Question about sealed bearing axles
Velo Orange is selling Dia-Compe 126mm rear dropout-space freewheel hubs having modern sealed bearings, not cup and cone, with left centre-to-flange 41mm and right centre-to-flange 21mm. In other words a 10mm offset to the right would produce a 31/31mm centre-to-flange spacing to then build wheels with zero dish, strong wheels, which could be used by putting the 126mm hub into 138mm rear dropout-space along with a longer axle and necessary spacers. But as the question, can the original 126mm hub axle be removed and replaced by a longer axle, perhaps 12mm longer?
Liked 493 Times
You can re-space the axle however you want but all that does is move the wheel left or right in the dropout. How does this make the wheel stronger?
Edit: Ok I think I understand what you're trying to do. You're going to dish the wheel to have more balanced tension, and then adjust for this dish by respacing the axle.
Not familiar with the particular hub but every hub I've owned have had removable axles.
Some sealed bearing hubs uses axles with shoulders to keep the bearings in place. This eBay listing shows an example:
https://www.ebay.com/itm/392503230866
I'm not familiar with the VO hub in question. But if it uses a shouldered axle, finding one with (a) the shoulder spacing you need, and (b) of the correct length and offset to do what you want might be difficult.
In theory, yes. But there's a potential issue that may or may not arise if you try to do a swap.
I am 99% sure these hubs are made by Dia-Compe, a wholesale business which sells only in 100-unit lots, no retail, and Velo Orange has them made by Dia-Compe with VO markings; https://velo-orange.com/collections/...heel-hub-126mm I have old bikes with 126mm dropout spacing and already have two of these beautiful 36h VO hubs. I do not have the equipment to pull one of these hubs apart but there are several bike shops in the area where I am which likely do and can.
Yes, in theory, within 138mm dropouts these 126mm hubs could be located to produce wheels with no dish. Freewheel hubs are very reliable, in the 1980s I put thousands of commuter miles on them and 14-34T freewheels and 48/46-36/34-26/24T 110/74mm triple chainwheels are available today, fine for commuting and touring.
Liked 1,099 Times
Another problem I see with substituting a longer axle is the amount of unsupported overhang it will give on the nds.
I am thinking about solid bolt-on axles, not QR, and made out of hardened tool steel, expensive but strong.
6-speed freewheels work reliably well and are available today in a wide range of useful gearing at low cost.
But yes, front derailleurs would be necessary.
If it's a threaded axle, then you can easily replace it with a longer axle. If it's a larger diameter smooth axle - these are often times proprietary and you are not going to be able to find a longer version easily.
By the way what bike comes with 138mm drop out spacing, as opposed to the common 135mm (for MTB's)? For 135mm spacing, running a threaded axle freewheel hub is just asking for trouble. There is too much unsupported overhand on the DS. If you are obsessed with solving the dishing problem, the best approach would be to run a narrower 7 speed freehub. You can find early Deore hubs with 7 speed freehubs. Use a longer axle to space these out to 135mm. For further improvement, run an asymmetric (AKA off center) rim.
Looking at the pic of the VO hub, they have threaded axles. So the cartridge bearings on both sides are retained by a (likely) 12mm collar that is drilled and threaded to mate with a standard 10mm axle. I'd guess bog-standard 6001 carts. Suntour and many other freewheel hubs used this design.
So it would be simple to replace the old axle with one longer - cut to size of course. You'd also need some spacers to fill out the non-drive side. At my local Co-op, this whole operation would cost less than $5 and take less than 30 minutes, including cutting the axle to size with a hacksaw.
BTW: having a cartridge bearing exposed to the elements is not good design. Cartridge bearings feature simple rubber air dams, which are inadequate to protect against water, particularly water under any pressure. Cart bearing hubs can be adequate if they feature double seals, separated by an air gap, like the old Suntour hubs. But, they are still inferior to cup and cone hubs like Shimano, both in terms of design and execution. And freewheel hubs are inferior to cassette hubs in design and flexibility. I have dozens of high-end freewheel hubs such as Dura-Ace, Superbe Pro, Record, etc. Rode them for 3 decades; rarely any more.
https://www.modernbike.com/origin8-r...r--m10x135x145
The linked axle kit is for a freehub-type hub, not freewheel. But my point is that without seeing the internals or hearing from someone who has, we don't know what Dia Compe actually did when they made the hub.
I hope you're correct, as that would make the OP's conversion possible and fairly easy.
Here is the 126mm hub I am looking at; https://velo-orange.com/collections/...heel-hub-126mm Looking at the two images available there, threads apparently are on both ends of the axle which got me to thinking the axle could simply slide out once un-nutted. But I do not have X-ray vision to see what goes on inside the hub so here I am to ask about that.
Yeah, you are right about the axle strength, which has known limits. 130mm dropouts got invented to handle 8-speed freewheels but 8-speed freewheels then exceeded the axle strength and freehubs then became the way to go, assuming more than seven hub speeds would be needed.
Offset lacing is somewhat of a gimmick, looking great on paper but producing offset dynamic loading to flex the rim on every revolution of the rim, a bad design. The load should be on the centre of the lacing. Ask any mechanical engineer and they will tell you the same.
Altogether, it looks like a 126mm freewheel hub in 135mm dropout spacing could produce a near-zero dish, but perhaps not with these hubs. There is potential here but a stronger axle would be needed, perhaps a redesign of the hub to work with modern through-axle technology.
Likes For icemilkcoffee:
Yeah, I was thinking it would be simple to swap-over to a longer axle but here on this thread I have been reminded of axle strength limits as were discovered by 8-speed freewheels on 130mm dropouts. A near-zero dish could be developed but it looks like 12mm thru-axle technology could be necessary.
Freewheels are a reliably good technology, I have put many miles on them and for commuter/tourist use a 6-speed freewheel + triple or double chainwheels running on 8-speed chain could do practically all of what they would need, working well and lasting long.
I have considered 7-speed freehubs but have you tried to get replacement parts for those 30+ year old hubs? Freewheel hubs are reliably good for 5- and 6-speed and can work well with 7-speed but 7-speed freewheels did not always fit in 126mm dropout spacing.
So those bazillions of dished wheels scattered over the planet are engineering disasters on the verge of happening? How worried should people be?
Asking for a friend
Asking for a friend
Expired Member
