80s Mercian? Patina
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 419 Times
80s Mercian? Patina
Picked this up for $2 yesterday.
Would love some info/opinions about it
I always thought mercians were super cool and have half considered buying a new one before.
As for the plan... I thought i'd be scrapping it with rust holes but I haven't found those yet. It's not my size. Weighing up coating with penetrol vs repaint, if it is indeed solid metal on further inspection.
Likes For Soody:
Bikes: Indeed!
Quoted: 1521 Post(s)
Liked 3,537 Times
That's the nicest $2 bike I've ever seen!
Since you say it's not your size I would suggest giving the frame a good oxalic acid bath so a prospective new owner can see clearly what they're getting into, then send it on its way to someone who can ride it. Let the new owner decide how they want to finish it.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 546 Post(s)
Liked 1,080 Times
I don't know why I am drawn to Mercian bikes so much. Maybe the way they have continued to be made in the small British shop for several decades with hardly any change to the method. If I found one for $2, I would find whatever stem and seat post it took to make it ridable.
You didn't say if it was too small or too big. If too small, you could put flat bars on it and make a theft resistant errand bike. I did that with a Takara that I bought for $5. I bought it to scavenge some parts from it. Then I replaced them with some lesser parts to make it back into a functional errand bike.
Takara Advantage
Takara Advantage
Likes For P!N20:
Quoted: 275 Post(s)
Liked 419 Times
Takara Advantage
Takara Advantage
55cm TT 54cm ST
Quoted: 275 Post(s)
Liked 419 Times
Quoted: 275 Post(s)
Liked 419 Times
Likes For Soody:
Bikes: Indeed!
Liked 3,537 Times
If you enter "oxalic" as a search term in the forum search function you will get lots of information as there have been numerous threads here about how to use it.
Brent
Likes For obrentharris:
Quoted: 847 Post(s)
Liked 2,219 Times
^+1 to this. I use about 1 tbs per gallon (hose in one hand, soup spoon in the other, meanwhile counting seconds - not an exact science) and frames takes 24-36 hours. Periodic monitoring is important.
I also keep a smaller, more concentrated container on my workbench for small parts like bolts & nuts, toe clips, bottle cages, etc. Maybe a couple+ tablespoons for a quart. That’ll clear the small bits overnight; just don’t forget about it for too long.
Quoted: 3874 Post(s)
Liked 3,482 Times
you may be surprised at just how much of the original colour shall reappear following the OA immersion...
do any of our Mercian experts recognize a model for the frame? was thinking possibly an Olympic.
lug pattern appears to be Prugnat S. crown an altered Vagner DP+.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 427 Post(s)
Liked 1,012 Times
I would inspect it for holes after a good, long, thorough sand-blasting...
Liked 3,482 Times
Likes For jethin:
Quoted: 275 Post(s)
Liked 419 Times
Ok i'm gonna do the Oxalic bath.
... that should free the seatpost right?
Quoted: 275 Post(s)
Liked 419 Times
another bike fished from the same creek
also $2
I think this one is truely f'd
sad thing is these bikes haven't even been ridden much
they're kinda in really good condition
also $2
Quoted: 1119 Post(s)
Liked 1,351 Times
Aluminium parts in contact with steel and oxalic acid solution get a grey discolouration. so there's something chemical going on.
I would worry that either or both of
a) the post growing bigger
b) the chemical reaction between the steel and the acid would be changed such that the steel s harmed/weakened
might happen.
That's a closed-top post, upside down for a while with a lye solution poured in through the bb is harmless to the steel.
Quoted: 1088 Post(s)
Liked 1,925 Times
Is the serial number still legible? That will tell us the year and the builder's number according to CR:
Mercian frame numbering consists of the number of the frame built that year followed by the year of manufacture, sometimes this system was reversed to have the year of manufacture first.
For instance 26876 would be the 268th frame built in 1976, so obviously your frame wasn't built in 1933 or 1937, also there should be a single number near the main frame number denoting the builder of the frame
That's New Zealand dollars which equates to about 50c USD.
Groupetto Dragon-Ass
Quoted: 417 Post(s)
Liked 797 Times
I think that Mercian still has their records and used to look up year and model for you - but I have heard that they started charging for the service.
They ID-ed mine as a 1987 Mercian Olympic. From comparing it to other Mercians, it seems like a reasonably priced sports-touring frame with no name on the seat stay caps.
Likes For Chuckk:
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 326 Post(s)
Liked 697 Times
I can’t wait to see how this turns out after the OA bath. After looking around the internet for awhile and comparing, I’m pretty sure juvela is correct that it’s an Olympic model.
Quoted: 275 Post(s)
Liked 419 Times
Two people wailing on the post in a vice didn't budge it. Or snap the head off, surprisingly.
trying some vinegar
and on the stem on the centurion
overfilled but poured some out
how long?
trying some vinegar
how long?
Quoted: 275 Post(s)
Liked 419 Times
Might do, but I'd try to get it out some other way instead, before oxalic acid.
might happen.
might happen.
ah man i thought lye was an acid too and vinegar would be similiar. But it's alkaline. Next time I will try lye.
Quoted: 275 Post(s)
Liked 419 Times
serial no: 56884
so 1984?
so 1984?
Likes For Soody:
Quoted: 326 Post(s)
Liked 697 Times
