120 psi on 26x 1 3/8" tires?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Liked 980 Times
I need some new tires on the Sports, and happened upon the Bontrager T1's. My present (original?) Regency tires have a max. pressure of fifty-five psi. These new Bontragers have a psi of one hundred and twenty. What are your thoughts on running high-pressure on Westwood rims? Even if I preferred it, which I tend to doubt, would it be safe? Would it be safe to run 120 p.s.i. tires at 50 p.s.i (which I presently use)? I have taken the Sports on informal club rides with older riders, and the higher pressure would help me to get up the hills. I don't want a jarring ride quality, though. What is the thinking on these tires, and why are 26 x 1 3/8" (590) tires manufactured at road-tire psi?
https://www.trekbikes.com/us/en_US/e...olorCode=black
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Insane Bicycle Mechanic
I doubt the 26 x 1 3/8” version is rated at 120psi. (The 700C version, maybe.) I’ve never seen a 26 x 1 3/8” rim with hooked beads, which are needed for such a high pressure tire.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Standard Member
Liked 980 Times
You are correct. Trek just confirmed that this size is rated from 70-100 psi. That still sounds a little bit strange for a 3-speed, though. I am not understanding what kind of bike this tire is designed for.
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,654 Times
Liked 4,083 Times
But - tubed clincher wasn't a choice? I don't think I am the only one who still riders them. (Should I run out and buy a lifetime supply of tubes? A nitrogen gas filled freezer?))
señor miembro
Liked 6,654 Times
Ride, Wrench, Swap, Race
Liked 1,339 Times
There are tandems and perhaps loaded tourers riding on 26x1-3/8" tires, somebody had to make tires suitable for them!
Indicates a strong tire casing, so likely durable.
Likes For dddd:
Standard Member
Liked 980 Times
I skipped the Bontragers and committed to some N.O.S. vintage 590's, which are Michelin, made in England white-walls. I just did not want a harsh, high-pressure ride. Thanks for the suggestions, Jeff and Surfer.
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Liked 330 Times
Sun offers the CR-18 in 590.
Likes For PhilFo:
