Tools for a Super LeTour?
Hi, folks.
I just bought a 1977 Super LeTour 12.2 that gets here Monday.
My other bikes are much more modern (threadless headsets, hydros, etc.). Any tools / parts I should pick up while I'm waiting for it to arrive? Thinking mostly of any BB/freewheel tools, anything I'd need to remove the old headset and clean/lube it, etc.
Also, if you have suggestions for good 5-speed freewheels and chains, I'm all ears! Thanks!
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1302 Post(s)
Liked 749 Times
https://bikehistory.org/bikes/letour/
This is a more "modern Schwinn"... they used world sourced parts and moved away from the proprietary items of past Schwinn "glory"
Really Old Senior Member
You might mention what tools you have so we don't have to start with a "set of ........
I wouldn't order specific tools such as BB & FW remover until I verified the one I needed by seeing the part in question.
Parts get changed, so one can't assume they are original and would therefore require a specific FW remover or BB wrench(es)
Likes For Bill Kapaun:
Quoted: 3634 Post(s)
Liked 3,062 Times
For the headset you’ll probably need a 12” adjustable (Crescent) wrench and appropriately sized headset wrench. The Park HCW-7 should fit, but measure for sure. If you’re going to service the BB you’ll need a crank puller and probably a lock ring tool. The Hozan C-205 isn’t bad. I’d also pick up their excellent fourth hand, C-356. Some good open and box end wrenches. A good pedal wrench. I like the Cyclo one from England. You probably have the necessary screwdrivers. That’s a start, I suppose.
Thanks. It's all-original (and all chrome!) except for some bar-end shifters, saddle, and tape. Pedals, crankset, freewheel, cables are all 1977-vintage. Shimano 60 up front, first-gen 600 on the back.
I have pedal wrenches, BB tools for Shimano road (BSA) and Hope mountain, various open wrenches. I assumed I might need some specialized tool for the freewheel, but I guess I'll know soon enough.
Liked 3,062 Times
Liked 749 Times
Liked 3,062 Times
Liked 3,062 Times
Likes For smd4:
Quoted: 2026 Post(s)
Liked 1,097 Times
Likes For HillRider:
Clark W. Griswold
Quoted: 4495 Post(s)
Liked 4,178 Times
I don't know what tools you will need because I haven't seen the bike and it doesn't sound like anyone yet knows what those changed parts were changed too. What I will say in every single situation unless purely using it for a 1 time use and never needing it again always always always get the best tools you can buy. Good high quality tools will last a long time but more importantly not damage any parts (if used correctly) and be more pleasurable to use so you will use them more often. The tools you use the most like the basic stuff (hex wrenches, screwdrivers and the like) those you really want to splurge on and as you use them less you can start to spend less and if it is really a 1 time use thing, just take it down to your local shop and let them take care of it save the money and the time and get more riding in.
Once you use a really nice set of hex wrenches or something like that you will understand. My father who knows little about bicycles or bicycle maintenance but understands tools from hobbyist wood working held my Abbey Decade Chain Tool in his hand and without knowing anything about it said "wow this is a nice tool, what does it do". There is a certain satisfaction with having nicer tools and using them. If you enjoy bicycles and working on them the multitudes of dollars you can spend on tools is well worth it. I have seldom regretted a nice tool purchase but always regretted a cheap tool.
