For the Brave...help me ID this one
I honestly think this frame is a Friday night special I have scanned lots and lots of vintage Pinarellos and have come up short. There will be elements that check all the boxes then, one thing will be off.
I welcome any suggestions of what I have and rough timeframe (I'm thinking early 80's). The chrome work is quite nice and honestly one reason I bought this on a whim - it would cost me double to rechrome it.
Don't be mislead by the decals -I've already actually changed most of those out. And apologies in advance for the photos, I'm new to posting on this site and am not sure how best to post thumbnails.
I'm really curious for your feedback (or confirmation that I possibly have a one-off that that they finished up late one night haha)
I'd guess later '80s, based on the "Pinarello" dropouts. It might be a Montello, but I believe those typically had a different bottom bracket & chainstay bridge configuration.
Really, the model name doesn't matter much -- what differentiated Pinarello road frames from this period was the tubing and paint.
Can you weigh it? Are there straight/helical ridges in the frame tubes / fork steerer tube? That's the (relatively) important stuff.
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1136 Post(s)
Liked 2,018 Times
chrome looks damn good to me.
But, if you really need, I know a place that does bikes for $200
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
Completely agree - the chainstay bridge is actually the most "unfinished" looking part on this bike - it doesn't have the typical lugwork that've seen (and I've never seen a Montello with a chainstay bridge). I'll see if I can weigh it and check on the other elements you mentioned when I get back home. Thank you for your input!!
Stop reading my posts!
Quoted: 1454 Post(s)
Liked 1,080 Times
well that's a beauty of a chrome Pinarello frame, congrats on owning it!
Only other clue, but one for the Pina experts: the BB shell is clearly a "custom casting" of a Cinelli SCM shell which has the "CINELLI" logo replaced with Pinarello branding, the single oval slot and distinctive "strap" cable guide they liked, also the piercings on the chatnstay socket tops (which are known as "can-openers" and distinguish this SCM version from the later Cinelli CCM shells). So most folks say the CCM was introduced "around 1984-5" exact date is unclear, question is did Pina have a big bin full of these "older shells" so they used them into later years, or...?
(here's a screengrab of a Cinelli catalog page that shows BOTH SCM and CCM were being offered at the same time, plus the "Spoiler" shell was on the preceding page! This catalog has the Flying C logo. All very mysterious.)
Likes For unworthy1:
I owned a Pinarello Record bicycle which I bought as a new frameset in September of 1979. I rode it for 13 years. My frameset's mechanical features matched those of my 1979 Pinarello catalog.
I estimate the date of your frameset to be 1982-1983, based on the following:
My frame had a semi sloping fork crown, not fully sloping like yours. And the chainstay bridge of mine was round tubing with chainstay gusset plates, not the square ended cast piece which your frameset has. My frame had exterior routing of the rear brake cable, with three braze ons on the TT.
Your frameset has the same lugs and bottom bracket shell as mine did. Later frames had lugs which 'swept back' in the upper corners. Later frames also had the fully sloping fork crown and the BB shell had the chainstay socket points on the sides, not on the top & bottom.
My late 1981/early 1982 Pinarello catalog (the front and back covers feature Giovanni Battaglin winning the 1981 Giro) shows both Battaglin's frame and the catalog frames having the semi-sloping fork crown. Battaglin's frame had exterior routing of the rear brake cable, with TT braze ons. That catalog also shows most models having TT braze ons for the rear brake housing. However, two models have internal routing of the rear brake cable: the Prestige S, built with ultralight Columbus KL tubes, and the TreCime, which is a Treviso type frame but the built up bike uses a triple chainring Campy crankset.
My 1981-82 catalog shows the same frameset (with 3 TT braze ons) used as Super Record, Record Special and Record bicycles. Those framesets used SL tubing. The Treviso model had lower grade Columbus tubing and much less chrome plating.
Although Pinarello frames were fully chromed and then painted over, I don't recall ever seeing a Record frameset which was fully chromed, without paint. I therefore choose to call your frameset a Record Custom.
On VeloBase, there is a gold plated Pinarello bike which is cited to be 1984. I believe this is the Montello model, since it has the fully sloping fork crown, the swept back lugs and the bridgeless bottom bracket shell.
(https://velobase.com/Velos/ViewModel...e46&PgOffset=0)
If you do a web search on 'Alexi Grewal Pinarello' you can find images of his 1984 bike. There is also a 1984 advertisement from Gita touting the Montello model with the bridgeless BB shell and internal routing of the rear brake cable.
(https://lh6.ggpht.com/_hSZo5vjiPmQ/R...wal%201985.JPG
The images of Grewal's bike further confirm that your frameset is pre-1984.
Your frameset is superb. Very well done!
Andrew G.
Andrew G.
Likes For Andrew_G:
Likes For ncracing72:
Crawlin' up, flyin' down
Quoted: 1054 Post(s)
Liked 2,605 Times
Andrew G.
Andrew G.
I did buy it from someone in Ukraine (if I recall correctly) and to be honest, that fork may not be original or the one that came with the bike.
As for the chrome - I do have a master Olympic art decor that I have sandblasted the paint off of and have found that although Colnago chromed the entire frame, it's not a "finished" chome, but more like a bumpy/orange peel type chrome for areas that would subsequently be painted. Do you know if Pinarellos are the same, or are they a smooth chrome finish under the paint of these types of frames.
So, I suspect that painted Pinarellos are not polished under the paint.
Chromovelato frames are the exception; the clear lacquer is applied over polished metal, which makes the finish delicate.
For reference, here's a photo of my 1979 Pinarello frameset, as restored by Joe Bell. The color is duPont Imron 'Light Continental Blue Metallic', which was the original color.
Andrew G.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 687 Post(s)
Liked 1,010 Times
very nice Pinarello steel frame
Likes For georges1:
The placement of the Pinarello fork threads similarly matches what Roland Della Santa did for my 2017 DS frameset, which he made for me.
Andrew G.
Likes For Andrew_G:
Quoted: 1087 Post(s)
Liked 1,915 Times
The serial number format in conjunction with the 'Pinarello' stamped dropouts suggest ~1987-1989.
As far as model, pretty sure the Treviso stuck with the 1010B dropouts.
As mentioned above, Montellos don't have a chainstay bridge.
I have not recently confirmed, but I recall (with high confidence) that the surfaces where chrome is visible are polished before plating. Surfaces which are painted over are generally not polished so that the paint has a rougher surface, which makes the paint adhere better.
Andrew G.
Andrew G.
I suppose that would narrow w it down a bit - but you don't think it's a Treviso do you? I wasn't aware of any that had internal top tube routing. I'll take a look at the models they sold during that timeframe too.
Liked 1,915 Times
A Treviso wouldn't be fully chromed though, so the question may be is it factory chrome or aftermarket?
Edit:
The fork should have a serial number stamped on the steerer tube, see if it matches the serial number on the BB shell.
The Treviso model does exist with internal cable routing, not as common as with cable guides and not shown in the available catalogs.
Edit:
European models came with a lot more options. For example, you could get Montellos with SL tubing. That may lend more weight to a Treviso with internal cable routing.
Edit:
Old fart
Quoted: 3617 Post(s)
Liked 3,446 Times
So I guess that would make it a Cinellirello
Quoted: 1150 Post(s)
Liked 1,784 Times
Most of the details match what I have, the differences being the badge and chainstay bridge.
I was thinking this red one is 86-87. I was thinking the fade paint jobs started about 87.
Im sure yours is a season or two newer than the red one.
Liked 1,080 Times
I'm sure I have seen a number of other (mostly Italian) branding replacements in the same shells, but can't recall which: maybe Battaglin and/or Guerciotti?
At least when they have it there's a slightly lower chance of another bike being mis-identified as a "Cinelli" in CL/eBay/FB/etc. ads by the uninitiated!
Old fart
Liked 3,446 Times
Likes For JohnDThompson:
Quoted: 1651 Post(s)
Liked 850 Times
The OP's frame is also missing the two "P" pantographed triangular gussets on top of the BB shell, so it is not a match for a Montello. More likely a Record or a Treviso.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 4260 Post(s)
Liked 2,977 Times
Beauty.
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 392 Post(s)
Liked 813 Times
ncracing72 it's a really nice one, no question, I think it might be aftermarket chrome, but I also have vague memories of at least one kind of atypical Pinarello where only the lugs were painted (I eally don't remember if the owner peeled back the remainings of an earlier cromovelato) shoot a few pics of the brake bridge, so far it could be an early Asolo Cromor but many other things as well...
What is really an interesting part is the BB-chaninstay lug with the cutouts on top. These were used on the Record frames and Super Record Special full bike (also the catalog shows this detail to draw attention on it) but it didn't have internal TT cable route. 85 was a phasing period, the only model with internal cable was the Montello 85. And there is an interesting twist, they show a photo from the 84' olympics.... Alexi Grewal on internal cabled bike(s?)...
now look at this thread, I explicitly don't want to imply or let you believe, that yours is a team bike or anything like that, although it could be. But what's sure is that the BB lug fits the bill with internal cables as well: Road Test/Bike Review (1985) PINARELLO Arco LA84
are your tubes squashed/pinched in any ways?
https://www.roadbikereview.com/threa...o-la84.352957/
Likes For Lattz:
