Trainer tire important?
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Liked 479 Times
For those who are using a wheel on trainer, is it important to have a dedicated tire that's "designed" to use on the trainer? I started Zwifting about 5 years ago and bought a new tire because I thought it was a trainer tire but it was just a road tire with red trim.
It's still going after all these years but I am noticing some rubber debris building up around the roller.
Bikes: '23 Devinci Hatchet Carbon Apex1 '19 Norco Bigfoot 6.1 ,'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Liked 128 Times
When I bought my trainer tire, the dealer suggested the trainer would probably eat a road tire and possibly throw tire shreddings/dust
No idea if it was a sales gimmick or not but the trainer tire has lasted WAY longer than any road tire I ever had
I read all the stuff about special tires, but decided to try a regular tire anyway and put on an older used tire that I wouldn't mind ruining. I now believe the special tires are just a marketing grab. I've had NO problems with a regular tire. It hasn't shredded or thrown rubber dust, nothing - perfectly fine. I've had it on my trainer for almost a year now and I'm not seeing any more wear than when I ride on the road.
Liked 687 Times
I've always used worn road tyres. They do the job. As long as it's a smooth-tread design it'll be quieter.
Trainer specific tyres are likely a harder compound so they resist heat and wear a little more. Just use whatever you have on hand. 🙂
When I had my Trek Pilot 5.2 on a dumb trainer upstairs on a wooden floor, it reverberated just enough that it made the whole floor hum. It wasn't loud in the daytime, but it carried through the wood enough that it would wake up the wife. A red trainer wheel stopped that.
Now that I'm in the basement, I don't use it. On the concrete it seems to be a non-issue.
Liked 479 Times
Ok, so I switched to the dedicated training tire and retired my existing tire but don't really see much of a difference and I think it's actually louder now ha ha. My experience with my bikes, the old saying, "if it ain't broke don't fix it" seems to always apply to every change I make.
Oh well, maybe the rubber debris won't be an issue any more.
Likes For gthomson:
I had older Vittorias on an old Trek I was using for trainer with Wahoo Snap/ERG wheel on trainer. It was squealing crazy so I got a dedicated trainer tire. Another Vittoria tire. It was quiet and no debris. I need to mount this on the newer Felt from 2014 that has the originals, but I just may wear that one out. BTW, trainer tire a little harder to mount as it's not very pliable.
Liked 479 Times
Not quiet though so wondering if I need adjust the tire pressure or adjust the mounting of the roller to increase or reduce the pressure.
Likes For gthomson:
I am potato.
Liked 1,741 Times
IME I went through a trainer tire about once per year. Road tires lasted between 3-5 weeks.
Car dependency is a tax.
Never used a trainer-specific tire on my wheel-on Wahoo, or previously on rollers. And have never seen shavings or tire dust either.
As long as your tire is relatively smooth, not knobbies, you should be fine.
That said, while riding a stage of the Tour de Watopia last week, I got a flat just as I crossed the finish line. Weird, huh? Patched 'er up and good to go.
(Maybe my massive power output heated it up to past the melting point of rubber!)
