed container, rubber degrades over time due to slow oxidation. Ozone and exposure to certain chemical fumes can dramatically accelerate the degradation.
Depending on which source you want to accept, 6 or 10 years is the max recommended lifetime of auto tires. And auto tires have a helluva lot thicker rubber than road bike tires - and a lot more area over which to spread the load.
Liked 1,339 Times
Tires grow a bit with age, mostly within the first couple of days and rides and a bit more over a year's riding.
Tire pressure affects measured width as well.
13mm rims should be considered extra-skinny, modern road rims are about 18mm internal. Each 1mm of rim width affects tire width by almost .5mm.
My 5000's in the 25mm size are only 1mm narrower than 4000's on the same rim (once both tires have had some time and miles to settle on their dimensions).
By most reports, the 5000 is about the same as the 4000 in terms of mileage and puncture resistance. Their measured thickness at center is also nearly identical with both tires nearly 3mm and both using their super-thin and strong Vectran belt.
The 5000 is a couple watts faster (per tire) at equivalent pressure. I doubt that it's 1mm narrower width is causing that since they were tested at the same pressure.
I ended up getting the tires for $60.I'm not positive but I think they will fit on my 1989 Ironman.
Good score. Depends on which rims you have, if they're narrow you'll be fine, but if they're wide don't be surprised if those tires balloon out to almost 31-32mm.
2019 Salsa Warbird
2019 Salsa Warbird
I have the 25mm 4000s II on Mavic Open Pro rims on an '86 Ironman and they measure just under 26mm with about 90 - 95 psi.
I also have an '87 Ironman Expert with the unicrown fork with 27mm Vittoria Open Pave's that measure a bit over 26mm on the stock Wolber Alpine rims. There's not a lot of clearance at the closest points which seems to be under the rear brake and at the chainstays, and under front brake and at the fork blades - maybe about 4mm - 5mm. It's a comfortable amount of clearance but not huge.
