70s and 80s Road Bike Brake Levers
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 206 Post(s)
Liked 71 Times
For say the 70s and 80s, are all the different road bike brake lever brands compatible? Could you use Campy levers with Dia Compe brakes? Could you use Dia Compe levers with Universal brakes? Shimano levers with Campy brakes? I've been searching for an answer and not had luck finding one. Thanks in advance for any responses.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,452 Times
Yes. I never used Campy but used DC with Universal, DC with Modolo, etc.
Likes For thumpism:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3936 Post(s)
Liked 6,622 Times
Campy goes with everything. But if you have a full Campy bike, I wouldn't put Dia Compe levers on it.
Likes For SurferRosa:
aka: Dr. Cannondale
Quoted: 2172 Post(s)
Liked 3,519 Times
Yep, until Shimano SLR was introduced in 87, everything was pretty much interchangeable.
Likes For rccardr:
señor miembro
Liked 6,622 Times
There's one setup that doesn't work very well, and that's using an aero lever for the front, mounted on the normal, left side paired with a much older side-pull that has its cable entry on that same side. If you wanted to do this, it's almost better to switch the levers, front-to-right, British style.
señor miembro
Liked 6,622 Times
Another one that someone pointed out today is pairing a lever without a quick release with a side-pull also without a qr. It's doable, but you might need to deflate the tire to remove it.
Quoted: 1087 Post(s)
Liked 1,918 Times
Or wind up the adjuster, aka slow release, if there's enough thread available.
On one of my bikes I need to deflate the (25c) tyre to get it out of the dropouts due to the close proximity of the seat tube. Two birds, etc.
A common problem here in Australia where the convention is to have the front brake on the right side which creates a dicky cable arc. Hence why I set my bikes up 'Euro' style - left lever to front brake.
Likes For P!N20:
señor miembro
Liked 6,622 Times
Quoted: 1624 Post(s)
Liked 2,245 Times
Form over function? Right to the front for me. Been that way for 50+ years. Dave Moulton does the same.
Quoted: 99 Post(s)
Liked 154 Times
Since the topic is current... I need to replace some dia compe aero levers that are in nasty shape. Taking recommendations for aero levers that have the vintage look... be they 80's/90's or new production. Wouldn't hurt if they're italian but hey.
Likes For P!N20:
Quoted: 1090 Post(s)
Liked 708 Times
https://www.amazon.com/Dia-Compe-Dri.../dp/B09HXJ35P9
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 392 Post(s)
Liked 813 Times
Liked 1,918 Times
Liked 2,245 Times
@P!N20 - For me, being right-handed and a former motorcyclist, the right hand is preferred for front wheel braking, functionally.
aka: Dr. Cannondale
Liked 3,519 Times
Quoted: 392 Post(s)
Liked 813 Times
Only in the sense that SurferRosa mentioned above that the Deltas don't have a quick release, so it's good to have one on your lever. Other than that it's just pulling a cable. Remember Campagnolo invented the 'gruppo', and prior to that riders mixed components as they saw fit.
Quoted: 3636 Post(s)
Liked 3,062 Times
Quoted: 392 Post(s)
Liked 813 Times
Liked 3,062 Times
Likes For smd4:
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Old fart
Liked 3,454 Times
Likes For JohnDThompson:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1300 Post(s)
Liked 3,757 Times
Likes For AdventureManCO:
