Tool needed for an early Cinelli headset?
blahblahblah chrome moly
There's only one tool for this:
Kidding! Those are super rare and $$$$ when you can find one.
Much more commonly available, the VAR #13 adjustable pin spanner, usually used on BB adjustable cups, can have the pins put in facing each other like this.
There was a Park pin spanner with the hooks facing inward, I forget the part number, no longer made I think. The hooks weren't round, but I filed them to round on mine, for use on a similar Bianchi headset.
That takes a steady hand and some filing skill to do it well. Use a fine file and go slow, take it down only until the pins barely fit, leaving them as large as possible for strength — since they aren't replaceable.
I have also done it with a cheap stamped-steel BB pin spanner where I just twisted both of the arms 90° until they faced inward. Can't find it though, sorry no pictures.
I started with one like this Park SPA-6:
Made of weak and malleable steel, so twisting was easy with a vise and an adjustable wrench. Maybe do-able with just two wrenches if you don't have a vise.
Mark B
Mark B
Likes For bulgie:
Old fart
Liked 3,683 Times
Agree. VAR-13 will work.
Tullio tool Nr. 772 -
