My experience learning how to adjust the front and rear derailleurs
Recently bought a used bike. It was shifting horribly, chain rubbing very bad and noisy, rear derailleur clicking/popping, chain rubbing on itself (in the rear derailleur) while on smallest cog...
Spent many hours this week learning and working on adjustments... Was going to give up after the first day because I was having such a hard time. Stressed myself out trying to find a LBS (there are none within 45 minutes of me so I don't know where to go).... Spent more time learning and finally figured everything out! I feel so proud of myself!!
But kind of embarrassing... The last thing I needed to figure out was indexing. I couldn't do it because I needed to turn the barrel adjuster clockwise, but it was already turned as far as it could go...
Couldn't find anything helpful online (trying to google if my cable was too tight). Was ready to unclamp and loosen the cable...
Finally, this morning, I took a look and realized the bike has TWO barrel adjusters 😳😅. None of the videos or articles mentioned anything about two barrel adjusters (maybe assume we already know that???). I had been only using the one near the rear derailleur, but I vaguely remember earlier this week playing around with the one near the handlebars. I had that one turned counterclockwise all the way. Indexing was quick and easy after I adjusted it 🤣🤣🤣🤣
Quoted: 523 Post(s)
Liked 663 Times
Likes For wheelreason:
Quoted: 6392 Post(s)
Liked 4,987 Times
Two adjusters on the same cable just give you that much more available adjustment.
I'm just guessing that the one on the rear DR was almost maxed out one way or the other and the other just happened to have the needed amount of adjustment left.
You don't really add tension to the cable. The spring on the DR controls that tension and there is no adjustment of that particular spring. What you are really doing is more akin to shortening or lengthening the cable to where it attaches at the pinch bolt on the DR. Though you also could just have repositioned the cable in the pinch bolt and probably made the adjustment with just the one barrel adjuster on the DR itself.
Likes For Iride01:
Happy With My Bikes
Quoted: 888 Post(s)
Liked 2,359 Times
IMHO there is a well deserved sense of accomplishment that comes from figuring something out on your own. Congratulations
The most important thing is that you figured it out without asking first here so you didn’t have to read through 16 pages of arguments to the point that you didn’t want to even try.
Likes For Chuck M:
I don't know.
Quoted: 343 Post(s)
Liked 921 Times
woot! fixing a bike is very satisfying. Way to go.
Likes For RB1-luvr:
Bikes: Lemond Poprad, Cervelo Soloist, Cannondale F4, RANS Velocity Squared
Quoted: 42 Post(s)
Liked 67 Times
Well, I've been tinkering with my bikes for years and I still just turn one way...and if it doesn't fix it, just go the other.
I know it has something to do with lengthening or shortening the distance that the cable runs...I think.
Likes For BobsPoprad:
Quoted: 1649 Post(s)
Liked 1,875 Times
Likes For icemilkcoffee:
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
Personally I'd loosen the cable and reset the barrel adjuster so it does have some adjustment for the future.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2751 Post(s)
Liked 6,106 Times
Derailleurs can be a royal PITA to adjust for the newbie. Congratulations for having the tenacity to stick with it, figure it out and make it work. Well done!
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 1167 Post(s)
Liked 1,278 Times
Agree. Disconnect the cable, put both barrel adjusters in a middle position and reattach the cable. FWIW, I find I use the barrrel adjuster at the derailleur almost exclusively. The one on the downtube - on my bikes - is much more difficult to turn and the cable just doesn't seem to respond as smoothly as at the derailleur itself. Also, when I adjust the cable, it just seems more convenient: I pedal the bike with the right hand, adjust the cable at the derailleur with the left. I'm always looking/listening to the RD when Im doing this so it just makes sense to me.
Likes For Camilo:
Liked 4,987 Times
In fact out of the 50 plus years I'd say that only the last dozen did I ever have it all figured out. Partly because I finally read the instructions.
Likes For Iride01:
Quoted: 432 Post(s)
Liked 734 Times
Glad you've gained knowledge and experience on doing the adjustments! Saves trips to the LBS and if (when) the cable stretches, you can get it back to good shifting again! I know of a few who never did get der. adjustment down. Not too awful after you've done it a few times.
Likes For freeranger:
Quoted: 523 Post(s)
Liked 233 Times
You might take a trip over to the park tool website where there are links to many tutorials on how to maintain your bike: https://www.parktool.com/en-us/
It sure beats trial and error. The list for derailleurs: https://www.parktool.com/en-us/blog/...&area%5B%5D=52
It is one of several sites. The other one that gets a lot of attention is the Sheldon Brown website: https://www.sheldonbrown.com/
Quoted: 1885 Post(s)
Liked 1,759 Times
One of the first things yo do if asking questions about how to adjust something is to actually provide specific information about the bicycle and its components. In this case, the OP didn't do that, but still managed to sort things out without help. I fail to see the point of this thread
Likes For ofajen:
Quoted: 18596 Post(s)
Liked 16,097 Times
One tool you'll soon need is a RD hanger alignment tool. You can waste a lot time trying to get correct indexing when the real problem is a bent hanger. Parktool.com is the best place to look for advice and good videos.
Likes For DaveSSS:
This is encouraging! My slowest gear is slipping on the rear of my Trek DS 8.3, and it seems that a minor adjustment is all that is needed. I've been working up the courage to try it, and it seems like it will be fairly easy to do after watching the referenced Park Tool videos. The advice about watching what happens is good... in theory I know what it is supposed to do, but I haven't yet done it myself. I'll take all of this advice and give it a shot.
it's fine now. I had one of the adjusters turned all the way in one direction, so there was nothing I could do with the other adjuster to properly adjust indexing. now they are both somewhere in the middle so i could do fine adjustments using either one in the future
I had no idea there was more than one adjuster for the same cable, and I guess most sources (even for "beginners") just assume you already know that?
Quoted: 3663 Post(s)
Liked 3,104 Times
I'd close both barrel adjusters, or at least close them, then maybe back off a turn. There's usually little need to loosen cables; most likely you will need to tighten them using the adjusters.
Likes For smd4:
Grupetto Bob
Liked 6,106 Times
Changed wheel sets this week, and each had a rear gear cluster but with different ratios. When I switched back to the originals the alignment to each cog was off just a bit and I couldn’t shift to the largest cog. Weird. Tried using the barrel adjuster and got the alignment in place but still couldn’t get up to the largest cog. After a lot of fiddling I had to pull the cable more taught and resecure it and now it gets were its supposed to go. I find it odd that with virtually identical wheels but with different gearing that the cable would have become stretched. The thing is the cluster I switched temporarily to had two less teeth. Twilight Zone.
Mad bike riding scientist
Quoted: 6296 Post(s)
Liked 4,332 Times
That's very true. And for me being a tinkerer that didn't like to read instructions for much of my younger life, it took me quite a long time to figure out the mysteries of the DR. So I was turning things without really understanding what they did. Many times I was turning the limit screws, which basically don't affect the actual shifting.
The “aha” moment that came to me long (long, long, long) ago was when I realized that the vast majority of derailer problems are due to cable stretch. Once you realize that, you become a derailer whisperer and even a wizard to most people.
Stuart Black
Stuart Black
Likes For cyccommute:
Grupetto Bob
Liked 6,106 Times
Likes For rsbob:
