Suspension Seat Posts?
Bikes: Spot ACME with Shimano Alfine 11 & Gates Carbon Drive
Quoted: 39 Post(s)
Liked 78 Times
I've been considering a suspension seat post for my Spot aluminum-frame bike. I ride every day and only ever own one bike at a time. I'd would like to smooth out the rough spots in the road and was wondering if any of you have experience with these types of seat posts. I'm 6' tall and weigh 202 lbs.
The two I'm looking at are the Suntour and the KINEKT
Have any of you tried either of these brands? Is there another brand you'd recommend?
I'm open to any input you can give me.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
The other major options are Cane Creek, Redshift, and PNW.
The simple telescoping springs are very common on e bikes and comfort bikes
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 685 Post(s)
Liked 951 Times
I have used the kinekt for years and it has been good. my wife has one on the back of the tandem. I love the seat clasp it makes accurate adjustment and repeatability easy.
Likes For fooferdoggie:
Quoted: 39 Post(s)
Liked 78 Times
I'm leaning towards the Redshift now (which is totally human powered BTW).
I really just don't see the point of an electric bike myself but maybe that's just me.
Quoted: 571 Post(s)
Liked 428 Times
Suspension seat posts fall into the category of saddles, meaning it's a hit or miss on trying them and finding one that you like, or perhaps not at all.
Having about a two dozen each saddles and seatposts on hand, each one of them and each combination of them gives a totally different response.
I feel that with the correct saddle, the suspension seatpost is not necessary at all.
I admit this is a bit harder for a typical consumer to figure out as they may have to buy and exchange a lot here. I'd find a good LBS that can help.
Likes For soyabean:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 682 Post(s)
Liked 767 Times
Besides cost, other trade-offs are more moving parts (noises, imperfect tolerances, and maintenance) and weight.
Likes For andrewclaus:
Quoted: 39 Post(s)
Liked 78 Times
I feel that I'm using the correct saddle; a Brooks C17 that I love. But having it coupled to such a rigid frame leaves a lot to be desired. Especially for this 70 year old.
Clark W. Griswold
Quoted: 4505 Post(s)
Liked 4,192 Times
Any of the pogo posts are cheap garbage. Going up and down only isn't good for your knees and it changes your position on the bike. The proper isolation post like Kinekt or even CC moves you down but back as well to keep your knees and body in a similar position.
Likes For veganbikes:
Quoted: 39 Post(s)
Liked 78 Times
Thanks for your input.
I ordered a Redshift ShockStop from Amazon and it'll be delivered today. I'll try it out and see if it works for me and if not, I'll return it and try one of the others mentioned here.
Quoted: 39 Post(s)
Liked 78 Times
I ended up going with the Redshift ShockStop and just go back from my daily ride. I couldn't be happier with this thing. I found myself chuckling a few times at how this seat post smoothed out the rough spots that I'm familiar with and have ridden over so many times over the years. My lower back felt so much better after this ride than it has in quite some time.
Quoted: 1009 Post(s)
Liked 1,695 Times
My brother is one of those guys that suffers with a bony arse. He is always looking for a softer ride and has spent quite a bit of money in his search. The one thing that really changed his ride was going to wider tires and a longer wheel base. The seat posts, bars and many, many, seats he has tried made little difference...
Likes For zandoval:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 427 Post(s)
Liked 1,011 Times
My Kinekt spring seatpost seems to basically remove about 3/4" to 1" worth of bumps, when set fairly lightly for my weight. It sure helps in a bumpy environment. I'm 65 and 215 lbs.
Likes For Fredo76:
Quoted: 39 Post(s)
Liked 78 Times
I've been riding with this new seat post for just over a week now and couldn't be happier with it. it really takes the edge off of the bumps in the road and my back feels so much better now.
Likes For Route 66:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I am considering this one which is expensive, but got good reviews:
https://www.ergonbike.com/en/product...sattelstuetzen
Likes For Lombard:
I'm around 220 pounds and 6ft3. I use a Suntour on one of my touring bikes. I bought it originally when I was getting a bit of back pain. I set the pre-load fairly high so that in normal use it wasn't moving but if I hit a large bump it gave a bit of cushion. Obviously really big bumps you avoid or stand out the saddle. I've now gone back to a standard post as my back has improved and the benefit is no longer worth the extra 500g.
As part of a weght reduction I saved nearly a kilo with a new seat post, lighter pedals, and a lighter rear wheel.
I also have a Cane Creek Thudbuster on my MTB. That gives a much softer ride. For outright comfort it is the one to go for. There is a bit of back to front movement as well as up and down but you get used to it.
Likes For irc:
Clark W. Griswold
Liked 4,192 Times
Great to hear! Some back issues is why I'm looking at these.
This is the experience I've had and as a result, how do you adjust the correct position?
The Redshift one is not a bad one but it is all adjusted at the bottom of the post so you cannot cut it down if needed and you have to deal with a greasy mess if you need to adjust and then you have to re-adjust your seatpost height each time and make sure it is aligned right. It is not a terrible thing but I would rather have my Kinekt. Now for a stem I think their stems look the best the Kinekt uses springs vs elastomers so they work a little better but they don't look as good.
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 58 Times
My wife's hybrid has an old CODA suspension seatpost. It's about 25 years old. I took it apart about 10 years ago and overhauled it. It still works well, but the adjustment nut is at the bottom of the post, so it'a a pain to adjust and obviously it can't be cut down. But the combination of spring, elastomer, and needle bearings gives it a certain smoothness I have not experienced with the "thudbuster" style seatposts.
I was able to replace the old elastomer with two sections of rubber hose, one smaller diameter inside the other and glued together with rubber tire cement. It has been holding up well for the last 10-11 years.
Likes For Keefusb:
Quoted: 458 Post(s)
Liked 490 Times
Hope it works out. I used a simple suspension seatpost on my hardtail mountain bike back in the 90s and it worked ok. I wasn't a serious cyclist then but I do recall it smoothed things out on the trails. Definitely pogo-ed a lot.
The modern designs look promising, but I cannot get myself to accept the weight penalty. My buddy has the Cane Creek and he loves it. Says it feels like he has a rear flat, and that's a bit distracting.
Keefusb
Quoted: 83 Post(s)
Liked 58 Times
IMHO, unless you are doing hard-core mountain biking on technical terrain, a suspension seatpost is a great alternative to a rear suspension. Generally speaking, they are lighter than a rear suspension, less fussy, and in many cases, they look better. With the explosion in popularity of gravel bikes, I'm surprised that we don't see more suspension seatposts being installed on gravel bikes.
Aaa
Quoted: 7 Post(s)
Interesting, the thing I was wondering is if a seatpost suspension could cause some strain to your legs/arms because they are still subject to harsh conditions.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 626 Post(s)
Liked 581 Times
On my own Trek 970, I've got a Cirrus Kinekt. With the right spring choice, it does well to mute most of the sharper, shorter-duration bumps that I would otherwise feel. Nice addition, for a hardtail bike.
Likes For Clyde1820:
