Strange hexagonal BB axle
Quoted: 5910 Post(s)
Liked 2,779 Times
Vaguely. I temember these as coming on relatively low end bikes from Germany, or elsewhere in northern Europe, in the late sixties and seventies. I sort of recall that it was something with an "H", like Heinemann or similar.
I hope that helps.
As I said, it's been a long while, but if you don't have the crank, I suspect that you won't find one easily.
I hope that helps.
Quoted: 6330 Post(s)
Liked 4,922 Times
There is a BB spindle on eBay with hexagonal ends Don't think it's quite the same as yours. But you might finds some hints in it's description to get you started googling for more info.
https://www.ebay.com/itm/284486113024
. However I wouldn't have any issue tossing that one in your bike and putting something more normal in it. Assuming the BB shell matches some standard in common use today. If not, I'd toss the bike to the recycling scrap yard too.
Quoted: 1321 Post(s)
Liked 1,959 Times
Toss out a bike that has hair growing out of it's joints? Pretty unusual phenomenon I think. Smiles, MH
SE Wis
Quoted: 2754 Post(s)
Liked 3,416 Times
Quoted: 4232 Post(s)
Liked 3,941 Times
I, too, have seen this type of crank/axle fitting. And like Francis I can't remember the brand or model names (although seem to think it was on a BMX/Freestyle bike) and agree with the speculation of not finding a replacement. If you pull the BB there might be some info marked on it. Andy
AndrewRStewart
AndrewRStewart
Apparently suntour made a hexagonal one called Hexon.
https://www.amazon.de/-/en/SR-Suntou.../dp/B002NN7JVU
Clark W. Griswold
Quoted: 4454 Post(s)
Liked 4,119 Times
Apparently SR Suntour (a different company from the original Suntour) made a hexagonal one called Hexon.
SR and actual Suntour are different companies, let's not get them confused. Maeda Industries went out of business and SR bought out the name.
SunXCD was founded by the former President of SunTour so it really has the lineage from SunTour
Quoted: 114 Post(s)
Liked 119 Times
So not sure what is going with the conflicting info.
Quoted: 2026 Post(s)
Liked 1,096 Times
You have to be careful with Amazon's descriptions of a lot of products. Many are improperly described and you have to know exactly what you are looking for. Bicycle components seem particularly prone to incorrect descriptions.
Likes For HillRider:
According to Frank Berto (see his "Sunset for Suntour" article), SR was bought out by Mori Industries (a Japanese steel tubing company) in 1989. In 1990, Mori bought out Madea SunTour, combining the two entities shortly thereafter. The resulting company was called SR SunTour (likely to make use of both SR's and SunTour's name recognition).
The bottom bracket under discussion in the Amazon link above was apparently made after Mori combined SR and SunTour. Given SunTour's extensive expertise with bottom brackets, I'd guess it was made by the old SunTour division - but that's only a guess.
Clark W. Griswold
Liked 4,119 Times
Um, no. SR never owned SunTour.
Unfortunately, the new SR SunTour management team either chose not to purchase (or were perhaps unable to purchase) SunTour's intellectual property, other facilities, and other tooling as part of the 1995 buy-out. Berto says Mori sold SunTour's remaining tooling for scrap (which included the tooling for the Superbe groupset) and sold the rest of SunTour's remaining facilities individually. He doesn't say what happened to the IP rights.
I did some further checking, and it appears that SR SunTour produced products using the Hexon crank interface as late as the early 2010s. (Unfortunately, I've been unable to determine when it first appeared.) Based on that fact, I'd guess you're probably correct in thinking it was developed after the 1995 management-buy-out vice something developed by the old Madea SunTour development team.
Likes For Hondo6:
You're most welcome. I especially enjoyed the late Paul Brodek's insider commentary at the end of that version of the article.
Got a copy of the latest edition of Berto's The Dancing Chain as a Christmas present. If the book is anywhere near as good as his "Sunset for Suntour" article, IMO it's worth every penny it might cost.
In general it seems like a strange move to go for a hexagonal axle like that. Only works with 6-sided cranks and square axles have been the norm for 100 years or so.
Likes For ign1te:
Liked 4,922 Times
6 corners will be harder to shear off than 4 corners.
Liked 4,922 Times
But you'd mused earlier and thought it strange......
The fact they didn't catch on shows that other designs for the spindle and crank arm interface were better than just the hexagonal. ISIS and Octalink being very common today.
