Modifying a Redshift shock stem
I'm not talking about the metal parts, but has anyone modified the elastomers? My idea would be for the stem to be softer for the initial travel and then stiffen up for bigger bumps. Another package is 12 dollars so it might be worth an experiment. My thought would be to either drill holes or to cut one elastomer down so the other one is working first. I also realize that with only 20mm travel there simply isn't much to work with.
With a mighty wind
Quoted: 1115 Post(s)
Liked 912 Times
Ride it like it's a rigid stem and be psyched that it's a little forgiving.
Likes For rosefarts:
Quoted: 427 Post(s)
Liked 340 Times
+2 Rosefart!
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 337 Post(s)
Liked 786 Times
I’ve used one before and it did what I needed. Seeing as it’s designed to be used with as little as only one elastomer, I can’t see any harm in putting in a second that’s been altered. My new bike has the Specialized shock post which I like a bit better but I’d still use a Redshift without hesitation. If aesthetics matter to you, BMC makes their own version of the Redshift that is much sleeker looking and uses all the same elastomers.
