Bianchi questions
WGB
Bikes: Panasonic PT-4500
Quoted: 1811 Post(s)
Liked 2,368 Times
Bianchi questions
So I grabbed this bike.... For the BELT saddle, which I'll install elsewhere...
It's an odd one to me as I assume it's Japanese made, but it's built with Columbus tubing. The BELT could be a replacement someone put on and not factory.
Seat tube sticker
Fork sticker - one on each side
Serial number is LS321511. PO threw out the small chain ring as it was a triple, and the FD is a 300EX so doubting that's period correct.
Saddle is just a spare I had
Tiagra replacement RD
Is this a Japanese or Italian frame set?
Seat tube sticker
Quoted: 3861 Post(s)
Liked 3,445 Times
obvious respray -
no manufacturer is going to paint over a fork crown cap
also note the amount of rust on the details of the brake caliper vs the condition of the paint finish...
obvious respray -
Likes For juvela:
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 392 Post(s)
Liked 813 Times
Hello, this seems to be a repaint and the decals are definitely not original to the bike, these are repros largely based on the ones used on 80's racing bikes and the signature should be at the back side of the top tube. It does not resemble the Bianchis known to me, but it doesn't mean anything as I don't really know the Japanese models. Is it possible, that the fork crown's top part is the ususal removable chrome cap, and it also became painted? For the serial number, you can visit the https://www.bikeforums.net/classic-v...ber-guide.html maybe T-Mar already wrote something there, but be prepared you might find out it might not be a Bianchi.
paging Bianchigirll
Lattz
**EDIT: by the time I finished writing juvela beat me to it with the cap
paging Bianchigirll
Lattz
Quoted: 4554 Post(s)
Liked 6,513 Times
Bikes: a couple
Quoted: 563 Post(s)
Liked 869 Times
You might want to check that, and I hope I'm not seeing what I think I'm seeing
Liked 3,445 Times
noticed this as well...and wondered
flat surface of fork crown cap is not parallel to bottom edge of lower head race
wondered also about seating of fork crown race
its looking like WGB hath taken in something of a...
Likes For juvela:
WGB
Liked 2,368 Times
Im unfamiliar with the Bianchi brand so if it's wrong it's my bad. I wondered why the serial number wasn't lining up with the thread by @T-Mar...
It was $120 Canadian so not much of a loss. I believe the cup isn't seated correctly. I'll take it to a frame builder near here for a review. If he has concerns, I'll strip it for the parts.
BELT for posterity.
BELT for posterity.
Likes For WGB:
Liked 3,445 Times
as seen in last image above Belt brand saddles a product of Fujita also designated as Y.F.C.
there are also Belt brand saddle pillars
1964-1965 catalogue pages -
WGB
Liked 2,368 Times
I'm guessing mine is a "Standard model".
I like the look of those pillars, the model 1, 2 and the Hupel look very good.
@juvela I'm thinking that you must have stacks of old catalogues under your bed!
Liked 3,445 Times
Fujita offered a model of the Hupel Rider pillar during the bike boom era which expressed a very "copyolo" look
it came fitted to a number of topline Nippon products such as the Schwinn Voyageur by Matsus**ta
[images courtesy VB]
forum member VintageRide found a Belt pillar of the correct diameter for his P. Peschi project -
https://www.bikeforums.net/classic-v...-p-peschi.html
Quoted: 4722 Post(s)
Liked 3,046 Times
The serial number number format follows that used by Bianchi's Japanese source and indicates December 1983 manufacture, so it should be a 1984, Japanese manufactured model. Consequently, the Columbus decals are highly suspect. The post looks significantly smaller than the 27.0/27.2mm used by Columbus SP/SL. Also, the presence of dropout eyelets places in in the lower end of the range. I'm leaning towards an entry level Bici I or Bici II, assuming that it's from the Canadian side of the border. The post diameter may provide a clue as to the actual model.
Likes For T-Mar:
