Replacing Shimano Ultegra Chainrings.
It's time. From what I can tell, it is a simple matter of loosening the bolts and sliding them off. Correct? I don't have the tools to remove the whole crankset.
Ultegra version 6800, I think.
FWIW, I think I rode 20 years on my old Campy Record cranks and they still look great.
Quoted: 18461 Post(s)
Liked 4,565 Times
Quoted: 2027 Post(s)
Liked 1,099 Times
Note that recent chainrings have a specific orientation to take advantage of the shaped teeths shifting aids. The big ring orientation is obvious since the chainstop pin faces out and opposite the crank arm. Shimano inner chainrings have a small triangle engraved on the inner facing side and it is installed 180º from the crank arm.
Likes For HillRider:
Quoted: 3662 Post(s)
Liked 3,099 Times
Even with older cranks the tool isn’t absolutely necessary, but it’s nice to have, and as mentioned, isn’t expensive—like $5 or $10 bucks.
Thanks everyone.
It is pretty obvious where the hex wrench fits, but not the special tool. Since they are so cheap, probably best to just buy one and figure it out when the time comes.
Bikes: Bicycles? Yup.
Quoted: 508 Post(s)
Liked 1,707 Times
I'm pretty sure that tool does nothing for a 6800 crankset, and the chainring bolts require a torx T-30 driver. The tool is needed for older bolts.
Liked 3,099 Times
Usually--but not always--the friction from behind holds the inside bolt in place, both when loosening it and when tightening (sometimes even finger pressure on the back of the bolt can keep it from moving). It's when the bolt turns at the same time as you turn the Allen bolt that you need the tool.
The two pins on the right-hand part of the tool are used to remove crank dust caps on older models.
A Torx and not a regular hex Allen wrench? I hate when I have to buy a tool to use for 5 minutes, then again in 5 years when I am sure to have lost it.
Expired Member
Quoted: 3814 Post(s)
Liked 5,832 Times
You need to be sure what crank you have, then scroll to the bottom for chainring replacement. Shimano
Quoted: 863 Post(s)
Liked 1,113 Times
Ha ha, me too. I will say that Torx head fasteners are getting more and more popular all the time being used in everything. I just repaired a vacuum cleaner with Torx, also washing machine and dryer, cell phones, exhaust header pipes on my motorcycle, etc,. etc., so not a one-use tool anymore.
