Sizing a classic cyclocross bike (Ritchey Swisscross)
Quoted: 99 Post(s)
Liked 154 Times
Hi all I am looking for an older cantilever brake style Ritchey Swisscross. In a very general sense, would I look for dimensions similar to my classic steel road bikes, such as my 90's Lemond Alpe d'Huez or my '69 Bottechhia? I'm confused by the size charts I've found online as the Large nominal 57 does not sound all that large to me. I am 5'-8" and intend to use the bike for road and gravel riding, none of it competitive. Will use the largest tires that fit, presume 38 or maybe 40 if 650b. https://geometrygeeks.bike/bike/ritc...nti-2012-2017/
Ritchey's website (which only shows the new model) doesn't have sizing guidance by rider height. https://ritcheylogic.com/bike/frames...-disc-frameset
My two road bikes measure as follow, and they're comfortable to me. I ride them with very little seatpost stick-out.
Top Tube C-C: 58.5 Bottechia, 57 Lemond
Seat Tube C-Top: 58.5 Bottechia, 56.5 Lemond
Standover 80.5 Lemond
Also... if ya got a Ritchey gathering dust, send me a pm
I had the original Swiss Cross, in the late 1990s. Should never have parted with it.
I'm 5'11" and wear pants inseam of 30". I had the 58cm Ritchey originally but ended up trading it in for the 56. For me, that was a perfect fit. Since then, I've owned a 55cm Lemond Poprad and now have a 56cm Gunnar Hyper X and a 56cm Surly LHT. Attaching pics of the three bikes so you can see how much seatpost I have showing.
Quoted: 99 Post(s)
Liked 154 Times
Much appreciated. I called Ritchey and they said "Small" aka 51cm is recommended for "5'-3" to 5'-8". I know that lots of seatpost seems to be the way for compact frames but this being a more or less classic road frame I'm not seeing why I wouldn't aim for a larger size and use less post. Photos of my two road rigs below.
Ritchey also advised that Reach and Stack are the dims they'd pay most attention to. Again this steers me closer to the 57cm.
Reach Bottechia: 40.5cm
Reach Lemond: 41cm
Reach SC 51cm: 37-38cm (canti vs disc)
Reach SC 57cm: 39cm
Reach Lemond: 41cm
Reach SC 57cm: 39cm
Habitual User
Quoted: 5101 Post(s)
Liked 8,407 Times
Hmmm...My thought would be much smaller, but people have their own preferences. I'm 5'-9" with a 32" inseam. My Lemond Zurich was a 53. Most of my bikes are 54 or "Medium".
Does it work to use a frame built for 700c rim brakes with 650b wheels? I would think the brakes wouldn't line up properly, but maybe I'm wrong.
Quoted: 99 Post(s)
Liked 154 Times
I should say - both my roadbikes landed in my lap and I've ridden them for years. I never fussed much over their fit but they both feel good. The only new bike I've bought and consulted on sizing for is so different its not useful (small Cotic Flaremax full susp)
Reach Lemond: 41cm
Reach SC 57cm: 39cm
Reach Lemond: 41cm
Reach SC 57cm: 39cm
Quoted: 99 Post(s)
Liked 154 Times
Thanks all. Im looking at the Canti frame from the 2010s with carbon fork and revised headset. Yes i want to ride on and off road. Some pure road riding then as gnarley as I feel happy doing on approx 38s with mild knobs maybe. I think I found a 55 that could work…
Habitual User
Liked 8,407 Times
I'm doubtful that the frame will fit 38s, but I could be wrong. CX frames - particularly of the cantilever era - were often designed around the UCI max tire width of 33mm.
Likes For somebikeguy:
Quoted: 99 Post(s)
Liked 154 Times
Recall also reading that 650b doesn't buy much addl width on account of the chainstay shape.
Would be happy to hear from someone who has tried!
Habitual User
Liked 8,407 Times
Lots of good tire options out there. I'm currently really enjoying a 35mm Pirelli Gravel M (front) and H (rear) combination on my gravel bike. They roll pretty well on the road, and grip as much as I need in dirt (which typically includes singletrack with some moderately chunky sections). I've run 38s and 40s on my bike, as well, and have found that the 35s serve me just fine. That said, lots of folks are happy going wider.
Habitual User
Liked 8,407 Times
How would that work on a rim brake bike? It seems to me that the brakes wouldn't line up with a different rim diameter. Maybe I'm missing something.
Quoted: 99 Post(s)
Liked 154 Times
With caliper brakes you have bout 20mm adjustment, after that you buy long reach brakes ie tektro. I dont know about cantis, maybe someone can weigh in.
Habitual User
Liked 8,407 Times
You might want to research that a bit more. As I understand it, even long reach caliper brakes don't have enough adjustment for 650 wheels on a frame built for 700s. They also suck for power. With a cantilever brake, the brake posts would need to be moved lower.
Quoted: 99 Post(s)
Liked 154 Times
Yep for sure and what I was saying is that my understanding is the swisscross will handle the tires I want to run at 700c and there are very small returns from going 650 ok this particular frame so Ill likely stick with 700.
I wouldn’t try and mess with the wheel size on a rim brake cx bike regardless. The chainstay shaping thing is about the current disc bike.
Quoted: 1455 Post(s)
Liked 2,059 Times
