That creaky bottom bracket...
Bikes: Bicycles? Yup.
Quoted: 492 Post(s)
Liked 1,653 Times
Was actually chainring bolts that needed tightening. But I did get to change a press fit BB twice.
Likes For BTinNYC:
Quoted: 4232 Post(s)
Liked 3,940 Times
I find ring bolts are often dry of lube and rarely checked for tightness. Since they are easy to check for tightness this is one of the earlier things I do when chasing crank noises. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 4557 Post(s)
Liked 1,697 Times
"Creaky BBs" are actually creaking only about 20% of the time.
Likes For Kontact:
Liked 3,940 Times
I have thought of LockTight for threads as being a somewhat last resort. Having drilled out too many ring bolts that were frozen but still loose I like being able to easily tighten or remove, clean, lube and reinstall them. IME fine threads want little or no threadlockers. Andy
AndrewRStewart
AndrewRStewart
Liked 1,697 Times
Likes For Kontact:
Likes For Lombard:
Quoted: 117 Post(s)
Liked 26 Times
I had a creaky BB30 BB on my new Cannondale Synapse a few years ago.
I tried everything with the BB30 brgs. Removal, re-installation, and using a special sealant. I spent a lot of time with the BB, and even contacted Cannondale, but the problem continued.
When I removed the chainrings from the crank, cleaned, lightly sanded the matting surfaces, greased and re-installed them the creaking disappeared; I used loctite 202, and torqued them to specs.
Whenever the creaking re-appears which happens after a year or two I follow the same procedure to eliminate the creaking. This procedure is always successful.
Likes For yannisg:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Liked 1,697 Times
Liked 1,697 Times
So this seems unlikely.
Sock Puppet
Liked 863 Times
Except that for awhile, Cannondale was putting chrapo FSA Gossamer cranksets on bikes - I presume as a cost cutting measure. After 4K miles of substandard front shifting, I ditched it and got a Shimano 6800.
Liked 1,697 Times
So were tons of other companies. Yet FSA Gossamer cranks don't have a reputation for creaky chainring bolts.
Quoted: 117 Post(s)
Liked 26 Times
My Cannondale synapse HiMod BB area started creaking after 2 years. I estimate about 8k klm during that period since I was using the bike only for races and brevets and not for training.
After using the procedure mentioned in my post above the creaking was eliminated and returned after 2 yrs, and again I used the same procedure; 5 years later (a month ago) it returned. Using the same procedure the creaking disappeared.
Both BB brgs turn smoothly to the feel with the DS very slightly less.
I have never found the chain ring bolts loose.
Since the creaking goes away with this simple procedure I don't plan to change anything.
I understand if I was to replace the crank with a Shimano I would have to install a sleeve in the BB, and have read that this setup can creak also.
PBP Ancien (2007)
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 77 Post(s)
Liked 156 Times
I always check the chainring bolts before stripping out the BB. In the summer months I've had good results by simply laying my bike down (drive side up) and applying lube (not WD40) to the chainring bolts. The sun warms up the chainset and you get good penetration of lube and it can save a lot of work. It's not 100% effective though and it didn't work for the dreaded 'Cannondale Creak' on my CAAD12.
